Liquid split into pioneer djm800 mixer
Liquid inside the mixer.
can it be repaired?
    Scholar:
  • 38 Answers
Question is what kind of liquid and if the system has parts that would trap moisture.
Water you can simply that the cover off of most electronics and use a blowdryer to dry them out very well and let sit for a day then test it to see if there is permanent damage.
Anything that has sugar in it will cause buttons to stick and is not easily cleaned out. Some times a moist cloth can be used to clean most of the sticky substance up then proceed with the water method of cleaning.
If it has large capacitors or transformers these can trap water in them and cause shorts that will kill the electronics if not you.
Another item that will not like the water are sliders and rotary pots. The graphite that is usually present in these guys have bad reactions to water and will usually sound pretty bad after a swim.
Posted on Apr 05, 2008
What is error E5 on pioneer mini split air conditioner?
E5 indicates excessive temp. of the outside coil if on cooling, OR excessive temp of the inside coil in.
Try cleaning it (them if inside one too), with dishwashing liquid and spray outside hose.
Jun 03, 2014 | Pioneer Ductless Mini Split INVERTER Air...
Tap and fx buttons are stuck hi my name is john haill i am blind and own a djm 800 i my mum was cleaning my gear and she used polish and now there stuck
Use some CRC226 around them to break the polish residue and lube them. It should only take a little. CRC226 is available at Home Depot in the electrical dept. It is plastic safe.
Jun 03, 2011 | Pioneer DJM800 DJ Mixer (Warehouse...
Pioneer djm-800 mixer won't turn on is there a fuse to be replaced.. where is it located...and if not is it cheaper to buy a whole new power supply assembly or get it repaired?
  1. Take out all the knobs and faders and unscrew the face plate. (make sure to unplug first).
  2. You should be able to see a small tube fuse under the power button (I have the DJM 500 and that's my layout).
  3. Take the fuse out and see if the wire inside is broken or not. (best way to check the fuse would be to use a multimeter and set the dial on ohm and put a lead to each end of the fuse and see if the meter reacts).
  4. If it is not the fuse it may be the power supply, unfortunately I don't know how to check that one, but u can find spares online.
Good luck tdlabs
May 04, 2011 | Pioneer Audio Players & Recorders
I have owned my Pioneer DJM800 mixer for a few years now. Warranty is up on it. Decided to tighten down my headphone jack cuz it was getting loose. In order to do that, i had to take the top plate off (was...
This is likely a very simple problem. Look for a connector that you did not seat properly or got pulled off when you opened the unit. The cables are often short and pull off the connections or even break a wire. It is NOT likely you need a new power supply.
ALSO see if you might have pinched a wire when re-assembling the unit.
Jan 30, 2011 | Pioneer DJM800 DJ Mixer (Warehouse...
The bottons for my effects are not working
what doesn't work? the button itself, the efects selector knob, or the display? the more info. the better
- josh
Jan 13, 2011 | Pioneer DJM800 DJ Mixer (Warehouse...
Just bought DJM 800 mixer and the screen went out within 5 mins. The display stayed off and never came back. any ideas
This is likely a power supply problem. If under warranty have it repaired right away. Unless you have electronic repair skills, this is not a DIY project.
Download service manual here:
http://elektrotanya.com/pioneer_djm-800.pdf/download.html
Dec 22, 2010 | Pioneer DJM800 DJ Mixer (Warehouse...
Hi, My lcd screen keeps going away after 5 mins of
The fact that it comes back after a tap would say to me there is a dry joint or loose connector.
http://www.technicsdjuk.com/
http://stores.ebay.co.uk/methleykev
Apr 16, 2010 | Pioneer DJM-600 Silver Professional DJ...
My Pioneer DJM 500 won't turn on
i had my decks fixed by these guys they are in london.
thier websites is www.technics1210repair.co.uk
they do PIONEER MIXER REPAIR
check them out.
im only spreading the word due it i had my decks fixed their and i am so pleased im telling everyone so they can get the same service i did, rather than paying over the odds at some **** toster repair shop.
alan
Mar 14, 2010 | Pioneer DJm500 Professional DJ Mixer...
Single handel pioneer show facet will not get hot only warm ?
This is a spool valve.
Inside the valve is a mixer spool sealed with orings.
Remove the handle, and take out the spool. You will find an oring split/severed.
Take the spool and the model # of the faucet to the hardware store, and they will get you a replacement oring or an entire rebuild kit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 21, 2010 | Pioneer Plumbing
Headphone output not in sync with channel output on djm800 mixer
This is to help prevent feedback at high levels. While it may be "correctable", it would defeat the design of the unit to prevent oscillation...accordianman
Nov 22, 2008 | Pioneer Audio Players & Recorders
115 people viewed this question
 Grubhead
Grubhead
