Question about Kitchen Ranges
We have a ge self-cleaning radiant range. I accidently spilled hot grease from steaks when I was removing them from the broiler. The grease dripped down inside the glass on the front of the oven. Is there anyway to clean this. It looks awful.
    President:
  • 778 Answers
If you are saying that the grease got in between the layers of glass (lamination), then you will have to disassemble the door, clean the glass, and reassemble. I haven't done this job on your particular model, but have on others and it is a tedious & time consuming task.
If though the grease is just cooked onto the inner surface of the glass on the oven door, you could use a single edge razor to scrape the gunk off (being extremely careful not to flip the blade causing you injury), as you would ice off a windshield with an ice scraper. There are handles made to keep the blade secured while using it (making it less likely to flip and injure the user).
Posted on Apr 05, 2008
Our new home has a GE XL44 gas stove the top works fine but when I use the oven it smokes and sets off the smoke alarms.The stove is over 3 years old Any ideas before I have to call the repairman in?
A gas stove shouldn't smoke. Is is clean? There is some grease that has eluded your cleaning efforts of interior surface?
Here are some tips that may help you resolve this problem:
Check the broiler flame. If the broiler flame is not adjusted properly, you could be creating soot from the burner flame.
Position the items that your are broiling lower so that they do not splatter grease up onto the broiler baffle.
Use a broiler pan that will drain grease and drippings down below the top surface.
Broiling many items will naturally produce some smoke. If you have the oven door closed when broiling then the only place that the smoke can go is up and out of the oven vent. If you partially open the oven door, some of the smoke will come out of the door opening.
You may have residue on the top walls of the inner oven cavity. Do you have self-clean feature on your range to clean the oven? Follow all of the procedures in your owner's manual to properly clean the oven using the self-clean cycle. This may clear out any undetected residue that could be causing excessive smoke during broiling.
Aug 26, 2015 | GE Kitchen Ranges
I have no owner's manual and need to know how to clean a "self-cleaning" over.
Manuals for many GE appliances are available here: http://www.geappliances.com/service_and_support/literature/ . You will need the model number and there is a guide to find the plaque at the site. Most ranges will have the plaque under the left front burner, on the frame behind the oven door, on the frame behind the drawer or on the left leg behind the drawer or kickplate.
General cleaning procedure for self-cleaning: first use hot soapy water (non-abrasive cleaner, not an oven cleaner) to clean the frame around the oven and the oven door itself. Also clean large spills (acidic and sugary spills can damage the surface of the oven). Remove all of the racks, foil, pans and the broiler pan from inside the oven. Close the oven. Ventilate the kitchen well. Then it depends on the oven type.
If you have a touch pad, press the Clean button and adjust the time for the cleaning cycle (usually with the +/- touch pads). Then press Start. Press Cancel to stop the cycle. The oven will automatically lock and remain locked until the oven cools down after the cleaning cycle. See the documentation for timed cleaning. If you have a dual oven, you will need to press the Oven button for the one you want to clean.
If you have an older range, push the latch to the right and set the Oven cycle dial to Clean. After the oven has cooled, turn the oven cycle dial to Off and push the latch back to the left.
I hope this helps.
Feb 18, 2011 | GE Kitchen Ranges
My jgsp48soh1ss GE profile is having broiler problems. It goes on but the flame is too low. Won't broil a steak as the flame won't extend over the metal guard.
No promises but id try to get it a good cleaning, some times grease and oil of popping fat pockets may clog your vents for the gas. Also try to find the supply line in and make sure that is is well sealed, with no cracks or breaks. There just may not be enough gas getting to your broiler.
Please note, i am no expert, only doing what i would try and do to fix it. Best of luck
Jan 28, 2011 | Kitchen Ranges
When I use my self-cleaning on my oven it leaves a brown stain on the white plastic part outside my oven door. How do I clean the area that has browned?
Hello- The self-clean cycle heats the inside up to about 800deg. There is no existing plastic that can take the heat at the vent w/out discoloring. The stain is from the smoke produced when the stuff on the drip pan incinerates. Try some oxy-clean and a damp cloth. Try to predict or minimize spills with foil and drip pans. Techs call 'self-clean' the 'self-destruct' cycle. Using this function will reduce the life expectancy of any electric range. Let me know if this info helps-have more if needed- Thanks- ED
Jan 28, 2010 | GE 30" Self-Cleaning Freestanding Electric...
GE PROFILE JBP79 OVEN RANGE - OVEN DOESN'T BAKE. CLOCK, BROILER, CLEANING WORK, LIGHTS WORK WHEN CLEANING OVEN. COIL ON BOTTOM DOESN'T GET HOT BUT BROILER COIL DOES.. WHEN CLEANING OVEN LIGHT WORKS WHEN...
Could be the sensor inside the oven.Mine burnt out when using the self clean feature. Two screws un-plug replace with new. Part less than 15 dollars
Jan 08, 2010 | GE Kitchen Ranges
GE JBP66 Self Cleaning Radiant Range
Your range is wired improperly. Hot wires go on the two outside terminals.
Nov 04, 2008 | GE JBP24 QuickClean Electric Kitchen Range
GE Profile Still Heating with nothing selected
IS THIS A DIGITAL RANGE,IF SO REMOVE THE TOP BACK COVER AND SEE IF ANYTHING ARCED(BURNED SPOTS) ON THE CONTROL BOARD,IF NOT DIGITAL, YOUR OVEN KNOB SWITCH IS STUCK IN CLEAN MODE,I HOPE IT'S NOT THE CONTROL BOARD AS THEY RUN ABOUT $200 ,LET ME KNOW-MIKE
Jun 15, 2008 | GE JBP65 Electric Kitchen Range
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
Kitchen Ranges Logo
252 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
