Question about Toshiba Satellite A105 Notebook
Laptop shuts down prox 1 minute into startup.
I get to the desktop, the icons show up & then it shuts down. I have read other posts & have checked the fan, I took it completely apart to check if the heatsink was clogged...it wasn't, and I have taken the battery out & it does the same thing, (although I do need a new battery). Now I'm at a loss.
Any suggestions?
  • 4 more comments
  • jacksjj Apr 04, 2008
    My dog chewed my AC adapter cord & I started using a universal one. I have been using it for a few days with no problems. I have to say that it isn't a "perfect fit" like the one from the manufacturer.
    Safe mode doesn't change anything and the computer doesn't stay on long enough to start System Restore
    I know you told me, that's why I responded to you. Thanks.
    I too was thinking it was a heating problem, but fan is running, fan & heatsink are clean, and after 4 hours of being turned off & completely cool, I still had the same issue.
    I'm not trying to disagree with you. I am just wondering if the battery was the problem, why does it do the same thing when the battery is out of the machine? I am asking because I am assuming you know more about this kind of thing than I do.
    Thanks for the explanation. I will see what happens with the new battery and/or adaptor & rate I'll rate your solution. :)
    Genius:
  • 1,027 Answers
The problem may also be a thermal problem with the processor.
  1. Remove the heat sink and fan assembly
  2. open ZIF socket and remove processor
  3. re-install processor
  4. insure adequate thermal paste is installed
  5. re-seat heatsink and fan assembly
  6. reassemble and re-boot
Posted on Apr 15, 2008
  • Anonymous Apr 15, 2008
    First to eliminate a thermal problem boot into the bios set up and leave it there for 2-3 minutes. if it still displays the set-up utility then the problem is probably your Operating System is infected.
    If the system remains in the bios setup without incident, then this software is for you.Hiren's Boot CD
    this is a zipped file that is a bootable .iso scroll down on the page to the download link. Burn this onto a cd and boot from this select antivirus and run the antivirus program before you boot into windows
    Keep it handy it is full of useful tools.
  • 1,183 Answers
The power distribution on the board is not correct. Try removing the HDD, memory, optical drives, and (modem, wireless card in case they are removable). If the system stays on without shutting down, one of these componets may be causing the same , plug them one by one to check .
If the system still shutdown, its time to replace the motherboard. or buy a new one
  • Mandeep  Singh
    Mandeep Singh Apr 15, 2008
    Take the computer in system BIOS and let it stay there for few mins . In case the system stays in the BIOS without shutting down it could be a problem with the OS
  • Mandeep  Singh
    Brigadier General:
  • 3,614 Answers
Software or OS system can possibly the one causing the problem, a virus can also do this thing. Evaluate everything and i think it was only on your OS.
Thanks
    Sergeant:
  • 300 Answers
If it's getting to the same exact point in the booting process, it makes me think the issue may be driver or malware related.
  • Upon turning the computer on from an off state, press the F8 key repeatedly until the startup menu appears. Select "Safe Mode" and see if the system boots successfully without shutting down. If it does, try installing a spyware removal program like SpyBot or AdAware and doing a spyware scan with that program in Safe Mode.
  • Again, try booting into safe mode (see above). Once booted, check the Start-->All Program-->Startup folder for things that don't need to be running when Windows starts.
  • If this issue began soon after a change or update of some kind, try using System Restore to go back to a date just prior to the issue occuring.
Posted on Apr 04, 2008
    Genius:
  • 3,422 Answers
HI,
he DC jack (plug) inside the notebook (in the back) is known to come loose and lose contact inside thus creating the condition of "losing power while plugged in". This also could very well be a bad AC Adaptor. If you have another one to test with try it. If you still have a charging problem, try wiggling the plug at the back of the laptop a little to see if it makes contact and starts charging the battery.
Another way to test to see if you have a DC Plug problem is to use a Docking Station, if the docking station charges the battery then you definately have a DC Jack problem.
Finally i would like to say the problem can be with your battery try replacing it.
Goodluck,
Please don't forget to rate the solution.
  • 3 more comments
  • Priya darshan Apr 04, 2008
    You can also try reseting the memory as well as the wireless card by removing them for 15min and then put them back.
    I already told you that it might be the power cord.Please buy a new one and see if that fixes your problem.If that does not fix then it is the battery.
    Goodluck,
    Please don't forget to accept my solution as fixya..
    Believe me it is the power cord or the battery not the fan..
    It may be the battery also.But as you said before that you were using a different power adapter then this problem occured.Usually these kind of replacement power adapters dont work for a long time and hence they may result in spoiling the battery or the adapter is spoilt itself.That is why the laptop manufacturers always recommend to use their adapter which is compatible with the particular battery.
    I hope iam clear.
    Goodluck again,
    And please don't forget to rate the solution..
  • Toshiba Master
  • 19,396 Answers
Did you check if the fan is working, and temperature is ok, you need to use a software
  • Ginko
    Ginko Apr 04, 2008
    If you can boot the system you use a software like speedfan to check if it shutdown for overheating.
    If it is turning off after one minute, if you start seeing windoows startup, check that is not a windows problem, you will need to do windows setup from an installation disk or using restore disks.
    You can discover if the shutdown is system related booting from a cd, for example recovery disk or windows cd. If the computer stands up with cd boot then you need to reinstall windows.
    If it shut down even booting from cd it is likely to be a heating problem. You need probably to replace the fan.
    Also motherboard or device problems can cause sudden shut down , but this is not a frequent case.
