Question about Daewoo DP42SM 42 in. HD-Ready Plasma Television
Lines moving through out picture
Lines squiggle randomly though out the picture only on the Video 2 screen. This began about 6-months ago. Tried switching out the DVD player, but the problem still remains. Seems to get worse when the colors in the scene are lighter. When it first started, the lines would dimish after about 10 minutes of playing the DVD, but now they remain the entire time. Any suggestions?
Can't give tech help ,but can tell you we have same problem and having a hard time finding an anwser /someone to come out to look . actually had a repair shop ask me to bring it in (yeah all 85 lbs.) will try calling place that repaired it when it was under extended warraunty thru best buy. took 1 mo to get the part back then. did you see my post on wiggly lines. good luck
Posted on Apr 27, 2008
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Screen flickering
A number of possible reasons--from brightness/contrast set too high to a issue with the power supply of the set--a expert would have to examine the set--you might want to call Sony to see if known issue with this model.
Oct 29, 2012 | Sony Grand WEGA KDF55E2000 55" Projection...
I purchased this computer refurbished 3 1/2 months ago. Just a few days ago, it started showing colored lines and locked up, Now, it seems to be an ongoing issue. Sometimes it will stay on for a half...
This sounds like a problem with the hardware electronics of the LCD the green blocks are a symptom of that. You can see if that is the case by attaching an external monitor and clicking the Fn key and one of the F keys at the top row of the keyboard that transfers the video output either to the LCD or to an external monitor or both - so you have to press that key a few times.
It may be possible to repair this problem by opening the screen, replacing some parts etc. but it is not easy or cheap. There is high voltage within the screen ic board so be careful.
Please rate Fixya answers.
Apr 16, 2011 | Computers & Internet
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
Purple image was visible in viewfinder and in picture, came on at rare random in 2 months ago. The picture became more frequent, and picture had vertical distortion as well. Pictures unusable. Then good...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jun 24, 2009 | Canon PowerShot S1 IS Digital Camera
White vertical lines on both monitors
You can download the latest drivers for the video card.Your co-worker does she have the same syatem as yours?When you download the lastst drivers.Un-install the installed one from your machine.Reboot your computer and install the drivers you downloaded.
Good luck
Apr 02, 2009 | Dell E178WFP 17 in. Flat Panel LCD Monitor...
Slow to come on, picture flashes black, 32" SONY tv
blankenship, the "IK circuit" is blanking your screen, only "fix" is temporary, remove back of tv, and on rear right side (facing into the back of the set) you can see 2 philips type plastic screws mounted on the flyback transformer, one is focus the other is screen, do not adjust focus , turn screen control clockwise slowly until you get white retrace lines on screen, then turn counterclockwise until retrace lines disappear, this increases drive from tube to IK circuit, will last anywhere from 6 months to 18 months and then it`s replacement time, questions? e-mail me back. good luck, BMW Rider
Jan 11, 2008 | Televison & Video
Hoizontal lines in images
The problem is faulty CCD sensor ( this device converts light into image ) so faulty sensor means either poor quality pics or no pics at all. Have sensor replaced and camera will work fine.
Sep 11, 2007 | Konica Minolta DiMAGE E50 Digital Camera
Screen full of moving colored lines
I would suspect bad solder connections allowing a ground to "float" It is a common problem with the model P42W24BX which I believe uses similar circuitry as your model. An experienced repair shop should be able to get you fixed up.
Dec 18, 2006 | Zenith P42W46X 42 in. Plasma EDTV
Daewoo DP42SM 42 in. HD-Ready Plasma Television Logo
103 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
