Question about Creative Labs Muvo V100 MP3 Player
Not able to transfer music
When my portable device is not connected to base that holds aaa battery it won't come on and my computer does not detect that i'm plugged into usb port
  • vaughn41 Apr 05, 2008
    yes
    after i follow all these instructions, when i insert player should the player be in on position.
    Genius:
  • 1,447 Answers
When you put battery on it does it turn on?
Posted on Apr 05, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 05, 2008
    Yes and computer will prompt you if it doesnt have a driver for it by then if there is non you will have to install driver for Muvot
    here is the linkhttp://us.creative.com/support/downloads/welcome.asp?action=next
  • Creative Labs Master
  • 19,396 Answers
If the device does not start when is not connected to charger, then battery are gone.
  • Ginko
    Ginko Apr 05, 2008
    And to connect to computer ensure you installed the software before connecting .If it is already installed you may need to reinstall. Here is the link to download the driver.
    Ensure that the Muvo is not connected when you reinstall the software
Bought this at salvation army and it didn't come with the intrustion manual just the operation manual. I don't know how to sync it to my computer so it can charge
You don't actually mention what you bought, so I'll take some guesses and provide all the information. They are either connected by a lead to a keyboard from a USB lead to the computer itself. With mice they have a base unit which connects to a wall outlet and a lead to USB or multipin socket. The battery inside the mouse is charged by the base unit.
Then there are cordless keyboards and mice. These have internal replaceable batteries of the Duracell AA or AAA variety. Then in the USB socket on the computer you plug in a receiver. The problem with buying such devices from charity shops is that the receiver is often missing.
Newer mice can be Bluetooth, but the computer must be Bluetooth enabled. You just have to pair them.
'Synching' doesn't charge, it just connects to transfer data. Truly speaking 'synchronising' means connecting two devices and transferring data from one to the other so that they both have the same data.
Apr 29, 2016 | Computers & Internet
C150 as not working what's solution?
Check the orange "Hold" switch on the left side of the Sansa C150, if you cannot turn on the MP3 player or if none of the buttons is working. When the "Hold" switch is up, the buttons are disabled. Slide the "Hold" switch down to activate the buttons again.
Press and hold the "Power" button until the LCD screen lights up when turning on the MP3 player. Pressing the button quickly does not turn on the device. The "Power" button is located on the front of the device, under all the other control buttons.
Replace the AAA battery, if you cannot power on your MP3 player. To replace the battery, remove the battery cover from the back of the device by pressing in on its tab and pulling it off. Remove the old battery, insert the new battery and replace the cover. One AAA battery provides approximately 15 hours of power for your Sansa C150.
Change the backlight settings to conserve battery life. This is useful if you find the battery loses power quickly during normal use of your Sansa C150. To change the backlight settings, choose "Settings" to bring up the "Settings" menu. Select "Display," "Backlight" and then a shorter backlight time. The backlight will shut off after a period of inactivity that matches your backlight setting.
5
Review your music purchases to understand what rights you've purchased to the content, if you are unable to play a track back on your Sansa C150. When you purchase music, it comes with certain rules for how you can store and play it. You may not have paid for the right to transfer the song to a portable media player.
6
Reset the Sansa C150 if it acts erratically or if you have other problems. To reset the device, open the "Settings" menu and choose "Reset All." Choose "Save" to finish restoring the MP3 player to its factory default settings. If you decide not to reset the device during this process, select "Cancel" instead of "Save."
~KenjiFox
Jan 07, 2011 | SanDisk Sansa c150 MP3 Player
I need to download music and there is no file for
Using XP, the player should be detected through the USB port of the computer as a removable disk [also called MSC device].
note:
Before disconnecting the player, always go through the icon "Safely remove hardware" in the right corner below of the computer screen, to keep the player free from data loss or data faillure.
First prepare the player before connection / check normal working of the player:
0. Player NOT connected to the computer
1. Switch the player ON using the >| button
2. Check the HOLD icon in the display: padlock should be OFF
3. When the padlock shows up, unlock the player: slide the HOLD switch to the left: padlock should not show in the display now.
4. Switch the player OFF, holding the >| for about 3 seconds.
When the player should not behave normal, perform a RESET.
