Question about LG DLE2514 Electric Dryer
LG ELECTRIC DRYER
DRYER MAKES TUMBLING NOISE AS THE DRUM REVOLVES. THE NOISE IS VERY SIMILAR TO THE NOISE GENERATED WHEN DRYING A PAIR OF TENNIS SHOES. AS THE DRUM REVOLVES ONE COMPLETE REVOLUTION, IT MAKES ONE THUMPING NOISE.
YOUR HELP IS GREATLY APPRECIATED
  • 6 more comments
  • Anonymous Aug 26, 2008
    Look for cracks in the drum itself, mine has made that noise for a while and I just found that the drum is cracking more and more snagging my cloths in the mean time. This is a defect in the drum for sure.
  • daleec Apr 22, 2009
    I have the same issue with our LG DLE3777 dryer. It started thumping and continued to get worse with use. What I found was that the VERY thin metal drum started to crack in the welded seam in the very rear of the dryer drum. Mine is right behind one of the baffles and the crack is now a little over an inch (~3 cm) long. The raised section of the back of the drum is where 2 support rollers run. If I turn the drum by hand I can see the metal separate or flex at the crack when it goes over the bottom most roller in about the 6 o'clock position.
    Since my 3 year old dryer is still under extended warranty the repair shop has a new drum and rollers on order now. Don't know how long that will take, but this is looking like it may be a more common issue than it should be. That's just my personal thought which is free.
  • jmcfly007 May 23, 2009
    Thumping on each rotation. One rotation, one low thump. Drying clothes well and no other problems.
  • Anonymous May 24, 2009
    same thing...thanks for teh advice on this website.
  • Anonymous Mar 18, 2014
    The dryer was making a rattling noise. My husband removed the exhaust pipe which seemed to be the problem. However he spun the drum and the belt fell off in the back. How do we put it back on?
    When dryer is turned on and drum is spinning the dryer is making a rattling noise.
  • Anonymous Mar 29, 2014
    my dryer started out with making the thumping noise, then a squeaky noise, now the drum is moving slow.
  • Anonymous Apr 01, 2014
    the gas dyer dries our clothes fast, and works great except the drum keeps turning and does not shut off
  • 26 Answers
Henry, its going to be 1 of 2 things. Check inside your drum, see if the vent in the rear has burning or discoloration around it. If it does, it sounds as if your vent is restricted causing the unit to overheat, so clean/fix/replace the venting and your support pulleys will need to be repalce ie flat spots from overheat. If there is no scoarching marks and you know its not the vent or heat issue, the drum seam may have parted causing the thump as every revolution is made.
Posted on Apr 04, 2008
SOURCE:
What is making mywhirlpool/admiral electric dryer sound loud and thumping noise
You dryer belt may be shot and a piece of rubber is missing making it jump while working. Needs replacing before it completely quits. It will eventually just break apart.
Apr 13, 2015 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Kenmore dryer making a thumping noise
Your dryer has rolls on the drum and they are going bad and need to be replaced
Mar 22, 2014 | LG DLG3788W Gas Dryer
LG DLE 2514W DRYER MAKES RUMBLING NOISE WHILE RUNNING
Hi Willie Bolden
Sounds like your problem is drum rollers are in need of lubrication or replacement.
Go to the following webpage for a schematic of your dryer and parts.
Please take time to rate me
Bud
http://www.appliancepartspros.com/parts-for-lg-dle2514w-abweeus.html
Oct 11, 2012 | LG DLE2514 Electric Dryer
Very loud noise like tennis shoes drying
Check for a possible cracked weld in the seam of the stainless steel drum. Noise most likely is the crack passing over the front or rear rollers each revolution.
Mar 24, 2011 | LG DLE2515S Gas Dryer
My dryer (maytag atlantis) has started making a loud clunking noise with each revolution. its still drying fine but sounds terrible. any thoughts?
A loose belt will allow the drum to slip when clothes hit the paddles in the drum. It sometimes sounds like a pair of tennis shoes are in the dryer when it slips and is usually rythymic.
These machines also use drum rollers that can make a racket when they go bad.
http://www.repairclinic.com/Maytag-Dryer-Parts
Good luck.
Mar 02, 2011 | Maytag Dryers
This started recently, my dryer makes a loud noise while it's drying. It sounds like tennis shoes are in there drying.
There are usually 3 rollers that the drum rides on as it spins. Sounds like one or more of the rollers has worn out
Apr 03, 2010 | Dryers
Dryer drum stopped rotating, dryer blower continues to work.
The belt probably broke, and coincidentally happened while drying the shoes. The belt is easy to replace. Open the back and you'll probably see the belt laying on the bottom
Nov 10, 2009 | Bosch Axxis WTA 3510 Electric Dryer
LG DLE2512W Dryer says chech filter, starts, heats and turns but makes loud noise. Maybe something stuck? A sock?
Drying drum is not on its host. Lay down the dryer and then bolt it after aligning it.
Oct 07, 2009 | LG DLE2512W Electric Dryer
Maytag Neptune Dryer makes loud noise while drying.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ergfgfjk
Sep 06, 2009 | LG DLE2514 Electric Dryer
Noisy dryer
hi there,
the rattling and squeeling noise usually comes from the drum shocks. they do wear out due to use. i would recomend replacing them.
Oct 11, 2008 | Kenmore Dryers
LG DLE2514 Electric Dryer Logo
996 people viewed this question
Top LG Dryers Experts
jimorris77
John Tripp
John Tripp
Marvin
Marvin
Are you a LG Dryer Expert? Answer questions, earn points and help others
