Our tv has two inputs not three. The player has three outputs. The tv has one for audio and one for video. We are unable to get the philips to function under these circumstances. ps we have three different tvs, puchased at different times and all are different makes. None have three inputs. Please advise if there is converter of some kind, otherwise we have to return the philips dvd/video player model #dvp3340v/17.HELP!!!
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
Ok i am guessing that you are referring to RCA type hookup, if so there are 2 different types - yellow/white/red and red/green/blue no your TV probably has 1 yellow and 1 red or white if this is the case then make sure that you match up the yellow with yellow and then for the red and white these are for sound and you can buy a conversion cable at wal-mart for under $5 just make shure that it is 2 female RCA to 1 male RCA then plug both the red and white into the female sides and the 1 male into the one on the TV - now the channel that this input will show up as will most likely be AV1 or AV2 not a normal channel like the VCR did with channel 3
if you tell me the brand and model # on TV i will look it up for you and give you a more detailed description
Posted on Apr 05, 2008
How to connect Magnavox TV Model CH 3930 AL O2 to VHS player?
Actually, what you want to do is connect the VHS player to your TV. Your VHS player has three output leads: R. audio (red), L. audio (white), and video (yellow). These connect to corresponding inputs on the rear of your TV. Select VCR as the input source to your TV.
Mar 27, 2017 | Magnavox Televison & Video
Philips slc4
Check to make sure your Video and Audio are plugged into the same source input on your TV and the Output on your DVD player. (Ex. Audio/Video input 1) You could have your audio on 1 and your video on 2
Sep 01, 2014 | Televison & Video
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
I want to connect my philips home theater to samsung tv so how do i connect plz guide i hv three colour ep pin
Hi, to hook up a Tv to an home theater they are all the same process.
Instruction:
Make sure your playback devices are properly connected to your receiver. Whatever playback devices you use, make sure they are plugged into the appropriate inputs on your receiver. DVD and Blu-ray players, satellite boxes and cable boxes should all be plugged into video inputs, and CD players should be plugged into audio inputs. Your receiver will have labels on the back panel indicating into which input you should plug your devices.
Connect the video out to your TV's video input. Make sure you use the correct cable to make the connection. For newer receivers, the connection will likely be either HDMI or component. If your receiver has an HDMI output, use an HDMI cable to connect the receiver to the HDMI input on your TV. If your receiver uses a component output, use a component cable to connect your receiver to the component input on your TV.
Connect the audio output of your TV to one of the audio inputs on your receiver if you want to output your television's audio through your home theatre system. Most recent TVs will either use an optical cable or a digital coaxial cable to connect to the receiver, allowing you 5.1 channel surround from your television. If you have an older set, you will likely have to use standard RCA cables.
Turn on your receiver and press the "Setup/Menu" button on your receiver's remote. When "Input" appears on the display, press the right arrow key on your remote to select TV from the list.
After selecting TV, press the up or down arrow keys on your remote to select the audio input jack into which you have plugged your TV's audio cable. Press the "Exit" button on your remote to exit the setup menu and lock in the settings.
Tips & Warnings
Make sure you plug everything into the correct jacks or you will spend unnecessary time trying to troubleshoot why you don't have picture or sound.
Feb 17, 2011 | Audio Players & Recorders
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
How to connect a dvd player to lcd tv
Your DVD player's output is Composite Video (the yellow connector) plus stereo audio (the red and white connectors, for right and left audio)
The inputs on your TV are for Component Video, which splits the video signal into three cables (Y for brightness, Pb and Pr for blue and red, respectively)
Check your TV to see if it has a composite input (single yellow connector, labeled "video" or "composite")
And be sure to let me know if this helps!
Oct 24, 2009 | Televison & Video
Cant hook dvd/vcr to my cable box the manual says I need a extern
The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Setting up mintek 100 dvd player to cable box to tv
Newer TVs have multiple inputs. Mr Mark is correct, you generally do not daisy-chain Audio/Video units unless you are using a recording device. Cable box to Cable input on TV. DVD player to other inputs.
Let's get some terminology out of the way. Specifically for the Mintek DVD-1600. There are NO inputs.
Coaxial Audio out (orange) is for digital audio only. Usually connects to stereo reciever for Dolby 5.1 surround sound. Not for TV.
S-Video (black w/4 small holes, 1 square) is for better quality video than composite. Use this to TV instead of Composite if you have a S-Video input on your TV.
Composite (Yellow) Older video input type. Works just fine. Connect to TV.
Audio Output ( Red & White) for analog stereo only. Goes to TV. Red=right, White=left channels.
Component Video Out (Blue, Green White) is the newest video output type in this unit. Better than S-Video. Use this option if available on your TV instead of S-Video or component.
Feb 13, 2009 | Mintek DVD-1600 DVD Player
Tv connection
connect the composite video output of the player to the composite video input of your TV. The jack should be marked in yellow. Then connect your Audio input of the tv to the Audio out of the player.
Oct 09, 2007 | Philips PET710 Portable DVD Player
Televison & Video Logo
Top Televison & Video Experts
