Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washing Machine Smell and Stopped Working
This is regarding a Whirlpool Ultimate Care II washing machine. After five continuous loads of wash, the washing machine produced a burning rubber smell and then stopped working. After 7 hours, The machine was able to work again in proper working order. Is this because it was overworked? The motor could have possibly overheated? Please provide me with a more probable answer, it would be greatly appreciated!
Thank you.
Nick and Kathya
  • 5 more comments
  • Nick9673 Apr 05, 2008
    Thank you aborcass. I thought so too. The same thing happened when the freezer door was left open one day. After about 10 minutes, the whole fridge shut off and had to reset it from the button in the back.
  • Anonymous May 04, 2008
    same problem
  • nubile Oct 20, 2008
    Was washing a big heavy blanket when I smelled something burning - almost burnt rubber smell. Went to shut it down and noticed it was already dead. Researched for hours, then plugged it in and it works fine. I will be unplugging it when not in use and watching carefully over the next few loads.
  • Anonymous Jan 02, 2009
    We have a new Whirlpool top loading washer, nothing fancy - it was about $350. I've done a bunch of loads using the low agitation cycle with no problem but this morning used the two-speed "Casual" cycle for the first time and it started to give off a burned smell. Water level was OK but I added more anyway and switched it back to low agitation. It is going fine, but this is not a good start! Can you tell me more about the two-speed problem, and how to tell if it is an electrical contact vs a belt problem? (We have the manufacturer's warranty only.) Thanks much
  • vandic44 Jan 14, 2009
    I have the same problem with my Whirlpool washer (same make) but now mine won't go on at all. It is only four yr's old. Any suggestion's?
  • billwer Apr 25, 2009
    GE Washer WPSF4170V0WW - Half HP 2-speed motor runs for 10 seconds or so, then cuts out - on all cycles, agitate and spin. Seems that its a thermal overload issue. Is the motor shot?
  • Anonymous Apr 29, 2009
    When lid closes the machine doesn't start. You have to bang on it for it to start. Is it the lid switch??
    President:
  • Whirlpool Master
  • 2,651 Answers
Thatss what it sounds like to me the motor simply turned off on overload( giving that electrical, almost burnt rubber smell.) either that or it was overloaded as well as overworked. i wouldnt see any reason for concern, unless was happenig on regular basis
Posted on Apr 05, 2008
    Novelist:
  • 184 Answers
THERE IS ONLY ONE DEVICE ON A TOP LOAD WASHER THAT WILL SHUT DOWN THE MACHINE AND THEN RESET LATER. THE MOTOR HAS AN OVERLOAD ON IT THAT WILL TRIP IF THE MOTOR GETS TOO HOT OR PULLS TOO MUCH CURRENT. IT SOUNDS LIKE IT GOT TOO HOT FOR SOME REASON. IF THE MACHINE WAS OVERLOADED ON EACH WASH LOAD, IT COULD CAUSE OVERHEATING OF THE MOTOR.
ANOTHER CAUSE WOULD BE IF THE MOTOR IS A TWO OR THREE SPEED MOTOR, AND THE TIMER OR SPEED SWITCH FUSES CONTACTS TOGETHER, IT COULD CAUSE TOO MUCH CURRENT TO RUN THROUGH THE MOTOR OVER HEATING IT.
I WOULD JUST MONITOR IT AND SEE IF IT GOES AHEAD AND WORKS O.K. THE OVERLOAD WILL KEEP IT FROM BECOMING DANGEROUSLY HOT.
Spin does has stopped working. all the functions work normally but the washer has stopped spinning.
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Here is a link to the part you will need.
Jan 01, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer ultimate care II will not spin motor is working
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Standard washing machine hoses dont seem to fit my Whirlpool Ultimate Care II washer? Do I need an adaptor of some sort....
The Whirlpool Ultimate Care II is an American top loading washing machine and requires different hoses available from Whirlpool.
May 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool washer (Ultimate Care II) stops at
This is probally the lid switch. You can check this by checking for continuity. You should have none with switch open and some continuity when switch is closed if yours has continuity when opened you will need to replace. There is a video at www.appliancehelponline.com/servicemanual.html that can walk you thru the replacement.
Mar 28, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine won't drain
I had a new washing machine in my garage(lucky me)
Aug 22, 2009 | Whirlpool Washing Machines
Whirpool washer burning smell
i would consider getting aanother washer.if it keeps doing this the machine will cost you more than its worth. time to call a repairman in again id guess..
Jan 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine will not cycle
I have a Whirlpool Ultimate Care II. My washing machine would not cycle once it filled with water. I purchased a lid switch from partselect.com. The installation took five minutes. This corrected the problem. I hope this helps.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Top Loading whirlpool washing machine.
Could be the top lid switch. If the timer has stopped moving (you can no longer hear it clicking along) good chance that's what it is. When it has stopped try pushing hard down on the top of the lid AND/OR put a piece of plastic (or something ) into the lid latch switch... See if it continues on with the wash cycle...
Mine just went bad this week. Bought the part for $25...
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer stopped working
If after waiting for a while it still does not respond - most likely the motor is burnt - especially if those were all very heavy loads
Regards
Sep 17, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
3,101 people viewed this question
Dan Webster
Dan Webster
Sal De