0. Disconnect the player if connected to a computer.
1. Remove the battery from the player and leave it out for 10 seconds.
2. Replace the battery.
3. Power ON the player with the >| button and see if the player works normally.
4. Switch OFF the player, holding the >| button for 3 seconds.
How to check the detection of the MSC device on your computer:
0. Player Normal Functioning, NOT connected, NOT locked and switched OFF.
1. Explore 'My Computer': click start in the left corner below of the computer screen and select 'My Computer'.
2. Connect the MP300 to a USB port; detection may take some time.
3. Look on the computer screen if a new removable disk shows up in the explorer overview, coming up with a new drive letter.
4. Now you should be able to put music onto the player, showing up as a removable disk with the new drive letter: use 'copy and paste' or 'drag and drop' method for music transfers.
note:
When no new drive letter shows up, try another USB port.
Connect directly to the computer, not through a hub.
If you need more help, tell me at what point connecting or transferring fails in this thread.
There's also a software program called Coby Media Manager that can be used for detection or transfers. Coby Media Manager is based on MTP connection mode.
Need help for this ? Write your comment in this thread.
May 28, 2010 | Coby MP300 MP3 Player
Wont turn on when new batteries were installed
It is likely that the calculator is ON, but the screen is too light to enable user to see anything. If that is the reason, you can darken the screen.
Press the [2nd] key and release it. Press and hold the UpArrow till screen darkens enough.
If that does not work, here is what the Texas Instruments Knowledge Base says about the calculator not turning on.
Here it is from the horse's mouth (TI Knowledge base)
I hope it helps.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83-family or Ti84 Plus family to reinstall the calculator operating system (see below.)
  5. Remove all of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Reinstalling the OS fot the TI84Plus
How do I correct the Error Waiting...Please Install Calculator SoftwareNow message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating the operating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect to send the operating system to the calculator. Make sure to have the latest version of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit back on." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
Oct 20, 2009 | Texas Instruments TI-84 Plus Calculator
TI 84 won't turn on. New batteries installed. TI Connect recognizes device and I installed new OS. Brightness is not the issue. Any suggestions? This is one of student's calculators. Thank you.
Sorry, answer was posted as a clarification request.
Caution: The resets described in these troubleshooting steps will cause a lossof applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed bypressing and releasing the up arrow; repeat as necessary. To adjust orlighten the display, use the down arrow.
  3. Remove one of theAAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. Thecalculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system (see below.)
  5. Removeall of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn thecalculator on. Adjust the contrast if necessary.
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating theoperating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect software to send theoperating system to the calculator. Make sure to have the latestversion of TI Connect installed on the computer.
Ifthe message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
Hope it helps.
Oct 19, 2009 | Texas Instruments TI-84 Plus Silver...
I have just bought phillips dab 1102 and drag and dropped music file for transfer but not showing on portable device.any help
normally mp3 players always show on pc as a prtable device when connected with pc. the main thing is if it not detect by pc as a device. u can't transfer any music & may be it will not work again (damaged). if it detect on pc then u can use quick format option then transfer new music files & see.
thanks
Oct 05, 2009 | Audio Players & Recorders
Replaced the batteries and downloaded the software
Hope it helps.
Oct 05, 2009 | Texas Instruments TI-84 Plus Calculator
I need to know how to turn it on...i don't know if its broken or what...cuz i put in new batteries and it won't trun on
1. Open the battery cover on your TuneCast II Mobile FM Transmitter. Install the included AAA batteries and
replace the battery cover.
2. Plug the 3.5mm connector into your iPod player or other portable music device.
3. The AUTO ON feature will power on the FM Transmitter when the unit detects an input signal. Your FM
Transmitter’s “AUTO ON/OFF” feature uses your audio player’s volume level to automatically power on and
off.
For best results, keep your player set at a medium volume level. NOTE: Setting your device volume very
low may cause the FM Transmitter to turn off, even if the audio player is on.
You can also press and hold
both and buttons simultaneously for two seconds to turn on the unit. To turn off the unit, press
and hold both buttons simultaneously again for two seconds.
Mar 03, 2009 | Belkin TuneCast II FM Transmitter
Unable to transfer music on creative muvo v100
i have a blackberrry curve8330 hooked up with page plus a prepaid service. I had accidently reset it and now the signal comes & goes how can i get it to work again? do i need a email address and password from pageplus?
Apr 05, 2008 | Computers & Internet
i have stored all mp3 player songs in my Olympia MP3 player but unable listen to songs getting an error message NO FILE but already there are 30 songs were there in MP3 player please let me know
Apr 05, 2008 | Creative Labs Muvo V100 MP3 Player
Creative Labs Muvo V100 MP3 Player Logo
53 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
