That pump is likely to be a hot water return pump not a booster pump. it sound like a large property so its likely the hot water system requires balancing to get the hot water to the extreme areas. If all the hot outlets have some form of isolation valve try closing all but the affected areas and see if hot water comes out. If so only open the closed outlets enough to give you reasonable flow. This hopefully will force the hot water to the affected areas.