SOURCE:
Icons keep freezing on my desktop on my laptop which is medion akoya
You didn't post the OS you are using, so I will give you a Win 7 suggestion. Start by cleaning and speeding up your Machine by eliminating unnecessary start up processes. Download these freeware programs, 1, CCLEANER at : http://www.filehippo.com/download_ccleaner/ This freeware program has many useful tools, the cleaner will remove the junk from your machine and free up disk space. In the TOOLS section, STARTUP section, disable ALL unnecessary startup programs. 2, MALWAREBYTES at: http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install UNCHECK the TRIAL PRO version, you want the freeware version. Run a FULL Scan, delete ALL results, reboot. Here are more tips on increasing speed in Win 7: http://www.pcmag.com/article2/0,2817,2364937,00.asp ALSO run a FULL scan with your up-to-date Anti Virus Software. Run Windows Update to install the latest updates. Post results for further assistance.
Mar 19, 2013 | Computers & Internet
Slow hard to start
I will just give you some reasons why computer starts slowly and I hope these will helps.
1.Theres a lot of program in your computer are set in Startup:
- Try to download "CCleaner", you can download this for free at filehippo.com
- As you install this, go to the tab "tools", you can find the Startup here. Delete all the programs here which you might not need during start up.
2. Theres a lot of junk files and registry errors in your system.
- Using CCleaner, clean the junk files and fix all registry errors,,do not back up during registry fix.
3. You have a lot of icons or shortcut in your Desktop.
- More icons or shortcut slowdown the startup of your pc because it times for the system to read this, other graphics and display at your desktop may also slows down the startup.
Hopes this will help...Comment if you like my post..Thanks..!
Aug 26, 2010 | Computers & Internet
This morning my desktop photo ws still on my hp however all of the icons and tool bars were gone. I shut it down manually and restarted it about 10 minutes later. its comes up goes as far as the windows...
probably you might have turned off the show desktop icons for your desktop.
Right click on the desktop and then click on arrange icons by and the check the ---- show desktop icons option.
This should fix your problem
Nov 05, 2009 | Acer Aspire 5610 laptop vista combo with...
Computer startup
can you try right clicking the desktop and click view on the pop up menu, then under view click show desktop icons.
Apr 17, 2009 | Computers & Internet
Systemax laptop not shutting completely down
Try this ;
Buried deep inside Windows XP lurks a little-known program called shutdown that shuts down your system in a very fast � but orderly � way. Here's how to put an icon on your desktop that'll shut down your machine quickly:
1. Right-click any empty location on your desktop.
2. Click New, Shortcut.
The Create Shortcut Wizard appears.
3. In the Type the Location of the Item box, type shutdown -s -t 0.
It's important that you put spaces before each hyphen, that you have no spaces after each hyphen, and that you use a zero at the end.
4. Click Next. 5. In the Type a Name for This Shortcut box, use a name that will remind you that this button is for a very quick shut down.
6. Click Finish.
Jan 15, 2009 | Systemax AOL Optimized PC (100607) PC...
It takes my PC a very long time to boot up, what can i do?
If you have installed any softwares recently it might slow down the pc as many softwares will install a startup file in order to start faster. You can shut these programs from starting up when the pc starts.
I put 2 steps to resolve this in order of simplicity.
Remove icons from the Startup folder
Some programs open with a shortcut icon in the startup folder (Startup icons). Use the following steps to show any startup icons that might be hidden and remove startup icons from the startup folder:
NOTE: Removing items from the Startup folder does not uninstall the software program.
1. Right-click the Start button, and click Explore . The Windows Explorer window displays with Start Menu already selected.
2. Click the plus sign ( + ) next to Programs .
3. Click Startup . The shortcut icons are listed in the right pane of the window.
4. To show any hidden icons, click Tools , click Folder Options , and click the View tab.
5. Click Show hidden files and folders (Windows XP/ME) or Show all files (Windows 98), and click OK .
6. Click an unwanted startup item in the right pane of the window and drag it to a blank area on the Windows desktop. Release the mouse button to drop the icon onto the desktop.
7. Continue dragging unwanted icons until all unwanted startup icons are on the desktop. Click Yes to any window that display asking to confirm the removal of a read-only file.
8. Close Windows Explorer and restart the computer for the changes to take effect. Delete the startup icons that were moved to the desktop after you are satisfied with the way the software programs are working.
If you find that a particular software program should not have been removed from the Startup folder, double-click the startup menu item to open the Startup window. Then drag the icon from the desktop back into the Startup window.
Jan 11, 2009 | Compaq Presario 5000 PC Desktop
Laptop screen.
Ok, Start the laptop in safe mode.
Press F8 (do it a few times) just after the initial screens have faded when you turn the laptop on.
You will get a Windows Startup screen.
Select Safe Mode and press Enter twice.
After you get into Windows, goto..
Start - - Run
Type msconfig and click the OK button
In the new window that pops up select the Startup tab.
Click the word Manufacturer and it will sort the list into order.
Scroll down the list and remove the ticks from anything where Microsoft is NOT the manufacturer. Also make sure to leave your Anti Virus software ticked. It may list itself as anything, but reading the text will let you know what is what. If unsure, then just leave the Microsoft boxes checked and the rest unchecked.
Click Apply
Then OK
OK any other boxes that pop up, and restart normally.
Post back and let me know if you can now get in normally and we can proceed from there.
May 16, 2008 | Acer Aspire 5100 Notebook
You can change it by rating his solution as thanks for trying or just denying it.Then rate or accept my solution as fixya.
Apr 04, 2008 | Toshiba Satellite A105 Notebook
ERROR MESSAGE READS...
Try starting it in safe mode. (Hold F8 after power on). If you get your icon screen go to start, run and type in msconfig. Click startup and disable all the items. Hit OK and try a normal restart. This error can be caused by a bad program starting up.
Aug 30, 2007 | IBM ThinkPad 600X Notebook
Toshiba Satellite A105 Notebook Logo
141 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
