Question about Mitsubishi Televison & Video
How do I clean the mirrors on a Mitsubishi big screen TV, Model #VS50605
  • c_bonnefil Apr 13, 2009
    i have VS-6055 mitsubishi
You have to pull the staples on the back
Posted on Jul 25, 2008
SOURCE:
I have a mitsubishi dlp tv model wd60735 the picture is not bright any longer any suggestions
I think you have one of the models that have two mirrors inside: not Mitsubishi's best idea.
Most have just the large mirror in the back but I think this model has a very small mirror at the bottom (odd shape about 4x6 inches) behind the front screen which faces upwards and gets dirty from the fans inside the set.
It is amazing how much it can dim the picture; Caution, if yours has it the only way to get at it is to remove the entire front screen assembly---a phone call to Mitsubishi will confirm if your model has the two mirrors----the big one never needs cleaning(almost never and is special).
If you find your model has two mirrors either consider having a pro come out and do it (15 min job) or You Tube it to see if instructions there.
look before you leap as this is usually a two person job.
If you have questions let me know.
I have seen this before in these sets
SD TECH
May 14, 2011 | Mitsubishi Televison & Video
PICTURE HAS BECOME VERY DARK AND DIM ON THE SCREEN
SD TECH
May 11, 2011 | Mitsubishi WD-62725 62" Rear Projection...
The bottom of the screen has transparent green blotches
This model has a geometry mirror that is lies in the front of the cabinet. It is dirty and needs cleaned. Remove the middle front plastic cover, between the screen frame and speaker cover. Remover the screen frame, disconnecting the harness (4 screws are behing that middle cover ;). Clean the mirror and reassemble. Wipe the lens while you are in there and do not touch the big mirror... you'll really have a mess if you do. Also, use caution not to put pressure on that little mirror as you clean it, you'll mess up the geometry and end up with a trapezoidal picture.
Mar 13, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mirror on Mitsubishi DLP HDTV 60" model # 60735 dirty looks like black blade of grass on main screen how do i clean the mirror
Hello zero_x08, 1) remove the cover of the TV and find the light engine. 2) using canned air blow dust from the mirro assembly 3) test the screen by turning the TV on after the system has warmed back to room tempurature. This should clean the mirror Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 11, 2009 | Mitsubishi WD-60735 Projection Television
Bugs in my tv
YES!
remove the top back panal screws (be carefull the mirror is connected to the panal! do not drop!) now wipe off and clean the three glass lenses inside..also wile your in there clean the inside of screen and the back panal mirror You will see a big improvment in picture!!
Please rate this response and help keep this area free!
Jan 22, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Cobwebs behind the screen of a Mitisubishi WT-55809
Wile your in there you might as well clean the mirror and the lenses *and you will see a big change in your picture!
Remove screws from upper back of tv to access this area ..be carefull with the back the mirror is connected to it!Please rate this answer
Thank You!
Jan 15, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi VS50605 rear projection TV won't come on
The power supply caps in the light engine power supply were faulty when they were installed. You need to remove the power supply and take it to your local electronics shop where they can remove the (7) faulty 1000uf 16v electrolytic capacitors and insert new ones. If you remove the power supply yourself (takes only a philips screwdriver) and reinstall it yourself, the electronics shop shouldn't charge you for more than an hour worth of time. The caps would be about $10.
Here's a photograph (thanks Don Crawford).
Nov 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
My Mits-Projection TV model WD-52825/WD-62825
Good Day, jmkay;
I see no reason why you can't do this yourself, but unlike the pioneer you have to approach the Mit's from the back and will have to remove the back from the screen (sort of)....charge you battery and Good Luck, big IRISH.
Aug 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi tv parts
This mirror Mitsubishi part# 767D055020 is no longer available from them but JVC has one that will work- Andrews Electronics = $101.72
Sep 21, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Televison & Video Logo
564 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
