Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore elite 106.54619300 Ice maker just stopped working
The ice maker just stopped working. So I took it out and there was just a little bit of ice in it. So I ran it under water and got the old cubes out. And now still nothing. Any ideas??
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
Sounds like the moter is burnt out and you need to replace ice maker try ebay
Posted on Apr 04, 2008
woodchuck789
  • 4070 Answers
SOURCE: Ice maker stoped working
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Posted on Sep 07, 2009
WCAnderson
  • 9 Answers
SOURCE: ICE CUBE MAKER SMELLY ICE CUBES
Unfortunately, this is one of the inherent problems with a self defrosting freezer units. Some frost free models/brands are less smelly than others. Grabbing the cubes as soon as they drop so they don't sit in that nasty freezer air and placing them in a zip lock would help a lot but probably not completely. Be sure and clean the inside of the freezer often so there is less of the smell left in the plastic that surrounds the ice cubes as well as the foods. Don't eat freezer burned vanilla ice cream, for sure! Hope this helps.
Posted on Oct 11, 2008
  • 172 Answers
SOURCE: Kenmore Refrigerator 106-9557612 Ice Maker won't Eject cubes
Hi caleycatz,
It sounds like you are in need of a motor module for your icemaker. This is the motor and gear that drives the icemaker prongs. The part number is
W10190935 The price is $77.59 and $6.00 shipping
I can have one of these at your door in 1-2 days, so let me know if you need one. We take Visa Mastercard and Discover. Or you can order from sears for the same price and wait 10 days.
Good luck to you and I really hope this will FixYa. Please take the time to rate me. Thanks
Mike Anerson (Owner)
Anderson Appliance Repair
(865)945-3808
Mca0824@aol.com
Posted on Oct 28, 2008
arikrom
  • 528 Answers
SOURCE: kenmore refrig model #106-56232400 ice maker
the ice maker unit prob' bad and if you sure it is on and the flag is not stoping it from runing you might need a new unit but there are other tests you can do before..
call me 843.789.4824
Im in Charleston S.C but will happy to help you
www.911servicetoday.com
Posted on Dec 30, 2009
woodchuck789
  • 4070 Answers
SOURCE: Ice maker dispenser is not
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing.You should hear the ice door open and the augur motor turning to turn the augur which pushes the ice out the door. If the augur doesn't turn Take all the ice out of the bin and try. perhaps the motor is too weak or the augur is locked up. Take the bin out and try to see if the motor will turn with no load. The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter when you try the dispenser. If you are, probably bad motor. If not ,dispenser switch or solenoid is not working.
There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Posted on Dec 01, 2010
Ice maker stopped making ice
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Dec 26, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Trio 795.77563600 Ice Maker Not Working
Try putting ice inside instead. if the machine gives you water then it's converting in reverse order.& still working. put the machine upright & youi'll get ice...
Jul 29, 2010 | Kenmore Refrigerators
Ice maker not working
heatman101
fdfdfs43
Apr 19, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Weird moaning noise from freezer compartment
I took out some ice from the icemaker and turned the temperature setting up a few notches (making the freezer a bit warmer). I'm not sure which of these tactics fixed it, but the noise stopped almost immediately!
Jan 06, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker won't stop making ice
it's time to replace the ice maker, it will not stop, the you can feel the small bar when it looks in to the of position.
Dec 10, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite, will not make ice, but it does dispeanse
Dear tnsmarchini
You said, Kenmore elite, ice maker in door...........................???What????????
And we need more detail than Ice maker in door.
What does your ice maker do?
Sep 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite refrigerator 795.775.62600
make sure the ice maker is turned on, push and hold the little round button on the front for 15 seconda and see if it starts up an cycles. Also check to make sure the fill tube isn't clogged to the ice maker and another thing to check is the water valve.
Sep 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
I have a kenmore coldspot side by side model # 106.53662300.
The ice maker red light is blinking and it has made very little ice in the last 24 hours. What do you think the problem is?
Jan 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
476 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
