Question about Vizio L32 32 in. LCD HDTV
Black Squares on the Screen
At random, and in random places, little black boxes appear on the screen. Sometimes there is only one; other times there are as many as ten. Changing channels doesn't help and neither does turning the TV off, waiting a few minutes, and then turning it back on. Sometimes it happens for several days in a row; other times we may go for a few weeks before we see them again.
  • 1 more comment
  • acaerlyn Apr 10, 2008
    I have the same exact problem with my VISIO 47" HDTV. I bought the TV about a year ago at Sams. I use regular Cable TV through Comcast. Could it be a problem with Comcast or the TV itself? Mine only starting doing it the last month.
  • neshanicmom Jun 19, 2008
    I have the same problem - random black squares that come and go. Our cable company also just changed to Comcast.
  • Anonymous Jun 22, 2008
    MY 42" VIZIO NOW HAS BLACK RECTANGULAR BOX COVERING LOWER 75% OF SCREEN. HAVE TO TURN OFF SET TO REMOVE, BUT KEEPS COMING BACK AFTER 5 - 10 MIN.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
This kind of problem is normally do of bad cable box or sat
Posted on May 02, 2008
SOURCE:
Sony Wega 27in Randomly Has Block Box Appear On Screen
this means the TV having picture upper part of the screen. problem may be -15 V to vertical deflection ic suddenly gose off and system control gose to stand-by mode resolder vertical out ic , -15 v supply line from the fly back and system control .
Jan 15, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Vizio 42" LCD - Random appearance of small black rectangles
There is a processing fault that is starting to occure. What you are seeing is a type of aliasing. This can be in the main signal processing or in one of the control areas.
The set will require service. The service rep will test the set by using board substitution. There are typicaly a number of areas in the TV set that can cause this type of fault. Once the defective board is located the fault will be easy to service with a simple board swap and some adjustments.
If the set is out of warranty, it may be expensive to service. With many of the no-name brands, spare parts can be difficult or impossible to have.
Jerry G.
Jan 02, 2009 | Vizio L32 32 in. LCD HDTV
Sharp lc-26sh10u intermitent problem
its a motherboard problem. i got one for sale or you can sell me the tv cause mine has a broken screen
Dec 25, 2008 | Sharp LC-26SH10U 26 in. LCD Television
Black box
Go to your menu and turn off the closed caption
Nov 07, 2008 | Olevia LT42HVi 42 in. LCD Television
I would check and see if you have the text option on under your closed captioning. With the new digital transition the signal for text captioning has been getting messed up during broadcast here lately. If it is on i would just shut it off or go to regular closed captioning.
Nov 02, 2008 | Vizio GV42L 42 in. LCD Television
Black menu-like box randomly appears, covering the picture
This is a problem with closed-captioning. What you are seeing is a closed captioning box with no captioning in it. Usually this is being accidentally transmitted by the cable company "head end". Just make sure your closed captioning function is completely turned off. if you are seeing it randomly, it may well be coming from your cable company. Is it just on certain channels?
Sep 05, 2008 | Toshiba 15DLV76 Television
Black Box
It sounds like the "Text" mode of closed captioning has been turned on. If you look towards the top-right of your remote you should see the "CC" button. Push that and set the option to "Off"
Jan 18, 2008 | Olevia MN-20LCDTV-SN 20 in. EDTV-Ready...
Black bar on screen
The text mode in the closed caption is turned on.Turn off the closed caption. I don't have the schematic in front of me, so, I will wing it. There may be a button on the remote that says CC, if so then use that button to turn it off, if not then go to the service menu and you may have to search a bit. Either way it's an easy fix and you can do it yourself. If you can't find it, then, reply and I will give better instructions when I get into my shop next week.
Sep 10, 2007 | Samsung TX-R2735 27" TV
Small black squares appear on Vizio 37
Sounds like a digital cable issue to me. Try connecting the cable directly to the TV bypassing the cable box and I bet that the issue will be gone. If so then contact your cable provider as the box or the incomming signal may be at falt.
Apr 01, 2007 | Vizio L37 Television
Vizio L32 32 in. LCD HDTV Logo
616 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
