Question about Ricoh KR-5 SUPER II 35mm SLR Camera
My cameras advance lever will not spring back and allow the film to move to the next frame. How do i fix it?
    Problem Solver:
  • 13 Answers
Push the film release on the bottom of the camera and try to continue forward then. If you are trying to get 27 pictures on a 24 exp. roll you may have advanced your film so far that it is stuck on the piece of tape that attaches the film to the spool. Take only 24 pictures.
Posted on Aug 16, 2010
SOURCE:
I just bought a nice used Mamiya twin lens C3 but the shutter is locked up. There is a small metal piece holding the shutter release from moving. Not sure how to un-lock, seams to be a safety device of...
The vertical shutter sliding lever gets locked if the film doesn't get advanced to the next frame, and the mode selector is set for single exposure. You can't trip the shutter unless you have film in the camera and you forward the film to the next frame. That should allow you to release the shutter with the sliding lever.
Mar 17, 2014 | Mamiya Cameras
How do i get my advance lever to move it seems jammed
A Canon AE-1 is not an EOS camera the Canon "A" series is manual focus while EOS is auto focus. First thought In answer to the advance lever stuck or jammed I'm going to assume the camera is in serviceable condition and has not been subjected to water damage or harsh use. If we are dealing with just the advance lever then I'd say that you have over advanced the film at the last frame. I've done this myself after loading a 24 exposure and thinking I had a 36 exposure film. At the bottom of the camera there is a little pin which releases the advance lever and allows the user to rewind the film. Under normal conditions when it's time to rewind the film into the canister this pin offers little resistance to pushing in to release, however depending on how much force the advance lever has been subjected to increases the tension on this pin. Push the pin in and rewind the film.
Second thought is if you have film in the camera and it has not been used fully then it's possible that the film has already been advanced to a new frame and the shutter needs to be activated before the lever will become free and advance to the next frame.
Other problems with the Canon "A" series cameras is they have a tendency to dry out the lubrication and begin to squeak when the shutter is fired. This condition can eventually result is a shutter seizure and give the same advance lever condition.
Those are the three things that come to mind over this lever problem lets hope it's just run out of film.
Nov 20, 2010 | Canon EOS-AE-1 35mm SLR Camera
The frame counter is set on S, the film advance lever doesn't work anymore either. Is there anything I can do or should i take it to get fixed?
frame counter,mechanism is bad,before u get it fixed,try urself open the back door of the film chamber u will find a lever just below the number counter,move it freely ,push and leave, the put a dummy roll and move forward the film,if u get number counter working ok
Mar 05, 2010 | Vivitar V4000 50MM 35mm SLR Camera
Pro-S film back doesn't advance film properly.
There is good chance that the back needs a spring replaced. I've seen them fail many times.
Nov 14, 2009 | Mamiya RB67 Pro SD Medium Format Camera
My Mamiya RB67 triggers and shutter lease lever works but film advance lever doesn't move. Trigger button fired several times but film advance still showing 1.
This is not the best solution as it indicates a faulty film back. The film should advance without resorting to activating the film-wind release lever. That is only for intentionally advancing a partially exposed roll of film. Make sure the multi-exposure lever is not engaged and that the counter does advance and the red mark disappears as you advance to an unexposed frame.
Nov 09, 2009 | Mamiya RB67 Pro SD Medium Format Camera
Have a Canon AE-1 Program that I've received yesterday.. while taking it out for a shoot, a problem occured: Everytime I would Advance the lever to the next exposure it would take a photograph as if the...
Camera has a bad magnet, the A series were plagued by this.
Repairs will cost more than probably what it's worth.
The AE-1's used an electromagnet system to activate the shutter for a smoother press and less shake from the camera system.
I got lucky and recently purchased an AE-1 program that doesn't have this problem, it seems to be a hit and miss with these.
Oct 17, 2009 | Canon EOS-AE-1 35mm SLR Camera
Film Advance Lever and Shutter Curtain
If the film advance lever is "flopping" back and forth, the problem is most likely a jammed advance mechanism inside. The shutter is cocked *mechanically* and released the same way--no battery power is needed. One old trick you could try to release things is to push the rewind button on the bottom of the camera.*sometimes* it will free up the mechanism enough to unjam.
Sep 17, 2009 | Vivitar V3800N 35mm SLR Camera
Film advance lever wont move. Shutter button does not register.
the self timer may be the issue. the self timer if not all the way released will not allow you to advance to the next frame :( i sometimes have to push it back to the start position
Nov 13, 2008 | Photography
Film advance lever
Yes this is fairly common with K 1000 and the Spotmatics : although the shutter is cocked and hence you cannot advance film you cannot release shutter because mirror box is not cocked. Remedy : remove bottom cover and locate mirror box lever which protrudes slightely and is movable up and down and is spring loaded. Move upwards until it licks in position ( moving up against spring tension ). Now release the shutter and camera should let you advance the film .
Sep 17, 2007 | Pentax K1000 35mm SLR Camera
Ricoh KR-5 SUPER II 35mm SLR Camera Logo
349 people viewed this question
Top Ricoh Photography Experts
Marvin
Marvin
Harrie
Are you a Ricoh Photography Expert? Answer questions, earn points and help others
