Question about Sharp HTDP2500 System
Sharp DP2500 speaker bus diagram
I have a sharp HT DP 2500 system. It has proprietary speaker connection bus plastic connectors that I cannot figure out the proper connections for. (I don't have the factory wiring harness to plug in. I bought a schematic, but it is for an HT DP2500W.Sharp customer support has been no help at all. Any idea where I can get a diagram for the proper hook ups?Thank you
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 95 Answers
Hi..have you gotten an answer for this question...I just googled this model number..and about the second one down is the factory service manual...for the model you and I have...there is a way to go inside and solder wire to each speaker leg to make it work that way without the special plastic connector that was the original..
Posted on Jul 23, 2015
5 Suggested Answers
guitarman002
  • 80 Answers
SOURCE: I was given a Sharp HT-DP3000 reciever and all the
Do you have speaker wire if not you will need some, the wire is cheap about $5 bucks a roll your local department store will have it. You see a red and black tabs on the back of the unit and on the back of each speakers you push down and stick one wire in the hole. red will be your + and black will be - The two surround go on the back wall behind your seat.The center will sit on top of TV and the sattalite speakes go beside the left and right side of TV. and the sub sits on the floor in hidding behind something or under a table. (P.S, Make sure the wire is shaved about 1/4 of inch before you stick in the wire DO NOT plug the power cord in, intill you hook up all the speakers this could damage the unit. You do not need a sub woofer, if you have one great If not don't worry that will not damage the unit it has a internal switch to turn on/off the sub woofer The sub woofer offers extra deep bass that you can't get from the sattalite speakers.)
Posted on Aug 31, 2009
  • 41 Answers
SOURCE: how to hook up sharp dolby surround pro-logic
The source of your program will determine how you hook things up, and if you want to (if it's possible) route the video through the Sharp as well. Some systems have video switching, so you can run all sources through the system, and have a single video cable running to the TV.
If you are using a DVD player, typical Pro-Logic requires a red/white RCA cable from the DVD player to the amplifier unit. The video cable, either a 4-pin S-Video or a yellow composite cable, will run to the amplifier unit for switching purposes, or ditect to an input on the TV.
You can also run red/white RCAs fron the HDTV to an input on the Sharp. You likely have to set the TVs audio output to "fixed" or "external", which will disable the TVs speakers, while putting out sound to the Sharp.
Posted on Jan 06, 2011
  • 910 Answers
SOURCE: looking for owners manual free
Sharp support from their website is very poor and I don't think you'll get a free one from anywhere.
This is the closest to free I could find.
http://www.ued.net/ued/addItems.do?itemCode=SHATINSE0006SJZZ Shows Sharp Part No but out of stock.
http://www.encompassparts.com/products/?SHATINSE0006SJZZ is where you can get if from for $3.50 but not sure about P&P.
Posted on Apr 20, 2011
  • 5421 Answers
SOURCE: Hi.How can I connect SHARP HT-SB400 sound bar
You should be able to connect these but you'll need some extra adapters/converters/cables. The Sharp HT-SB400 has analog audio inputs (http://www.sharp.co.uk/cps/rde/xchg/gb/hs.xsl/-/html/product-details.htm?product=HTSB400&cat=10500 ). The Samsung UE40C6000 LED TV has a digital (optical) output and a headphone jack (http://www.samsung.com/uk/consumer/tv-audio-video/television/led-tv/UE40C6000RKXXU-spec ).
With a RCA (F/F) to 3.5 mm (M) adapter, you may be able to connect the headphone audio out to your sound bar directly. This is an example: http://www.cyberguys.com/product-details/?productid=4730 . I'm not sure if this will automatically disable the TV speakers.
The other option is to get a digital audio to analog audio converter. One of these is http://www.amazon.com/Digital-Audio-Analog-Converter/dp/B0013LWK3A . You'll also need the optical digital cable in addition to the RCA audio cable that you have. With this you'll have to follow the manual for turning on the digital audio output on the TV (under the Sound menu) and turn off the TV speakers.
I hope this helps.
Posted on Mar 05, 2012
I need remote control for my Sharp Home theatre receiver model HT DP 2500.Do you have it?
this site does not handle anything
if you want something , go e-bay, gumtree, contact the manufacturer direct or call in at a appliance repair shop that repairs you equipment
Oct 30, 2015 | Sharp Audio Players & Recorders
I just bought the sharp home theater system ht-sl70/ht-sl75 and I cannot get the volume to be controlled thru my remote. I have a 60 inch sharp aquos tv. It has no arc and when I use the rca connection it...
Hi
I just bought HTSL75 speakers. Its manual saying its volume is controlled by TV's remote control
But i am having Samsung UN46EH6000 LED. and Speakers is connected to LED via RCA and LED is giving fixed output, so all the time, speaker is working on full volume
Is there any workaround, so that i can control volume while using sharp HT-SL75 speakers with Samsung UN46EH6000 ?
Is there any volume control device to control the volume of the speakers in my case ?
Thanks for your help !!
May 09, 2012 | Sharp Audio Players & Recorders
Hi.How can I connect SHARP HT-SB400 sound bar system to TV SAMSUNG UE40C6000 LED? I have RCA cable supplied by sharp, it's that possible? My SAMSUNG operation system is : T-VAL6DEUC-1016.0
I hope this helps.
Mar 04, 2012 | Sharp Audio Players & Recorders
How to connect sharp HT-SB350 to Sharp LC-42D69U
You may have to use the optical cable connections. Make sure there is an optical out on the tv and on the sound bar. Get an optical cable to connect them and go to the audio setup screen and direct the sound from internal speakers to optical out.
Nov 13, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Looking for owners manual free download - for my sharp ht-dp2500
Apr 20, 2011 | Sharp HTDP2500 System
Sharp HT-DP3000 reciever don't know how to plug in speakers
Hello, many thanks for your request. I found a quick manual for HT-DP3000, you can download it here:
http://www.tradebit.com/filedetail.php/9120914
(Check out for the green download button on the upper left side)
Aug 31, 2009 | Sharp HT-DP3000 System
I was given a Sharp HT-DP3000 reciever and all the speakers that go with it.. but I don't know how plug in the speakers into the wire there is a box for the two surround and a separate box for the right...
I want to the ability to hook up another set of
Don't do it. The all-in-one box systems are not designed for modifications, hence the proprietary and prohibitive connectors. No more, no less than the supplied speakers. The amps are actually way more modest in power than the advertising hype would have you believe. If you do figure out a way to run more speakers in parallel you do so at the risk of damaging something.
May 14, 2009 | Sony CMT-HX7BT Shelf System
Sharp HTDP2500 System Logo
826 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
