Television cutting off
The timer light is flashing and attempts to turn on the unit,...it is clicking off immediately. Just not staying on. What can be the problem. Thanks Trini Jens
  • Anonymous Mar 05, 2009
    samsung
  • 149 Answers
Brand name and model please
Posted on Apr 05, 2008
SOURCE:
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
Carlton Microwave - C25MW09. Microwave unit stays on after timer has finished although light goes off and turntable stops rotating. Have to turn it on and off at the mains otherwise microwave unit would...
It is possible that the relay is staying latched to supply voltage to the magnetron even after the timer shuts down. This is dangerous and must be rectified.
You need to check the door switch and the lines from the program timer to switch the relay of the magnetron. It is possible that the timer is faulty and needs a check on the reason why it stays latched unless the power is cut. You can disconnect the magnetron to test but attempt ONLY if you are familiar with high voltage/ electrical circuits.
Jul 09, 2011 | Microwave Ovens
I hear the fan almost non stop while the tv is on.
You have a bad color wheel. The color wheel is located in front of the lamp, as the light shines through it as it spins. It is made up of different colored segments of glass, and one of the segments has came loose and causing the vibrating humming noise. The reason I know it isn't a fan is because the fans will continue to run for about 30 seconds after the set is powered off. The click you hear is the relay cutting off the fans. The color wheel cuts off as soon as you press the power button to cut the set off. I've replaced many of these at our shop for the same problem.
Jul 29, 2010 | Samsung HC-P4752W 47" Rear Projection...
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
Sony Trinitron won't turn on, Standby/Timer light now blinks 2x
your power unit maybe going bad
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 21, 2009 | Televison & Video
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
Akai pt4298hd rear proj tv
Unit may be in timer mode. Check menu settings
Apr 22, 2008 | Akai PT4298HD Rear Projection Television
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Televison & Video Logo
140 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
