Question about Panasonic PT-47WX49 47" Rear Projection Television
Panasonic Rear Projection PT-47WX42CF42
Hello
My blue convergence is flickering when I am trying to align it using the convergence screen.I have changed both IC STK392-110 still no success the resistors were OK too.
Please advise
  • buzgo Apr 05, 2008
    I dont have a scope, however when the blue convergence yoke plug the one that goes to the CRT is pulled the blue cross is not flickering anymore.
  • buzgo Apr 07, 2008
    Please help me with this one
    I have a sony DAVBC250 home theater system.After a while the front panel LED is blinking and no power.I cannot started up again.If I let it sit for a few days it starts OK, however the cd changer yellow LED are on for all 5 position, this can be reset by pressing the eject buttons.When trying to increase the volume the power shuts off and the LED starts blinking again.No speakers are attached to the unit.
    Please advise
    Thank you
Thanks for your help after I,ve got the service manual I have reset it to factory default settings, and I moved the convergence back and forth problem got fixed it is working OK now.
Posted on Apr 07, 2008
    President:
  • Panasonic Master
  • 1,779 Answers
Make sure your yoke plugs are clean and no cold solder joints around them. Let me know? Do you have a scope?
Posted on Apr 04, 2008
  • Jim Krause Apr 06, 2008
    Double check all the solder connections on the STK's again. I will check to see if you have a DCM module in that model and let you know.
SOURCE:
I cannot get the blue convergence cross to line up with others.
The tv convergence board is dead.Any colors G,B,R don't alignment matches up.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 17, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Colors are not aligned
Can't use the flash focus button or the convergence control crosses +s don't alignes red,blue,green colors.The tv have convergence problems,it dead.Must replaced 2 STK convergence ICS,and some or all it resistors to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 07, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Blue convergence will not align
You need the PT53WX53G convergence repair kit which is at the following link. The kit contains the components and detailed instructions on CD to do the repair.
http://www.tvrepairkits.net/
Jul 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
I have a panasonic 47" widescreen about 5 years old. Recently turned it on and all 4 corners are missed aligned and a faint line going through the middle. Tried setting the convergence with all of them...
Yes, the convergence output IC's have gone bad. They need to be replaced. This is a very common problem with all projection tv's. It is the job of those outputs to properly align where the red, green and blue beams land on the screen.
Jun 06, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Convergence problem
Hi, you`ve lost the convergence IC`, requires a good knowledge of soldering and. posssibly an alignment after replacement, good luck, video-tek
Feb 14, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Red and Blue slightly out of alignment
If constant all over the screen it is the static convergence that needs adjusting.
The green is not adjustable!
Move the red magnets with the blue covered with a piece of card to align with the green and then move the blue with the red covered to align with the green.
May 13, 2017 | Panasonic PT-51G41 51 in. Rear Projection...
Convergence problem and cropped picture
your tv is under convergence problem usually we need to replace 2 big integrated circuits in the convergence section, at this point you may need a good tech to come over to your home
Nov 13, 2008 | Panasonic PT-47WX49 47" Rear Projection...
You are on the right track. The problem is actually with the green convergence IC that controls the alignment. The convergence ic's take the information from the 3 pictures and align them into one picture on the back of your screen. Although this is an economical repair it is complicated and should be left to a quailfied service technician. If you are not sure of a local technician, panasonic's website has a servicer locator that can guide you to one. Hope this helps
Mar 31, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic- 47wx42f
the convergence ic's are at fault need replacing,call a service shop and ask for estimate to repair .should be under $ 300.
Dec 09, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-47wx49 47in
One of the resistors in the circuit connected to one of the ic's has burned out or changed value due to heat caused by short in previous ic before it was changed.
Mar 06, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
97 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
