Question about Gaggenau GI936-760 Dishwasher
New door panel installation
I've had my 936-760 since late 1999 and a after a remodel I now want a door panel that matches the rest of the cabinets. The installation manuel is long gone. Gaggenau sent us some screws and attachment pieces for $40 (!!!) but no template or instructions. Can you help?
    Champion:
  • 246 Answers
Try www.applianceart.com - not sure if they can help but may point you in the right direction
Posted on Sep 22, 2010
The belt attached to the blower wheel on my Whirlpool Cabrio dryer has come off. How do I reattach it?
Unplug the power cord of the Whirlpool dryer from the electrical outlet before installing a new belt. Remove the lint filter from underneath the lint filter cover. 2 Unfasten the screws underneath the lint filter cover with a screwdriver, setting the screws in a safe place. Slide a putty knife between the dryer top and the cabinet near the front, lifting up on the knife to detach the top from the plastic clips on the cabinet.3 Flip the dryer top back against the wall so it is resting on the rear hinges. Locate the screws on the inside of the upper front panel near the top.4 Unfasten the screws on the inside of the upper front panel with a screwdriver. Lift the panel up off the metal clips on the front of the dryer cabinet. 5 Unplug the door switch connector from the back of the upper front panel by hand, setting the panel out of the way. Slide the putty knife between the lower front panel and the dryer cabinet, pulling the knife away from the cabinet to detach the panel from the plastic clips on the cabinet.6 Place a couple of wood blocks under the lip of the dryer drum to hold it in place. Locate the idler arm near the motor at the base of the dryer.7 Move the idler arm forward to relieve the tension on the belt. Take the belt off the motor and idler arm pulleys, lifting the drum up and sliding the belt off the drum.8 Install a new belt around the dryer drum, looping it over the idler arm and around the motor pulley. Move the idler arm back into position to add tension to the new belt.9 Remove the wood blocks from underneath the lip of the dryer drum. Plug the door switch connector into the back of the upper front panel by hand.10 Slide the upper front panel over the metal clips on the front of the dryer cabinet, securing the top of the panel with screws. Fasten the lower front panel to the front of the dryer cabinet, pressing the panel onto the plastic clips by hand.11 Flip the dryer top back down onto the top of the cabinet, pressing down to secure the top to the plastic clips on the cabinet. Fasten the screws underneath the lint filter cover with a screwdriver.12 Slide the lint filter back under the lint filter cover by hand. Plug the power cord of the Whirlpool dryer into the electrical outlet.
  • Oct 11, 2011 | Whirlpool Dryers
    My dryer starts to squek real loud when it is running
    The source of this noise is usualy the dryer drum drive belt.
  • Unplug the electrical cord before replacing the dryer belt.
  • 2
    Pull open the dryer door and locate the screws underneath the top lip that secure the top of the dryer.
  • 3
    Unfasten the screws holding the top on with a screwdriver and lift the top, flipping it back and resting it on the hinges.
  • 4
    Unfasten the holding the front panel on the cabinet, using a screwdriver. These screws are at the top on the inside of the panel.
  • 5
    Disconnect the door switch wires on the back of the front panel by hand, pulling the connector straight out off the electrical prongs and setting the front panel aside.
  • 6
    Locate the idler arm pulley next to the motor on the bottom of the cabinet near the back and push the idler arm forward to relieve the tension on the old belt.
  • 7
    Remove the old belt from around the idler and motor pulleys as well as from around the dryer drum and take the belt out of the dryer cabinet.
  • 8
    Place the new dryer belt around the drum in the center of the cabinet, fitting the belt inside the V-groove in the center of the drum, and lay the rest of the belt on the bottom of the cabinet near the idler pulley so you can access it easily.
  • 9
    Move the idler arm forward to allow room for the belt and thread the end of the new belt around the idler arm pulley and over the motor pulley, letting the idler arm move back to apply tension to the new belt. Check the new belt over to verify that it is lined up correctly in the V-groove on the drum and around the pulleys and that there are no twists in the belt.
  • 10
    Place the front panel back on the dryer cabinet, securing it with the screws on the top of the panel with a screwdriver, and plug the door switch wires back into the electrical prongs, pressing the switch wires on by hand on the back of the front panel.
  • 11
    Lower the top of the dryer back down onto the cabinet and secure it with the screws underneath the lip of the front panel.
  • 12
    Plug the electrical cord of the Hotpoint dryer into the electrical outlet.
  • Dec 28, 2010 | Hotpoint Dryers
    I have a Maytag dishwasher almost new. Less than a year old. Now I've remodeled my kitchen and the color don't match. How can I change the door panel?
    Check out www.applianceart.com. They have alot of different colors, patterns, pictures, designs and even stainless steel.
    Jul 09, 2010 | Maytag 24 in. MDB9750AW Dishwasher
    Dishwasher door drops hard when opened.
    Sounds like one of the doors springs is broken or has come detached from the dishwasher housing frame. If you have a plain dishwasher door, ie one that does not have a wood panel matching your cabinets, and the spring(s) are broken, new springs cost about $20. If you have wood panel on the dishwasher door, then you may need heavy duty replacement spring at about $22.
    Jan 15, 2010 | GE Dishwashers
    Remove door panel clk 320
    You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
    Mar 16, 2009 | 1999 Mercedes-Benz CLK
    NEED ORIGINAL DOORS ON MY 561 SUB ZERO LOOKS LIKE DOORS ON FRONT
    Given the model serial number I could get your decorative panels. The door itself is a framed door and designed to take a 1/4" insert. You can have new panels made if you have changed the cabinets, order stainless steel panels or put another material of your choosing. If you would like the more about the panels reply with mod and ser number which is in the freezer door jamb at eye level. Open the door past 90 degrees and look in.
    Jan 19, 2009 | Sub-Zero 561 / F
    How to make a panel, install it and a handle for Kitchen Aid model KUDU03FTPA panel ready dishwasher
    Hello babies5 what it means by panel ready is a cabinet door style front to match the cabinets. I have installed many of these panels, however they where always supplied by the cabinet shop who built the cabinets. As to handle, that also always matched the cabinet pulls on the rest of the kitchen. The idea of this unit is to hide the dishwasher. In my kitchen, simple doors, so I would use 3/4 inch plywood and paint it white with the same pulls as my current doors and drawers have.
    May 10, 2008 | Dishwashers
    Gaggenau GI936-760 Dishwasher Logo
    198 people viewed this question
    Top Gaggenau Dishwashers Experts
    Are you a Gaggenau Dishwasher Expert? Answer questions, earn points and help others
