Question about Cell Phones
I have a cect 168, and when i touch the screen it seems to be a bit riht orientated, therefore not ltting me tap things on the left, as when i tap the left it comes up as if i touched the middle, how do i fix it?
You need to buy a new touch screen, you can get em cheap on ebay, you will not need a new lcd though
Posted on Sep 15, 2008
SOURCE:
How unlocked the icon lock do Nathing when touch the screen
      Lock/Unlock Screen Portrait Orientation Mode - Apple® iPhone® 5. This helps if you can't get the screen/display on your device to flip or rotate. Access the Control Center by touching the bottom of any screen then dragging upward. Tap the Portrait Orientation icon to lock orunlock screen portrait orientation.
      Lock/Unlock Screen Portrait Orientation Mode - Apple ...
      www.verizonwireless.com/support/knowledge-base-64759/ Verizon Wireless
    Feedback
    Lock icon with circle ios7 need to unlock ' Apple Support Communities
    discussions.apple.com > Support > Apple Support Communities
    AppleMay 5, 2014 - Lock icon with circle ios7 need to unlock ... iPhone 5, iOS 7 ... it will
Jan 23, 2016 | Cell Phones
.. key board not turning sideways to text it did
  1. Double tap the home button on the bottom of the iPhone/iPod Touch.
  2. Scoll left by dragging from left to right at the bottom of the screen.
  3. Tap the button on the bottom left.
  4. Now your screen lock orientation should be turned off so your keyboard will turn sideways when you turn the device.
Mar 22, 2011 | Apple iPhone Smartphone
Hp pavillon tx1000 12.1 inch touch screen cursor stays at bottom left hand conrner
Clean the screen with a clean soft cotton cloth is the step #1
Step 2:
SEE FULL instruction HERE
Calibrate the touch screen
The command buttons and fields are displayed on the screen image at specific pixel points. To initiate a response, the touch screen interface needs to recognize exactly where a fingertip or pen touches the screen relative to the pixel position of the display. Each user has a slightly different hand-eye coordination response. Calibrating the touch screen allows the interface to compensate between where the program is expecting a touch and where the touch actually occurs. To calibrate the touch screen, place the tablet notebook in the desired orientation and do the following actions.
  1. Click or tap Start > Control Panel > Tablet PC Settings to open the Table PC Settings window.
  2. On the General tab, select the option to display the menus in either the Right-handed or Left-handed position.
  3. On the General tab, select the desired screen orientation from the drop-down menu, and click or tap Calibrate . Follow the instruction to touch the screen at the specified points. Repeat this calibration action for all four of the screen orientations, then click or tap Apply .
  4. On the Handwriting Recognition tab, select the Use the handwriting personalization option.
  5. At a later time, you can return to review the Go to Pen and Input Devices and Go to Input Panel Settings options to make using the touch screen to control programs and input text easier and more accurate.
Compare your version of the firmware to the latest one at HP offical site HERE
Always get the latest firmware to avoid problem.
Always keep the screen clean!
Jul 11, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
When i tap for example on the top right hand
Try calibrating the screen from settings. It should work then.
Jan 04, 2010 | HTC Touch Diamond Smartphone
My cect 168 shuts off
Try backing up your information to the memory card and performing a master reset on the device.
To perform a master reset go to the main menu and tap phone setup. Then tap Reset Factory Settings. Tap "yes" to restore and reboot. If it asks for a pin, it is either 1122 or 0000.
Feb 27, 2009 | Dual Electronics CECT P168 Cellular Phone
The touch screen and the pen do not pair to function
my i9 phone does not apply the touch screen anymore and the pen calibration i cant click on screen . when i try to calibrate it keeps on the same infomation of "touch where the point is , left, center and right.
Dec 24, 2008 | Dual Electronics CECT P168 Cellular Phone
I want to load Games on to my cect i9 touch screen phone, can you
I'm sorry to say that that guy is wrong because the CECT i9 does have java depending on who you purchase it from. If you want proof go on youtube and look at some videos of people actually downloading java games to their phone.
Dec 22, 2008 | Dual Electronics CECT P168 Cellular Phone
Broken screen on cect 168+
Warranty usually does not cover broken screen. You may contact a vendor for repair at a cost. You can try: www.i-buy-iphone.com
Nov 17, 2008 | Apple iPhone Smartphone
Cect 168 unlock code
Hi.. I've a cect p168 and engineer mode *#3646633# dosen't work on it.How can I enable that.I used *#6810#.
thank you.
Jun 27, 2008 | RIM BlackBerry Pearl 8100
Cell Phones Logo
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
