Question about GoVideo DP8440 Portable DVD Player
Looking for powerpak
Could you please e-mail me as to where I can get a battery pak for DP8440? I have the Portable DVD with power pak but no battery pak for this. Looking for one and how much would it cost? Thank you in advance. Steve
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
Sorry but the only one i found was $129.99 and out of stock
Posted on Apr 05, 2008
How long does it take charge the sunpack 510 batt using the qbc-5
Sunpak uses different power sources on their high-power handle mount (a.k.a. hammerhead) flash guns. The most common is the battery basket that holds 4 or 6 AA or C batteries depending on the type of the unit. One can insert Nickel-Cadmium or Nickel-Metal-Hydride rechargeable batteries instead of the primary cells, this way reducing the "consumables" costs at the expense of the smaller number of flashes per battery set. (Actually, NiCd or NiMH cells would probably give smaller number of flashes compared with the alkaline cells, but the recycle time between the flashes can be shorter. The reason is that at charging the flash capacitor inside the flash current counts more than voltage. Sunpak sells Ni-Cd battery packs named CL-2 for their flashes that utilize 6 AA-cells, and CL-3 for their 622 series (4 C-cells). The charger for these is the QBC-5. It recharges the exhausted batteries in 3 hours. As a solution assuring the shortest duration between flashes Sunpak offered the Powerpak, a shoulder holster that held a dry (non-rechargeable) battery of 510V, it charged the flash capacitor directly, omitting the transistor inverter in the flash body. As such battery became obsolete, the Poverpak has been superseded with the NC510 and later the TR-II PAK, which utilizes 10 Ni-Cd rechargeable batteries as a power source, and a powerful (more capable than the one in the flash) transistor inverter. NC510 and TR-II PAK use the same connection to the flash and the same outlook as the original Powerpak but, being rechargeable, are more economical. QBC-5 also serves a charger for the NC510 and TR-II PAK. You may ask, how the same charger can be used for 4, 6 and 10 cell NiCd packs. Well, the charger is specially designed for that, although charging time differs at the different battery packs. The NC510 and the TR-II PAK needs 10 hours to be recharged, when exhausted. The best way to avoid damages (overcharging degrades NiCd and NiMH cells) is to check temperature of the batteries. Charging must be cut off if the battery becomes hotter than 45 ?C (115 ?F). If after 10 hours of charge the NC510 does not power (the otherwise working) flash, then it must be serviced. Replacing the batteries is an easy job that can be done at home, with some soldering skills; NiMH cells with solder tabs are available at many web-based supplyers. Don't solder the cells directly, heat damages them. Avoid touching parts inside, when the pack is turned on: electrocuting is fully possible. Better find a professional, if you are not familiar with the electronics.
Dec 27, 2014 | Sunpak Cameras
How long do i charge a sunpak nc 510 rechargeable using a QBC-5 CHARGER
Jan 08, 2014 | Sunpak Cameras
Will not turn on
Remove main battery and try again, if no! sub the ram out one at a time and test, if still no! the DC jack in the laptop is a common issue for no power. I recommend a professional to assess.
Mar 18, 2012 | Sony DVP-FX810 8 in. Portable DVD Player
Tolong saya pak saya lupa kata sandi e-mail dan kode keamanan saya... ini alamat email saya pak philar_mifz@yahoo.co.id tolong dikirim password yang baru ke account saya yang satu lagi...
tolong saya pak saya lupa kata sandi e-mail dan kode keamanan saya...
ini alamat email saya dazoelanterpal@yahoo.co.id
tolong dikirim password yang baru ke account saya yang satu lagi rizaldazoel@yahoo.co.id
May 12, 2011 | Yahoo Mail
Looking for a battery charger for a Model No. DP8440
Hello
You can get its battery charger from some standard electronic spare part shops. If it is not available, order the item to Ebay, by giving them the model number of the charger. they will send it to you at your doorstep. Payments can be done by PayPal. The charger will be guaranteed and fresh piece. OK.
Apr 05, 2011 | GoVideo DP8440 Portable DVD Player
Battery pak will not keep a charge.
Check on Radio Shack maybe there you find something
May 01, 2010 | Mintek MDP-1760 Portable DVD Player
Battery pack for model no. 8017/ curtis portable dvd/cd player
From Curtis' website: "Q: Where can I purchase a replacement DVD battery?
Replacement portable DVD batteries can be purchased for $30 from Curtis International Ltd. Please mail a certified check or money order (payable to Curtis International Ltd) to 315 Attwell Drive, Etobicoke, Ontario M9W 5C1, ATTN: Customer Service Department. Make sure to include your name, complete mailing address, phone number with area code, model number of your unit and part required. "
Weigh you options....a new portable DVD player can be bought for not much more.
Jun 23, 2009 | Curtis DVD8017 Portable DVD Player
Looking for a replacement adapter
Durabrand is a private label tradename of Wal-Mart.
Here is customer support page.
Here is contact page.
Contact them and ask the price for a battery.
Aug 28, 2008 | Durabrand PDV-705 Portable DVD Player
Need to locate a power supply for a durabrand portable dvd player
The following google search will give you numerous places to shop for portable dvd batteries. I was not able to locate a specific place because you did not include the model and serial number of the dvd player, but you can browse the places on the search and enter your model and serial number to find a battery compatible for your system. If you were looking for something specific please provide details as to what you were looking for and I will be more than happy to try and help you further.
If you do not mind, please rate my help, I really do appreciate it. Thanks
Jul 07, 2008 | Durabrand Televison & Video
GoVideo DP8440 Portable DVD Player Logo
62 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
