Question about Toshiba Portege 2010 Notebook
The power cable light on my Toshiba Portege 2010 flashes yellow/orange when the plug is inserted. Computer will not turn on (green light on power button doesn't even come up). Have tried: 1) starting up computer without cable 2) holding power button down for 10 secs 3) taking the batteries out and putting them back in 4) starting the computer without batteries 5) starting computer without batteries and power cable.
  • uk_nemesis Apr 08, 2008
    Thanks for the speedy reply - i did not know it would be so fast!
    As per your first response:
    1) yes - the computer would not turn on both with or without the a/c adapter plugged in. However the flashing orange LED signalling that the cable is plugged in only occurred when the a/c adapter was plugged in
    2)LED stops flashing when the a/c adapter is removed
    3)yes i mean when the plugis inserted i mean that the a/c adapter is connected to the computer
    Last:
    I have just plugged the a/c adapter into the computer and the battery 1 LED is orange and the power cable LED is green - which usually signals that the computer is being charged. I will leave tihs on for 6 hours or so to see if it fully charges both batteries.
    Thanks.
  • B Joan Rapier
    B Joan Rapier May 11, 2010
    Hello uk_nemesis
    Do I understand you correctly that the symptoms are the same regardless of whether or not the A/C power adapter is connected to the computer?
    If that is the case, then, the core symptom is that the computer will not power up, yes?
    Are you ever able to get the LED to stop flashing (to turn off)?
    I'm not sure what you mean by "...when the plug is inserted..."?
    Do you mean when the A/C adapter is connected to the computer?
    Thank you for being so detailed (w/ your list of steps you've taken thus far). That's very helpful.
    If you could, please, answer the questions I've presented here, we can continue on w/ diagnosing the issue you're experiencing.
    Thank you
    BJ
    Sergeant:
  • 202 Answers
One thing could be that your A/C adapter has failed resulting in your battery not being charged. This would explain why you're experiencing the same symptoms w/ or w/out the A/C adapter.
Posted on Apr 05, 2008
  • B Joan Rapier
    B Joan Rapier Apr 08, 2008
    Thank you, uk_nemesis. So, do I understand you correctly? - The symptoms have changed? That is, now the system appears to be charging the batteries?
    If, in the end, your batteries don't get charged, I'd look into trying out a new A/C adapter. If there's a laptop repair facility in your area, I'm sure they'd connect a known working A/C adapter for you to see if the symptoms change.
    It could be that you have an intermittent connection either on the A/C adapter (where the cord meets the A/C to D/C converter (the "brick)) or at the computer.
    Please, do, post back and let us know how tonights charging goes.
    Thank you,
    BJ
Why is the power light on my Acer monitor flashing?
See this.. http://www.techsupportforum.com/forums/f25/acer-monitor-is-blank-and-power-light-flashing-green-318760.html
Also, here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 26, 2014 | Acer Computers & Internet
Why has my monitor turned orange. model dylm19r6 computer monitor
If you mean the light on your monitor is orange instead of green, it means the monitor is not receiving data from the computer.
Here's some tricks I would try...
Jul 14, 2014 | Soyo Computers & Internet
Glow plug indicator
Generally when you plug a network cable into a network port a yellow/orange light should come on to notify the user that a physical link/network has been made, there should also be a green light close to it that flashes when network traffic is flowing.
Sep 15, 2013 | Dell Computers & Internet
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
DC in light flashes orange
You need to test the AC Adapter For Correct Power Flow-Through... Use A Multimeter (available at any Home Improvement Store)
If That Tests Good.....
You Will Need To Test The DC Jack (the port where your Charger Cord Plugs Into On The Laptop.....)
If An Incorrect Adapter Was Used, You Might Have Shorted Out The Motherboard..
Dec 01, 2009 | Toshiba Computers & Internet
My toshiba portege M400 laptop will not start up, when I turn power on the power light starts blinking yellow and does nothing
This happened to me. The computer will not work with the battery in it.
Solution: Take battery out and plug in without battery... It should work,
You will need to get a new battery
Sep 19, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Help needed to get power connected.
There are a few possibilities.
If it's been plugged in continuously, the adapter may have simply overheated. Allowing it a few minutes to cool down without being plugged in could possibly fix it. Try unplugging the power cable from both the wall and the laptop for 30 minutes and give it another shot. This might work.
The other, less happy, possibility is that your adapter overheated to a critical point or was struck by an electrical surge and is damaged beyond repair. You can order a new one from a site like eBay or directly from Toshiba. Looks like you could get one from eBay for around 25$US incl. shipping but be careful and make sure you order the right thing.
Some eBay results: http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=ac+adapter+portege
Mar 13, 2008 | Computers & Internet
Toshiba Portege 2010 Notebook Logo
164 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
