Question about Casio Exilim EX-S600 Digital Camera
The card is locked... - Casio Exilim EX-S600 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Jan 17, 2013
  • kakima Jan 17, 2013
SOURCE:
My VPC-E760 keeps saying card is locked but the sd card is not locked
For the card locked, make sure that you are using a 2GB or smaller card. The E760 can not use 4GB or larger SDHC cards. 2GB cards can still be purchased on Amazon if your local store no longer carries them. If you are using 2GB, then here are some more tips for card locked.
For the "lens error", see this article for tips and steps that might help you repair it.
Apr 11, 2012 | Sanyo VPC-E760 Digital Camera
Tip
Memory Card Locked / write protected error.
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Memory card write protected, memory card locked, memory card will not read, can't use memory card.
on Jan 10, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
The memory was lock. but i want to unlock it
id1102_e3sdhc.gifSOLUTION 1 - Unlock the memory card.
NOTE: If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
Dec 30, 2010 | SanDisk 4GB microSD High Capacity Memory...
How do you unlock camera card it says card locked
Hi. Remove the card. On the side of the card is a small sliding lock. That's it. J.
Jul 12, 2010 | HP Cameras
Cannon IXUS 40.Saying, Card Locked.How do you unlock it?
In case it uses the SD card, then there is a lock feature in the card. You will need to unlock the card so that it becomes read/write enabled. In lock position, it is read only, so you can read the files from it but cannot create any more files.
Most SD cards have a switch on the edge of one side of the card. Sliding it up or down will unlock or lock the card. When the card is locked, you will not be able to transfer any audio tracks. Nor will you be able to play any copy protected files. We recommend you always keep the card unlocked.
sd%20card%20lock%20slider.jpgNOTE: We have found that on some cards, if the slider is even halfway towards the lock position, the card will be locked. Make sure that the slider is all the way to the UN-locked position.
Nov 24, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Whenever take picture 'memory card locked' message on the display
Nov 19, 2009 | Samsung L200 Digital Camera
Memory card locked
I had the same problem - just put the lock button of the card to the lock position and than again to the unlock position
Jul 06, 2008 | Canon PowerShot A450 Digital Camera
Memory card locked
Take the card out. On the left side of the card is a tiny white switch. Reverse the position.
Jul 04, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
CARD LOCKED
try puting the lock thing onto Lock. it worked for me
Apr 16, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Memory card locked
I noticed that this camera does not work well with cheaper memory cards. The only brand that works without fail is the SanDisk brand.
Jan 04, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Casio Exilim EX-S600 Digital Camera Logo
14 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
