Question about Pioneer PRO-200 60" Rear Projection Television
Convergnce red seem out of wack when I set the points tv does not offer to set red points
  • 2 more comments
  • ColumbiaD Apr 05, 2008
    I have the same problem. I can't align the colors. Where can I get parts and instructions?
  • dgrimes Jul 04, 2008
    I have the same problem with my pro-200 the red is out of wack and not see red on convergnce to correct problem
  • ldschutjer Dec 18, 2008
    red & green curve at bottom of screen
  • John Heitz May 11, 2010
    Please send Me the link where I can find repair parts/instructions. I really miss My Pro-118. Thanks, john.
  • Pioneer Master
  • 8,617 Answers
Your convergence ICs need to be replaced very easy and inexspensive repair. I can post a link where you can get replacement ICs and free installation instruction with pictures so you can do the repair yourself.Let me know if you would like the link.
Posted on Apr 04, 2008
My vizio vp50 hdtv10a changes differant colors when it turns on, can i fix it myself? what is the problem
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergnce select that and wait a minute the TV will adjust itself and give you a clear picture. If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the curser (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It taked time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture. You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synch.
Take care in solving the problem...
Aug 22, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
We have 52 inche akai and it shows double inmage
This problems is known as a convergnce problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergnce board,must be replaced to solved the tv covergence board.To solved the tv picture convergence problems.Try website like Tvrepairworld.com to buy a whole rebuild convergence board to replaced.The Akai/Samsung tv used the same convergence board.
Sep 15, 2010 | Akai PT5492S 54" Rear Projection...
We have an 80's hitachi mts 52" tv/ monitor and it has a 3d effect how do we fix this?
Tv have a problem known as convergence problems,it dead.Tv R,G,B colors lines mis alignment,Colors shadows or 3d pictures effect.The tv convergnce board is dead.The tv convergence board,require replacing 2 STK convergnce ICS and some or all it resistors.To solved tv convergence board,to solved tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Sep 11, 2010 | Hitachi 53UWX10B 53" Rear Projection...
The color on my tv is out of wack. It seems to have happened all of a sudden. mostly green, and no red.
if ur using the hd input make sure the cables are not loose also try deferent input , if the problen still there than u have a bad optical block
Aug 25, 2010 | Panasonic PT-61DLX75 61" HDTV
Ive got a samsung LE32A457CID tv every now and then whilst watching a progamme all the people green, wot can this be ???
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the cursor (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It taked time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
it is very easy just tedious and time consuming. If you have the auto convergence than your golden because this is the easiest way to "reset" the TV.
Good luck and if you still have the owners manual, You should read up on the convergence section in the manual.
Jun 14, 2010 | Samsung Televison & Video
Magnavox 51MP392H Rear Projection Television convergence problems
You need to try to adjust it with the original remote in the TECH mode---you can save the adjustments there--
With the set on a video input with nothing connected:
hit the following buttons: 0 6 2 5 9 7 STATUS
The menu should appear with choices---green(do not adjust green) red to green, blue to green etc.
On that initial menu will be a item that says store or save. Depending on the remote you have once you select red to green (cursor on remote) a grid of lines should come up---on screen will be instruction--menu to adjust and or status to navigate.
When you have the red--to green adjusted hit the status button until it takes you back to the menu where Store or save is listed and right cursor on it.
This will store the adjustments.
Go back by selecting blue to green and adjust that also and when done go back and save it.
Turn the set off to exit the service mode and see what you have---IF THE SET DOES NOT RETAIN these adjustments made in the Tech menu something is wrong with its DCU--digital convergence unit---that stores the adjustments.
Let me know if you have questions as I am here to help people.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 17, 2009 | Philips Magnavox 51MP392H Rear Projection...
Big screen TV corners of tv blue and red
I HAVE A 57" TOSHIBA REAR PROJECTION TV. HALF THE SCREEN HAS A BLUE TINT AND THE OTHER HALF IS CLEAR.
Jan 19, 2009 | Televison & Video
Convergence issues
Is the symptom the same on ac format? If so you may have to do an alignment. Also when the convergnce seems off if you go back to the convergence adjustmen is it off there aswell? If so you may just need to reflow thesolder on the convergence Ics.
Jan 02, 2009 | Mitsubishi WT-46805 46" Rear Projection...
C Color is way outta wack on my 56 inch pilips rear proj tv. HELP
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 28, 2007 | Philips 60PP9352 60" Rear Projection...
Strips of color coming up from bottom of tv
youll need to replace the stk ics inside the tv. they are easilly found by looking for two larg heat sinks. im pretty sure sony runs stk392-510. you will have to look at the ics to verify.
Apr 16, 2007 | Sony KP-53S75 53" Rear Projection...
Pioneer PRO-200 60" Rear Projection Television Logo
90 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
