Question about Lexmark X6150 All-In-One InkJet Printer
Lexmark X6150 scanner function is not working at all
    Brigadier General:
  • 6,966 Answers
If you are using Windows Vista, then you would need to update your drivers appropriate to your OS, update Vista specifically is USB ports drivers to the latest updates/patches. This is a common issue with Vista's USB ports. Microsoft has acknowledge the issues and has posted a fix here and here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 05, 2008
5 Suggested Answers
  • 829 Answers
SOURCE: How do I download a manuel for lexmark x6150 ? Chaplain Major Wa
Hi Click the below link and download the pdf file.
Posted on Jan 09, 2009
  • 435 Answers
SOURCE: my lexmark x6150 says hardware error 0502
Hardware Error 0502 on LCD Display
The encoder strip may have gone out of range of the sensor, or it might be dirty.
You need to check the encoder strip on the printer. This is a clear strip running the length of the printer, above or behind the cartridge carrier.
Check the encoder strip
    1. Switch off the printer using the power button.
    2. Disconnect the power cable from the back of the printer.
    3. Leave the power cable disconnected for 30 seconds.
    4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
    5. Take out both cartridges.
    6. Place an index finger on the encoder strip on either side of the cartridge carrier.
    7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
    8. Lightly press the strip first to the rear and then forward, if necessary.
    9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
      Click here for an enlarged view. The contacts on the back of the cartridge carrier are the ones you need to clean. IMPORTANT: Use a dry tissue.
    10. Reconnect the power cable and switch the printer on again.
    11. Perform the hardware test, first without the cartridges and then with both cartridges. Click on the applicable article link below.
      How to Perform the Hardware Test on the Lexmark X5150
      How to Perform the Hardware Test on the Lexmark X6150/X6170
    12. Make a standalone copy.
    13. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
Thank you
Posted on Feb 14, 2009
SOURCE: Lexmark X6150 says balck cartridge missing
Must use a new cartridge.
Posted on Jun 23, 2009
  • 928 Answers
SOURCE: Lexmark X6150 will not communicate with new Dell Vista computer
Uninstall the driver and restart. Turn off antivirus, install driver again and always click allow or yes if firewall ask for permission. Follow instructions, restart when done.
Posted on Aug 31, 2009
I need to unlock the scanner to turn on the printer
Please refer to this article from the Lexmark website on How to Unlock the Scanner Before Use on the Lexmark X6150 / X6170.
I hope this information has been helpful.
Sep 21, 2011 | Lexmark X6170 All-In-One InkJet Printer
I can not get the correct driver for the Lexmark X6150 All-In-One InkJet Printer. It installs everything but the scanner and the coppier.
Yes lexmark will not provide the drivers to these all in ones. They claim the 3rd party supplier prevents them from doing it. The only way to reload these drivers is to use the disk that came with the machine. Sometimes you can buy another one from lexmark but after 1-2 years they quit selling them because they want you to buy a new printer. Good luck.
Feb 15, 2011 | Lexmark X6150 All-In-One InkJet Printer
I have X6150 Lexmark and I am having a problem scanning from printer to computer. I have windows Vista operating system. Can you assist?
I have the same problem. The scanner isn't working at all.
I installed the current drivers from the lexmark suport page.
The hardware manager announces a problem with currupt registry information about the scanner (error code 19). Re-installation didn't fixed it and I even cleared the registry... but still now effect.
Printing works fine.
It would be very great if somebody here may have an idea...
Thanks in advance.
Dec 31, 2009 | Lexmark X6100 Flatbed Scanner
Lexmark x6150 wont scan
Sounds like your laptop isn't talking to your scanner. These scanners only work if it has access to a computer to store the scanned image. Check if your USB drivers are installed. Most times you can go to "Device Drivers" in Control Panel (Under the "System" icon) and right click USB to update drivers on the net. Depends how old your laptop is too. If that isn't the problem, try installing the drivers again, or search the net for newer versions.(Usually at the Lexmark site). But at the end of the day, you won't be able to scan till your laptop can recognize your Lexmark printer!!!!
Feb 14, 2008 | Lexmark X6150 All-In-One InkJet Printer
Lexmark X6150 All-In-One InkJet Printer Logo
613 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
