Question about Kenmore 24432 Top Load Washer
Washer does not advance to the spin cycle
Washer fills for the rinse and does not drain afterwards. Have to advance the knob to get it to complete the cycle.
    Novelist:
  • 184 Answers
IF THE TIMER STALLS COMPLETELY AND WILL SIT IN THE SAME POSITION FOR EVER IF YOU DO NOTHING TO IT, THE TIMER IS BAD.
Posted on Apr 05, 2008
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
The washing machinge is not completing the complete cycle
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not advance in the rinse cycle,water just runs continuely.
check the drain hose it should be only 6 to 8 inch in your drain line if drain hose is all the way in the drain line correct it and you will be fine.
May 21, 2009 | Washing Machines
Washer will not complete cycle
washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Washer won't advance from cycle to cycle
    * It's the timer, if your washing machine fills with water and begins agitating, but the timer never
    the timer.
    * It may be a cold-water supply problem, if the washing machine fills with water, agitates,
    Nov 16, 2008 | Danby DDW1805W Designer Series...
    Won,t drain on rinse cycle
    There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
    Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
    Kenmore 24432 Top Load Washer Logo
    53 people viewed this question
    Sal De
    fordexpert
    Robert Rankin
