Question about Maytag MAV6300 Top Load Washer
I heard lots of clicking, smelt a vague burning smell, then machine stopped
I heard lots of clicking noises and smelt a very faint burning smell; my machine continued to run for another ten minutes or so, then more clicking and it stopped completely (mid-cycle, too, so full of dirty water and clothes). I checked the power/fuse box - the problem isn't there. The machine is six years old. Should I call a repair-person or just buy a new machine?
    Novelist:
  • 184 Answers
IT SOUNDS LIKE A PROBLEM WITH THE MOTOR,WIRING, OR TIMER. SOMETIMES THE TIMER MOTOR WILL START CLICKING AFTER IT GETS SOME AGE ON IT. IT IS UNUSUAL FOR THAT TO CAUSE YOUR PROBLEM. THE SLIGHT BURNING SMELL COULD BE THE MOTOR. IT MIGHT HAVE TRIPPED THE OVERLOAD ON THE MOTOR FROM GETTING TOO HOT. AFTER IT HAS COOLED AWHILE, THE OVERLOAD SHOULD RESET ITSELF. YOU MAY WANT TO ADVANCE THE TIMER TO SPIN AND SEE IF IT WILL RUN NOW.
SOME RETAILERS OFFER NO CHARGE ON THE SERVICE CALL IF YOU END UP BUYING A NEW REPLACEMENT APPLIANCE FROM THEM. ASK AROUND.
IF YOU GET THAT DEAL, IT'S TO YOUR ADVANTAGE TO CALL FOR SERVICE. IF HE FIXES IT, YOU HAVE YOUR WASHER READY TO GO, IF NOT, AND YOU BUY A NEW ONE FROM THAT RETAILER, NO CHARGE FOR THE SERVICE CALL.
Posted on Apr 05, 2008
Burning smell no overheating stopped running
I would start looking at the wiring try to follow the smell it should at least get you real close.Could be a fusible link?
Mar 26, 2013 | 2002 Dodge Intrepid
Admiral washer model AW20N2V making a clicking sound...
call manufacturer. heard there was a recall... for dangers of fire.
Oct 02, 2012 | Admiral Washer Control Panel Frame 35-5733...
I have an F&P MW612 washing machine that stops at the start of the spin cycle leaving water in the machine. After pushing the pause button, looking inside, closing the lid and restarting I've heard...
Something may have been stuck in the drain pump impeller creating the clanking noise. This is a serious problem that can lead to the burning out of the motor controller module, the machine's "brain". It has been found that a short circuit is imminent on a leaky drain pump which can eventually burn out the motor controller module.
Empty the machine then lay it's front on a padded floor/surface and check the drain pump including the diverter valve where both the drain pump and the recirculation pump connect from. Replace the drain pump if damaged or leaking to avoid further damage to the motor controller module.
Fault Code Reading on Fisher and Paykel Top Load Washing Machines
Aug 23, 2011 | Washing Machines
Water will not drain humming noise
Humming sound could be jammed pump.Remove th filter and check pump Blades are free, nothing is stuck in it....
Nov 25, 2009 | Washing Machines
Smelt burning smell in the morning stopped cooling
I suspect the start relay burnt on the compressor. Now the compressor can not turn on. You need to repalce the relay.
Sep 04, 2009 | Kenmore 53542 / 53544 Side by Side...
My Kenmore washing machine had a faint burning smell.
i would let it sit for an hour. more than likley what happened was the motor overheated a little because it was trying to spin in an off balance situation. give it a break for a while the next load that you do keep an eye on it and see if you smell anything if you do then you have a problem. But 99% it is ok.
Jun 28, 2009 | Washing Machines
Stopped working, burning smell, clicking noise while plugged in.
have a technician check it out. burning smell is always fire hazzard. A connection may have gone loose or connections are soaked.
May 12, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Prima l080i
Magic smoke GONE!
Seriously, the main power supply has failed, and requires service. You are probably well past the warranty period, but check with the TV's service center - that information should be in the documents that came with the TV.
Jul 07, 2008 | Prima CV2011 TV
Washing machine stopped midcycle
It seems like the engine of the washing machine has burned out. If you are still in your warrenty period (and you used the machine conform operating instructions) you can contact the store you bought it from and ask for a replacement or repair. Otherwise you'll have to ask a repair man to come but these can be quite expensive.
Aug 08, 2007 | Maytag Performa PAV2200
Washing Machines Logo
220 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
