Question about Xterasys XN-2423G (XN2423G) Wireless Adapter
Blue screen at Microsoft second security package
After downloading Windows second security package I am getting a blue screen and a bad pool header whenever I try to connect to the internet. I had this problem earlier and I had to reload windows. When I didn't have this package I had no trouble connecting. Anybody have the same problem and any ideas about what I can do about this. I could always go back to when I didn't have my second security package but I'd rather not.
Thanks,
Gary
  • Anonymous Jun 26, 2008
    This morning I have started getting the error message Bad Pool Header after my computer has been on line for about 25-30 minutes. RegCure said it can fix Blue Screen errors but it does not fix this.I have no idea why or what to do to fix it.
    Regards
    Ceryac
Comment by ceryac, posted on Jun 26, 2008 This morning I have started getting the error message Bad Pool Header after my computer has been on line for about 25-30 minutes. RegCure said it can fix Blue Screen errors but it does not fix this.I have no idea why or what to do to fix it.
Regards
Ceryac
Posted on Jun 26, 2008
SOURCE:
My computer will suddenly stop and blue screen appeared, how many watts needed for intel desktop board nh8280
BSOD Bluescreen of death can be caused by a number of things
A bad or faulty motherboard data lead or its connection if its a flat 40 pin ide it will be the first to fail
make sure all leads have a dust free secure connections
A bad driver loose or faulty lead or not having enough ram
you might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang and cause memory dumps
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to
compatible ram also you will have an option to scan your system
you should always ask the seller if they guarantee the compatability of the ram before making any purchase
if you dont want to install more ram uninstall some unnecessary programs
make sure your ram modules have a dust free secure seating and the CPU central processing unit has thermal paste
if you can get a screen
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
or it might be a virus right click in bottom toolbar select task manager applications to see what is running and processes to see what is ticking over
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
http://100-downloads.com/download.php?p=615
windows xp microsoft security essentials
http://100-downloads.com/download.php?p=614
windows 7 microsoft security essentials
hope it helps
Nov 20, 2012 | Computers & Internet
My computersays VERYFYINHDMI poolupdate then turns on after blue screen
bluescreen can be caused by a number of things
a bad or faulty motherboard data lead or its connection if its a flat 40 pin ide it will be the first to fail
a bad driver loose or faulty lead or not having enough ram
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
malware protection
hope it helps
Oct 14, 2012 | Acer Aspire T690 (AST690UP820A) PC...
Blue screen BAD-POOL-HEADER
Your hard drive is messed up.
I'm assuming you are running Windows XP.
1. Log on to Piriform.com. Download CCCleaner and DeFraggler.
2. Run CCCleaner until you have no more registry problems. Reboot.
3. Then navigate to C:\TEMP and delete everything in the folder.
4. Navigate to C:\Windows\TEMP and delete everything in that folder.
5. Run Defraggler. This will take a while so brew a cup of tea, or coffee.
May 13, 2012 | Acer Aspireā„¢ T180 PC Desktop
Toshiba satelite on vista, comes up blue screen bad pool header then swithches off, then when i switch it back on, you here the dvd disc drive kick in but screen black, many thanks
First Update all the Drivers in the Computer, then remove the windows Updates which were done before the issue. Later use the Link to Download the Memtest86+ to check the RAM Module Stress.
http://www.softpedia.com/dyn-postdownload.php?p=13000&t=0&i=2
Now clean the registry using the any Registry Clean up application. This should resolve the issue.
Dec 01, 2010 | Toshiba Computers & Internet
Each time I plug in the USB cable I get a blue screen. I am running Windows 7. I am trying to load maps onto the Triton 400.
Don't bother with the 400 on a Win7 machine even though Magellan claims it will work. I also keep getting a bad pool header blue screen on mine even though I've updated everything I could. The best thing to do is to either setup a dual boot system with WinXP and only plug it in while running XP (Don't bother with XP mode in Win7) or have a second system that's dedicated to XP and run Vantage point from it like what I run now from my laptop.
The whole problem is caused by the Triton driver and for some reason Win7 doesn't like it all that much. Vantage Point does run great inside Win7 but as soon as you plug in the Triton, that's when it all starts to screw up.
All we can do is wait until Magellan gives us a proper working driver.
Aug 21, 2010 | Magellan Triton 400 Handheld GPS Receiver
When I put a blank dvd in my dvd drive, I get a ''bad pool header'' blue screen of death.
Sometimes the DVD is damaged thats why it shows like that or your drive won't support the local-made DVD.So u please use a branded DVD.
Dec 10, 2009 | Dell Dimension XPS 600 PC Desktop
Vista error codes 643 and 646
the error codes that you have mention is related to windows update of Microsoft .net framework.
To troubleshoot this issue, I suggest we first perform these steps:
Step 1: Download Microsoft Windows Installer CleanUp utility
1. Visit:
http://download.microsoft.com/downlo...BD/msicuu2.exe
2. Save the file to your computer.
3. Right click "msicuu2.exe", click "Run as administrator" and follow the
wizard to install this tool on your computer.
Step 2: Remove .NET Framework
1. Click Start ->All Programs->Windows Installer Clean Up, click Allow.
2. See if you can find .Net Framework software. If so, remove them.
After that, please restart the computer and perform the following
suggestions to reinstall .NET framework 1.1 and the updates for it.
Step 3: Install .NET Framework 1.1 Redistributable Package and related updates
1. Please download the Microsoft .NET Framework Version 1.1 Redistributable
Package from the following link and save it to the C drive (C:\)
1) Microsoft .NET Framework Version 1.1 Redistributable Package
http://download.microsoft.com/downlo...6/dotnetfx.exe
2) Microsoft .NET Framework 1.1 Service Pack 1
http://download.microsoft.com/downlo...867460-X86.exe
3) Security Update for Microsoft .NET Framework, Version 1.1 Service Pack 1
(KB928366)
http://www.download.windowsupdate.co...d81a178b15.exe
4) .NET Framework 1.1 Service Pack 1 SYSTEM.WEB.DLL and MSCOREE.DLL Security
Update for Windows Vista (KB929729)
http://download.microsoft.com/downlo...929729-X86.exe
Please follow the steps above and if still problem persist please lets us know
Regards,
Om
Oct 20, 2009 | Computers & Internet
Sony CRX835E CD-RW drive, Blue screen of Death on inserting CD-R
Bad Norton install. Actually bad Norton. Its causing driver corruption.The fact that it appears only when you insert a cd-r it's just random occurence, it could have happened as well when you would have tried to print something.
Best fix: just get rid of Norton , it's useless anyway. Get a decent antivirus for start. Otherwise uninstall it using the official uninstaller (not by using its uninstaller), run a registry cleaner, install it again using this time a diferent location and hope to gods that this time it won't screw your pc.
May 01, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Xterasys XN-2423G (XN2423G) Wireless Adapter Logo
153 people viewed this question
Top Xterasys Computers & Internet Experts
Ekse
Alun Cox
Are you a Xterasys Computer and Internet Expert? Answer questions, earn points and help others
