We are having a problem printing. We cannot print. Every time we print. it says problem reading the printer.
    Guru:
  • 1,463 Answers
Hi you dont say which printer you have ?
can you post make model.
or you oculd try a fresh install of the printer ,
riz.
Posted on Apr 04, 2008
How to clean Genuine HP 564 Printhead
Printer heads can get clogged if the printers have not been used in awhile or a print cartridge has been empty or stored for a long time. Clogs in print heads can cause problems with the print job quality. This article will tell you how to clean print heads.
I share a link please visit and read it.
http://www.wikihow.com/Clean-Print-Heads
Thanks,
HP Printer Support
May 31, 2014 | HP Photosmart C6180 All-In-One InkJet...
I am getting an error telling me to replace all 4 print heads. I thought it was odd that all 4 would go out at the same time. Should i replace all 4 print heads or is the problem something else? Maybe
This is general problem in hp plotters..
understand the concept: If U R replaced any one of print head in good working printer, printer detects new print head & it will try to align it with others. Printer will print align page to read, while reading if its found any other print heads are poor quality or bad condition, it will say to replace them also.. Some times it may 2,3 or all.
If UR printer is trying to printing align page and reading it, definitely it will detects & displays the faulty /poor quality print heads. U have to replace it..
If UR feels its expensive, try to clean the print heads manually & try for UR luck...
Trailing cable error is 11:11...
Mar 24, 2014 | HP DesignJet 500 InkJet Printer
Manteinance program run automatically every time i try to print something
Its not maintenance programme, its print head alignment page.Once print heads are aligned successfully, you wont get this page.
Reason: One or more print head nozzles are not firing/blocked/dried up the align page will not prints properly to read result printer unable to align P.heads. You can observe the print quality, based on that replace/clean the particular print head(s) and check. Verify that each line it will read & marked as a "right tick". If its marks like "X" ensure that align page not successful.
If you are confused better replace all(four) print heads, to get out of this issue peacefully.But ensure that before replacing the print heads,all cartridge ink level should be more then 50%.
Nov 28, 2012 | HP DesignJet 110 Plus NR InkJet Printer
Letter outline printing detail
your copier not set paper size.Paper seize is miss mach so several times print same print
Jul 13, 2012 | Canon imageRUNNER C6800 Copier
How to duplex print with 895cxi
This model printer does not have a duplex unit and cannot print double sided documents automatically.
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Jul 08, 2012 | HP DeskJet 895cxi InkJet Printer
Printer not printing out properly, can not read it.
Go to the maintenance menu and do a "nozzle cleaning or deep cleaning". Do a print test until the gaps dissappears. This a common problem of inkjet printers especially when left out of use for quite a time.
Aug 03, 2009 | Office Equipment & Supplies
E-mails print too small to read. New printer does same
Try placing you cursor on the text that you would like to print, hold the control key down then tap the PLUS key on the numerical pad a few times.
This should make your fonts larger so that they may print normally.
Jun 20, 2009 | HP Photosmart C7280 Printer
Hp psc 2210 all-in-one printer is busy
I replaced the black ink cartridge and my printer keeps saying press enter to
align cartridges. I have done this a dozen times using up paper and ink and it
still says pres enter to align cartridges.
Jan 18, 2008 | HP PSC 2210 All-In-One InkJet Printer
Font size problem when printing documents
Font sizes are a program thing nothing to do with the printer
 Examine your E-mail client set up in the read section[Different E-mail programs different setting ] probably under a heading
Tools/Options and look at how the font sizes are organized.
Oct 11, 2007 | HP PSC 2210 All-In-One InkJet Printer
59 people viewed this question
jasbo
jasbo
