Question about Compaq Armada E500 Notebook
Laptop battery date code
I have a compac E500 laptop battery with a date code of J1082. What date does this represent?
  • 426 Answers
The code is unknown...ony the computer manufacturer would know... try contacting them.... when in doubt throw it out (for the small things) if your wanting to replace it... go ahead and replace it!
Posted on May 27, 2008
6ya staff
SOURCE:
My laptop Compac NX 7400 doesn't run when I connect it on AC sector with the battery removed. Even with battery nothing comes. What the problem ?
That sounds like you may need a new AC adapter. If you need help finding the right AC adapter, I can help you.
Apr 23, 2013 | Computers & Internet
Dear sir , i have problem with my armada E500 "battery light flashing problem but system is not working with power button .just blinking orenge light .what can i do with it.
Hi
Remove you battery to you laptop and put out in 30min and check the middle of battery its coming out, if yes then change you battery because battery life is over.....
Cheer
Jun 26, 2011 | Compaq Armada E500 Notebook
I bought a used Compac Laptop & I cannot find the volume key. I am not very computer "literate", so you'll have to type very simply for me!
If your talking about the Windows Certificate it should be on the bottom of the computer or take the battery out and look in the pocket where the battery was.
Hope this helps... Dale
Apr 21, 2011 | Compaq Armada E500 Notebook
What is Dry Boot of laptop and how to perform it?
Dry boot is a way to reset HP laptops. Sometimes it works and sometimes not. Here is how to do it.
Disconnect the power cord, remove the battery, press and hold the power button for about a minute. Then re-insert the battery and power cord and try to turn it back on again.
If you are still having the same issue, remove the battery but leave the power cord and try to turn it on. Oh yeah, disconnect any USB devices and a monitor (if you connected a monitor to your laptop), make sure there is no disc in the drive either.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
Oct 02, 2010 | Compaq Armada E500 Notebook
Have compac persario m2000. The power supply will
the issue might be with the power jack . i mean the port where you insert the charger.. to fix this issue your laptop needs to be repaired.
Jun 14, 2010 | Compaq Presario M2000 Notebook
Compac laptop nc6000 tries to start up then shuts
For all troubleshooting, make sure the laptop is connected to the DC power cable rather than running off the battery.
are you getting any beeps? if not, it's probably bad system board or cpu. if you are getting beeps, then that beep code will usually give a clue as to the failing hardware.
Oct 03, 2009 | Computers & Internet
My usb port of my Compaq Armada E500 Laptop no
the usb port of my hp Compaq Laptop nc6000 no longer works properly. whenever i insert a flash it says usb device not recognized.
Jun 03, 2009 | Compaq Armada E500 Notebook
The Battery in my Hp Laptop Pavilion ze4900 is
using the wrong ac adapter the e500 adapter is not the same voltage or watts!
Feb 26, 2009 | HP Computers & Internet
Compaq Armada E500 Notebook Logo
2,030 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
