Question about Nokia 6133 Cellular Phone
Nokia 6133 white screen
Hi, yesterday wheni wanted to text someone my phone was off. i restarted it and it turned white for like 20 minutes, after that it turned off again. since then it does the same thing over and over. I did all the basic stuff, but your way of resetting doesnt work. Am i supposed to get sim out, then put sim in + battery. then turn it on while pressing *3send?
thanks in advance!
  • skipnyip Apr 10, 2008
    I'm having the same problem. I tried holding down *3send with the sim card out and pushing the power on. I get a message"start without sim card?". Do I also hold down the power button? How long should I hold the buttons?
    Thanks for your help!
  • gipy May 20, 2008
    same problem here it just turned off and when i turned it back on it was just white. i could still put numbers in but they wouldn't call out, it would just freeze up.
    Brigadier General:
  • 7,752 Answers
You need to change the LCD or flexcable.
Posted on May 28, 2008
How to format nokia 6133
hi,
  1. Power on the Nokia 6133. Turn the Nokia 6133 on and allow it to load the home screen.
  2. Navigate to options. Press the "Menu" key on the Nokia 6133. Select "Options" and press "OK".
  3. Select the memory card folder. Highlight the memory card folder. Press "OK".
  4. Select options. Select "Options". Highlight "Format memory card".
  5. Confirm the format. When prompted, select "Yes". Wait patiently while the Nokia 6133 formats the memory card.
  6. Enter a name. When the Nokia 6133 is finished formatting the memory card it will ask you for a name. Enter a name into the Nokia 6133 for the memory card. The Nokia 6133 allows the name to be up to eleven characters and numbers.
Aug 02, 2010 | Nokia 6133 Cellular Phone
Remove images onto microSD
You can change display of your phone & fix this problem Permanetly.
Remove memry card from phone, Connect it to another phone & copy your photos to your PC.
Thanks.
Sep 22, 2009 | Nokia 6133 Cellular Phone
Same here.
well all you need to do is find your nearest cell phone tech and have your cell phone flashed its sure to work
Jun 15, 2009 | Nokia 6133 Cellular Phone
Can't change my message center number, I can't send text messages
Hi Friend,
Note down the below steps to set the meessage center no in your mobile
Go to message menu----->message settings----->text messages------->message centre-------->enter message centre name and number
Kindly Check it and revert back
regards,
Ayyasam
Jun 01, 2009 | Nokia 6133 Cellular Phone
It turns on but a blank white screen only shows
i had the same issue when my phone got slightly wet. try taking everything apart (sim card, battery, back). let them dry out for a little bit then after like a day or two put the phone back together. turn it on it will be a white screen for a little bit but give it like 2 or 3 mins and if should come back. I did this for my phone cuz i really needed the pictures off it and it worked! hopefully if will work for you too. GOOD LUCK!
Jul 16, 2008 | Nokia 6133 Cellular Phone
Hey
Please change display
Jul 06, 2008 | Nokia 6133 Cellular Phone
Picture messages
Go to Menu>Settings>Restore factory settings
Jun 22, 2008 | Nokia 6133 Cellular Phone
LCD Screen
if ur screen remains white or gets white than it could be display connectivity cables fault or if it is broken than it is the displays fault and it can be repaired at Nokia Care
May 23, 2008 | Nokia 6133 Cellular Phone
Almost-blank screen -- no icons, nothing
First turn it OFF, take the SIM card out.
Press * 3 send at the same time and turn phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Dec 19, 2007 | Nokia 6133 Cellular Phone
Nokia 6133 Cellular Phone Logo
186 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
