Question about Disney Mix Max Digital Media Player
Disney Mix Max Problems
I have a Tinkerbell Disney Mix Max Player and it will not come on, unless it is plugged into the wall. Please help! I have a very sad little girl.
The mix max comes with a USB cable. Plug it into the computer and after it is fully charged you will be able to turn it on without the cable.
Posted on Apr 28, 2008
Reset the mp3
Posted on Apr 10, 2008
Just received a Tinkerbell Disney MixMax and it does not work. I tried to charge it with the usb cable to my computer...and nothing. It does not turn on at all.
I was successful in charging the device by using an old cell phone adapter (two worked) that fit perfectly (Motorola and Blackberry). If you do not have one lying around the house, checkout a thrift store. Best of luck.
Jul 08, 2011 | Disney Mix Max Digital Media Player
I have a Disney Mix Max and the movies won't load. Please help me. Thanks
Your problem may be that your movies might not be in the correct format. The Disney Mix Max only accepts files that are MP3 and WMA for audio, JPEG for video, and WMV for video. If the video that you are trying to load is not in WMV format, you will need to format it is so that it is in WMV. Converters can be found at download.com , generally for free or little cost. For the Mix Max user manual, click here. Resources- http://reviews.cnet.com/mp3-players/disney-mix-max-player/4507-6490_7-32133407.html?tag=mncolBtm;rnav
May 03, 2011 | Disney Mix Max Digital Media Player
How do i download music on my mp3 player?
How to Put Songs on Disney Mix Max
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable
* Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu.
Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
Mar 11, 2011 | Disney Mix Max Digital Media Player
I lost my cd to down load software to my laptop
Please check the following links for help:
www.playdigitalblue.com/customer-service/faqs/???disney/???mixmax
www.bestvistadownloads.com/???download-disney-mix-max-player-software.html
Sep 27, 2010 | Disney Mix Max Digital Media Player
I lost my disney mix max charger
There are several types of chargers you can use with the mix max....car charger, wall charger, USB to computer (FYI turn your computer off while charging and it stops), and my favorite - the speaker station. Just do a search for disney mix max charger on the internet, amazon, or ebay and several options will come up. I like the speaker station because it is easy to charge with it and lets my daughter use it as a stereo and dance unit if she wants.
Dec 10, 2008 | Disney Mix Max Digital Media Player
Deleting music on a mix-max
As far as why it's stopping it could be several things; there could be a problem with the track itself being corrupted or, depending on where you got the tracks, they could be protected with Digital Rights Management. The memory in the player could also be corrupt as well. I would start with reformatting the memory in the player to correct any potential corruption there might be. Below are three links that will answer both of your questions. Always make sure you properly disconnect the player from your computer to reduce the risk of corrupting the memory and causing these types of problems.
Format
http://digiblue.com/customer-service/faqs/disney/mixmax/06.html
Delete songs
http://digiblue.com/customer-service/faqs/disney/mixmax/05.html
Properly disconnect
http://digiblue.com/customer-service/faqs/disney/mixmax/03.html
Aug 29, 2008 | Disney Mix Max Digital Media Player
Disney mix match
Try going to their website and download the instructions for flashing the firmware on the Mix Max. Here's the link...
http://digiblue.com/customer-service/faqs/disney/mixmax/14.html
If that doesn't fix it I would call their support line and see what else can be done.
Apr 27, 2008 | Disney Mix Max Digital Media Player
Disney Mix Max problems
The memory could be corrpt in the player. It some times happens so try reformatting the memory to clear it up. This will erase everything and then you can put your songs and stuff back on it. Here's a link to the manufacturers instructions on how to format the player.
Mar 21, 2008 | Disney Mix Max Digital Media Player
How do you put music on a Disney Mix Max (512 MB) Digital Media Player
I have Windows Vista and the first time I plugged in the Mix Max it immediately downloaded the device drivers. I opened my Windows Media Player and it already recognized the player. I just transferred songs over walla they are on the player. Hope that helps.
Jan 03, 2008 | Disney Mix Max Digital Media Player
Disney hannah montana mix max
I have the same problem with my daughters Tinkerbell mix max. Any suggestions?
Dec 27, 2007 | Disney Mix Max Digital Media Player
Disney Mix Max Digital Media Player Logo
404 people viewed this question
Top Disney Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Rick
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
