Black line down the middle of plasma tv screen. After it warms up the line disappears.
    Problem Solver:
  • 5 Answers
It sounds like a possible bad connection on the upper or lower drive board.
You could disconnect power, remove back cover (carefully it will have sharp edges) and disconnect the ribbon from the plasma panel to the circuit boards on the top or bottom of the panel.
these ribbons are held down with a lock type conector of different types. Inspect carefully before unlocking connector, once unlocked and ribbon is removed look for any damage to the contacts then reinsert ribbon and lock connector.
If this doesn't work then you will either need to replace to drive board or the plasma panel
Posted on Apr 04, 2008
I have a 10 year old Pioneer plasma TV (Pioneer PDP-R05E). When the TV is turned on, it starts with a black screen, and then some reddish dots flashing on the screen, mostly on the corners. After...
10 years on a plasma is pretty good. If you are losing the plasma screen, then it will not be worth the time/cost to replace. LCD TV's have come down (and the new 4K format is here) considerably, are less energy hogs and last longer than the Plasma (this can be debated on longevity but LCD technology has been around a long time and is more prevelant than plasma). Time to upgrade.
it could either be the screen (my bet) or the controller board for the screen. Either way, the cost to truck a repairman out there, diagnose, order the part and return could exceed what a new format LCD will run you.
Nov 24, 2014 | Pioneer Televison & Video
Black line Down middle of 50" plasma screen tv
The tv T-CON board it is dying to causes this problems.This T-CON board sit in the middle at the bottom of the tv plasma screen panel.Try website like Ebay.com to buy a whloe new refurbish T-CON board for the replacement.
Jul 18, 2011 | Samsung 50 in. Plasma TV
LG 50' Flat Screen TV; Black Line down the middle of screen, TV is about 4yrs old.
A black line down the middle of the TV can be a few things. You plasma panel might be bad your buffer on that location of the screen might be bad or your logic board might be bad. Teh only way to find out is by replacing the parts , You can get parts at www.interliquidparts.com
Jun 08, 2011 | LG Televison & Video
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
Black line in middle of 42'' plasma screen
It could be one of buffer was defective. Get it repair does not cost so much $$$.
Aug 18, 2009 | Televison & Video
Black line down screen
hello, your tv has either the lower or the upper buffer defective, worst case scenario is the screen but only a tech with the skills can determine wich one is bad.
good luck
caypianan@yahoo.com
May 20, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Vertical lines down center of Plasma TV
Because of the complexity of these sets, the fault can be much more than just a bad IC. These sets are serviced at the board level. After changing the board, calibration is done as necessary.
The fault may be in the matrix power driver output area, or in the plasma screen back-plane layer itself. This has to be determined by the process of elimination.
I can tell you in advance that this will not be a low cost repair.
Jerry G.
Jan 10, 2009 | Philips Magnavox 42MF521D/37 Television
Sky PDS4250 42'' Plasma TV - Black line down centre of screen
not sure if this is the fix or not ...but i was tryin to fix a problem with my tv(not the same as yours)...but in the menu under adanced you can split the screen ....when i do that it puts a blue line down the middle of the screen
Dec 04, 2008 | Protron PLTV-4250 42 in. LCD Television
Black line in middle of panasonic plasma screen
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Oct 13, 2008 | Panasonic TH-50PV30 50 in. Plasma...
42HDS69 42 in. Plasma has several thin green vertical lines in middle of screen
If the set is still in warranty, call for warranty service. If not and you feel comfortable working on the set, carefully open up the back and reseat all of hte cables and connectors. This can be caused by marginal connections inside the set.
Keep us posted on your progress and results.
Dan
Aug 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
