Question about RCA H100 MP3 Player
Help me out
Where do I connect the RCA USB cable to the RCA Digital audio player
Connect the little end of the USB cable to the top of the unit. If you are looking at the face of the unit, the port for the cable will be on the right. Then connect the big end of the USB cable to your USB port on your PC.
Posted on Apr 09, 2008
How do I connect my Yamaha RX-V733 to a CD Player?
I don't see a RX-V733 on Yamaha's site. However, look for a stereo audio input on the receiver. Then use the appropriate audio cable or adapter for the CD player audio out.
Depending on the CD player, you should use either an RCA M/M to RCA M/M (red/white) audio cable or a 3.5 mm headphone to RCA stereo audio cable. (If you don't have a headphone to RCA stereo audio cable, you can use adapters on either side. Examples: 3.5 mm M to RCA F/F adapter to RCA audio cable as above or 3.5 mm M/M cable to 3.5 mm F to RCA M/M audio adapter, depending on which cable you want to use and where you connect the adapter.) After making this connection, turn on the CD player, select the appropriate input.
The connection for an external audio device (like a CD player) is shown on page 31 of the manual for the RX-V773. Even if this is a slightly different model, the image may help. The manual is available from Yamaha on the product page: http://au.yamaha.com/en/products/audio-visual/av-receivers-amps/rx-v773_g/?mode=model . Click on the Support tab. The direct link to the manual is http://download.yamaha.com/api/asset/file/?language=en&site=au.yamaha.com&asset_id=54075 .
I hope this helps.
Feb 21, 2017 | Yamaha Audio Players & Recorders
How to download on my mp3,have never done a download,it is a pearl rca
  • You will need USB cable .
  • It will be provided with your mp3 player.
  • Connect your RCA MP3 player to your computer with the USB cable that came with the player. Plug one end into the Opal player and plug the other end into your computer's USB port.
  • Open the Rca's USB flash drive. Click "Start." Click "My Computer." Click the "USB Mass Storage Drive."
  • Open another "My Computer" window, and locate the music that you wish to download onto your RCA MP3 player. Click "Start." Click "My Computer." Click "My Documents." Click "My Music."
  • Drag and drop the music files you wish to download onto your mp3 player's "Internal Storage" folder (for Windows Vista) or the "Media" folder (for Windows XP).
  • Enjoy the songs....
    Hope it will be helpful...
    Aug 26, 2010 | RCA Audio Players & Recorders
    Can this camera become a webcam and how
    Yes, but only with the yellow (video) and white (mono audio) rca plug cable (to mini USB) that came with the camera. This plugs the camera into a composite input (yellow) found on older video cards, VHS recorders, DVD players and TVs. There is no software switch to tell the Lumix what to do when it's connected to a PC by the USB cable; it just assumes you want to transfer files. Unlike USB audio recorders (Zoom H4) which give you the choice at plug-in, audio interface or disk drive?
    Feb 01, 2010 | Panasonic Lumix DMC-FS5 Digital Camera
    Cant put musci on my RCA Pearl 512 MB Digital Audio Player - TH11
    You need to connect up USB cable and then go to Windows Media Player program and WMP will guide you on how to download music
    Sep 14, 2009 | RCA TH1101 MP3 Player
    RCA 5001
    use another USB connector and check clearly the USB connection is ok...
    Jun 17, 2009 | RCA M5001 Digital Media Player
    I am trying to connect an akai dvd player to directv, please help
    ruettab,
    good day. to connect your any DVD player to any TV screen always remember this color code
    from DVD back part:
    yellow = video out
    red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
    Black = digital audio ( rarely use unless)
    Red and white (in a row) = Audio output (left and right audio)
    where to connect from TV screen.
    Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
    Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
    RCA yellow marked cable = DVD yellow socket
    RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
    then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
    once decided which INPUT to connect the player.
    ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
    now connect the other end of RCA cable to the screen by following the same color code:
    RCA yellow cable = TV screen A/V1 input yellow socket
    RCA RED and White = TV screen A/V1 input red and white socket.
    cheers,
    mark
    Jan 31, 2009 | Akai DVD-3850S DVD Player
    Video Connections
    These are all the connectors on the back. The "1 x component video output" indicates that you can use the "3 color video cord" you have, better known as Component Video Cable.
    Connector Type: 1 x HDMI ( 19 pin HDMI Type A ) - rear ¦ 1 x component video output ( RCA phono x 3 ) - rear ¦ 1 x S-Video output ( 4 pin mini-DIN ) - rear ¦ 1 x composite video output ( RCA phono ) - rear ¦ 1 x audio line-out ( RCA phono x 2 ) - rear ¦ 1 x 5.1 channel audio line-out ( RCA phono x 6 ) - rear ¦ 1 x digital audio output (coaxial) ( RCA phono ) - rear ¦ 1 x digital audio output (optical) ( TOSLINK ) - rear ¦ 1 x network ( RJ-45 ) - rear ¦ 2 x USB - front
    May 16, 2008 | Toshiba HD-D1 DVD Player
    Lyra rd 1072 mp3 player rca
    The USB cable is the same as most digital cameras and other MP3 Players. It's just a standard USB mini cable
    Feb 21, 2008 | RCA Lyra RD1072 MP3 Player
    My mp3 does not connect to my computer
    Try this link - they have udated drivers for your player, which hopefully will solve the problem; http://www.rcaaudiovideo.com/en-US/Downloads.html?ProductID=RD1070 Try a different cable also, and check by plugging it into a usb port on another computer that the problem is not with your usb ports. Hope this helps :)
    Mar 22, 2007 | RCA Lyra RD1072 MP3 Player
    Surround cuts out???
    Are you useing a digital audio cable when its cutting on & off? How long between the on & off? I have the same problem when I use a digital audio cable or a coaxial audio cable from my DVD player. To use the surround (6 CH) feature you need to use the 6 channel RCA jacks and if what ever your hooking up dosent have the RCA outputs your out of luck. My DVD player does have the 6 channel outputs and they work but the digital cables won't work. What are you connecting to it? I think something is wrong with the digital circuit board in mine, I would like to replace it and see. Reading your manual will help understand the 6 channel RCA and fiber optic digital cables. I hope any of this helped.
    Mar 05, 2007 | RCA RT2280 System
    RCA H100 MP3 Player Logo
    Top RCA Audio Players & Recorders Experts
    Gyula Lacz
    Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
