Question about Sceptre X37sv-Naga 37 in. LCD Television
Faulty Remote Can't get any operation with remote/new batteries to power on TV, any expierience with this?
  • sarahE Apr 19, 2008
    Same here- heading to radioshack for a universal replacement now.
Same thing happened to mine. I opened the remote and found that the springy wire that connects the negative (-) end of the AA batteries to the remote broke off. I soldered it back together and it works now. Soldering it back together was VERY tricky because the two ends were at a 45 degree angle to each other. It took a lot of patience and a steady hand.
Posted on Apr 26, 2008
6ya staff
SOURCE:
I have telefunken tv and whene i start it the picture come but it block i cant move anything i cant use the remote i cant even close the tv just if i Unplug the power pls helpe me
I'm not quite understanding what exactly you are saying. Do you mean,
You have a TV, and when you turn it on, you have pictures but, you can't scroll or operate/change channels, volumes etc. by using the remote but, in order to turn the TV off, you have to unplug the power cord.
1. Check the battery in the remote
2. If the battery is good in the remote then you might have a bad remote, buy new remote or replace it with a universal remote.
3. If either not a battery or remote, then it will be the control board inside the TV quit working and will need to be replaced. Depending on how expensive or age of the TV. By the time you invest fixing the board with labor, might runs you from $200 to $400 bucks, and you can buy a new TV from Walmart a 49" inch TV for $319 bucks.
Jul 30, 2018 | Televison & Video
I have a Philips LCD TV. The remote seems to have stopped working. The TV has power going to it, but I cannot control the volume or select the input with the remote. The controls on the side of the TV...
Take a camera phone and point the remote at the camera, then press a button that you know is working the Tv - you will see a white flash from the remote LED when the button is pressed. If you press a button on the remote that does not work the Tv and you get a white flash from the remote LED when looking at the remote - as if you are going to take a photo of it - then the remote is good and the Tv is faulty. Visa versa, if you don't get a white flash then the remote is faulty.
If the remote is no longer available, then pop it open with a flat screwdriver and wash the remote with a mild mixture of dish washing soap and water. Then let it dry out in the sun until completely dry and then reassemble to try again. I have repaired remote controls in this way for people :)
Jul 31, 2014 | Philips 42PFL3603D/F7 42-Inch 1920 x 1080p...
Why wont the tv power on?
Are you sure the remote control battery's are good.
First try new battery's and see if the remote control will operate.
Jun 09, 2014 | Televison & Video
Panasonic remote does not work
First check that the battery contacts on the unit are clean and can make a good contact with those batteries. If that doesn't solve the problem, maybe it's not the remote? VCR's have a remote sensor, these can and do go faulty. The only way to be certain is to buy a cheap universal remote. If that can switch it on the your Panasonic remote is faulty. If it can't the remote sensor is faulty.
May 25, 2013 | Panasonic N2QAYB000221 REMOTE CONTROL
Remote want work on tv
Make sure that you're using the supplied Remote (RMY-906) to control the TV. If so, perform the steps given below to resolve the issue.
  • Make sure that you're using batteries which are having enough charge. Try using fresh alkaline batteries.
  • Do not use rechargeable batteries in the Remote.
  • Ensure that the batteries are inserted correctly with the correct terminals by checking the + and - symbol in the battery compartment.
  • Make sure that the Remote is set to operate with the correct functions. On the remote control, press the TV FUNCTION button to re-check this.
  • Press the POWER button and other buttons to test the operation.
  • Make sure that none of the buttons are jammed in the remote control.
  • Ensure that the remote control is being used no closer than 3 feet and no further than 10 feet away from the unit. Try using the remote control at varying distances from the TV.
  • When using the remote control, be sure to point it directly at the remote sensor on the device.
  • Remove any obstacles that may be in the path between the remote control and the device.
  • Ensure the remote sensor of the device is not exposed to direct sunlight or bright florescent lights, as this can interfere with the sensors ability to receive signals from the remote control.
  • Try resetting the Remote. To reset the Remote. remove the batteries from the remote control, press every button twice, and then reinstall the batteries.
  • Try resetting the TV also to check the operation. To reset the TV, disconnect the power cord for a short period of time (approximately 1 minute), then reconnect the power cord and power on the television.
If the remote control is able to operate other devices (such as cable box, DVD Player or satellite receiver), then the issue may be with the IR sensor on the TV. If this is the case then the TV that will require service. Otherwise, the remote control may need replaced.
Good Luck!
KenSolutions
Nov 23, 2010 | Sony KP-61S75 TV
Set wont turn on from remote intermittently and occasionally turns itself off W70-2100
Does the TV turn off on it's own, or is the remote being pointed at the TV when it goes off - without you pressing the power button on the remote? If the TV goes off with the remote pointed at it (without you pressing the power button), it could be old batteries, or you need a new remote. Have you tried replacing the batteries in the remote? If it's not the batteries, have you got a universal remote lying around somewhere that you can program to operate the TV and try to operate the TV with it? If you determine that it's not the remote, it is probably something to do with the infrared remote sensor, or something faulty in the sensor's circuit board that controls the power switch. How old is the TV? If still under warranty, I would call the manufacturer and explain your problem. They will be able to assist you with any further questions you may have. The number for the manufacturer's Customer Service is located inside of the owner's manual. If you no loner have the manual, you can easily get the contact info via the manufacturer's website. Good luck, and I hope this helps...
Sep 10, 2008 | Televison & Video
Tv turning back on when turned off.
Thanks for helping me understand this problem. I've placed new batteries in the RC but, that don't help. It's the RC that came with the TV when I purchased it new.
[email protected]
Aug 12, 2008 | Televison & Video
Remote cotrol does not work except in close range.
Clean both red filter plastic windows, 1 at the remote control end and 1 at the tvs InfraRed receiver end, with window cleaner on a soft cloth. If this doesnt work you need to confirm operation with another working remote. Either the transmitter(remote) or receiver (tv) could be faulty.
Anything obstructing the IR path to the receiver located at the bottom edge of the tv bezel?
May 20, 2008 | Panasonic PV-C2061 20 in. TV/VCR Combo
Sceptre X37sv-Naga 37 in. LCD Television Logo
70 people viewed this question
Top Sceptre Televison & Video Experts
leeboy3909
Level 1 Expert
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
