Question about Ecoquest Flair Air Purifier
Fan trouble with Flair
When I turn on my unit, the fan takes a while to start turning then when it does it has a constant squeak while turning. To me it sounds like it needs a new fan motor. how do I fix this problem and if I have to replace the motor can it be done easily?
  • Anonymous Aug 20, 2008
    My Flair is 12 years old and my fan stopped turning completely. I can use chopsticks (when the unit is turned off) to turn the fan blades a little to loosen it up, and it will usually start turning when I turn the unit back on. But I'm going to try the WD40 trick on the fan motor next time. I think this is a common problem with the units.
Remove the retaining screw from the bottom of the unit and slide the insides out the back. use WD40 with the plastic extension tube, spray into the motor armature/stator and turn with your hand until it is free spinning then reassemble and turn on.
this is an ongoing problem with my unit because the air and all contaminents are pulled directly to the fan.
Posted on Apr 14, 2008
SOURCE:
How do you clean motor on Flair? Fan will not turn
The motor shouldn't need cleaning that would prevent it from turning on. When was the last time you cleaned the machine?
Jul 26, 2011 | Ecoquest Flair Air Purifier
Flair living air purificaion system
here are parts for your air purifier, including the motor and other parts you may need in the future.
AirPurifierRepair.
- just click the link
hope that helps, good luck
Jul 31, 2008 | Ecoquest Flair Air Purifier
I cleaned my Flair air purifier, The motor turns on but not the fan even after lubricating the fan shaft and giving the fan blades a little push. Any suggestions on how to get this going?
The Flair is no longer manufactured nor serviced by EcoQuest, and the company is now Vollara. If what you're hearing is the fan motor (there is no other motor associated with this machine), it might mean that either it's totally seized up, or that the oil just has not penetrated deeply enough.
1) Turn the machine over and remove the large screw in the bottom. The chassis will then slide out (I assume you've already done this in order to reach the fan shaft.)
2) Firmly pull on the fan blades near the center in order to pull them free of the shaft.
3) Turn the chassis on its back, so the fan shaft points up. Drip a small amount of lightweight oil (sewing machine, hair clipper, 3-in-1) on the shaft and turn it manually to work the oil down the shaft. Continue doing this if you feel the shaft loosening up.
4) Set the chassis upright, tilt it forward, and drip a small amount of oil on the rear opening to the fan shaft. Continue manually turning the shaft and tilting the machine to work the oil in.
5) Replace the fan blades and turn on the machine, depressing the safety switch manually, to see if the fan will begin to turn.
If it won't turn, it might mean that the fan motor is entirely seized up. You may be able to find a local small appliance repair person who could replace that motor.
Your other option is to call Vollara customer service at 800-989-2299 and ask them to explain your options. Use #16618 if you need a dealer referral number.
Feb 11, 2011 | Ecoquest Flair Air Purifier
I have the Flair Air Purifier. Everything except the light seems to be working. When i push the button, the fan jumps into high mode for a couple of hours as it is supposed to, but I don't notice any...
if you pull the unit out of the black box ( one screw on bottom) and then turn the unit up side down, their is a glass fuse in it. See if it is blown, their is also a fuse just for the ozone part it is marked F21 on the same board, it is soldered in the board, it is a black round fuse marked 400ma 250v on some models
Aug 21, 2010 | Ecoquest Flair Air Purifier
Can feel motor run, but fan doesn't turn and very little ozone smell-have new plate
same deal with mine. Im gonna open er up n give a look c. Im thinkin the fan motor is running but not enough 2 turn the blades. Im fixin 2 google fan motors now as a matter of fact.
Jun 09, 2010 | Ecoquest Flair Air Purifier
How do we clean the fan on our Flair?
take the grill of and get a soft cloth and lubricate the center of the motor
Mar 17, 2010 | Ecoquest Flair Air Purifier
I just washed the electrostatic grid and didnt have it thougholy dryed before inserting it back into the unit. Now I cant get the power light to turn on
As long as you have the cells in the correct direction, the air flow direction you should be O.K. If you have a way of turning on a constant fan that will help dry them. I would shut the power button off to the electric air cleaner and run a constant fan for 24 hours. After that, turn the power on and the constant fan off. Turn up the heat and see if it works.
Nov 24, 2009 | Air Purifiers
Flair Fan
OK, good news and bad. Check the actual fan speed potentiometer with a ohmmeter. There are only two outs from the pot itself to the little circuit board that its attached too. The pot is 75K so make sure your ohmmeter is in the right range setting. With the meter connected, turn the dial and make sure it goes from 0 to between 70K and 75K ohms. If it doesnt or its all over the board, then the pot is the problem. Now I can't seem to find one that is a direct replacement, 75K is an oddball. I didn't un-solder mine from the board. If yours is bad, unsolder it and look on the back for the manufacturers part number, google that with the p/n as the search terms.
The circuit for the fan is not tied to the sanatize button. The circuit is relatively small, with two film capacitors, two resistors, a diode, and a triac. The circuit is on the board located underneath the unit. The circuit is located right next to the fan pot inputs on the main board. Its about 1" square with the "fan pot" inputs at the bottom left corner, if reading labels right-side-up. Resistors are almost indestructable so it is probably not them. I would lean towards the triac, diode, or caps. Look at the components and the solder connects in that circuit. If anything looks burned or black, or a solder joint looks like it has gotten too hot, that component is probably the problem. If its not the pot, which more likely than not it probably is, then I would lean towards the triac or diode. Here is the triac p/n:511-BTB06-600T. The diode I would also have to unsolder to access the part number, or I would list that as well.
I would start at the pot. That would be my guess as to what went bad. It could also be a bad solder joint on the small board the pot is soldered on to. Also check and clean the 1/4" disconnect terminals on the fan motor itself. For mine, I just cut off the old female terminals on the wires and crimped on new ones.
Hope this can give some help.
Sep 26, 2009 | Ecoquest Flair Air Purifier
Only one plate inside, it's glass edges are broken or deteriorate
I haven't seen an older Flair that I know of. There will be as many slots for plates as are required. The filter is definitely washable. Use an enzyme cleaner and rinse with hot water. The fan motor should be oiled every month or two. It should cost less than $100 to get it running in top shape.
Feb 08, 2009 | Ecoquest Flair Air Purifier
My Fan on My Flair purifier is not turning when I turn on the unit. Nervous about poking around in there don't want to break it, any ideas how to fix this? Thanks
To fix it..........there is one screw on the unit on the outside.........really long!.......remove that and the entire unit just slides out of the housing..........
The replacement fan motor can be purchased on ebay....ranging from $21.95 to $32.95...depending on the model Flair that you have...the most common one is the $29.95 replacement...
Really quite simple to remove and replace!!! and well worth it!
Hope this helps.
Feb 02, 2008 | Ecoquest Flair Air Purifier
Ecoquest Flair Air Purifier Logo
285 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
