Question about Canon PowerShot A400 Digital Camera
Camera shuts off after turnning on
After I turn the camera on it turns off and I have put fresh batteries in.
  • Canon Master
  • 4,738 Answers
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pics in a digital camera. Some may even have problems just powering startup of the camera. Performance may vary between brands and is also dependent on shelf life of the battery when bought.
For the most part, digital cameras should only be used with rechargeable NiMH batteries. Walmart sells these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Posted on Apr 05, 2008
Lens error, restart camera camera shuts off
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Aug 13, 2010 | Canon Cameras
Whe I turn the carmera on it says lens error and then the whole camera shuts off, I am not sure what to do . Is it broken?
Jul 02, 2010 | Kodak EasyShare C713 Digital Camera
Camera wont turn on even with fresh batteries
camera wont turn on even with fresh batteries,it says:"battery low..than beep,beep and turn off"
Jan 21, 2010 | Kodak Easyshare C813 Digital Camera
My camera won't turn on, even with fresh batteries.
u need not get new camera.use an iron metal to sctrach the bateery terminal of the cameral then put the battery.
Dec 09, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
My camera turns on, then immedeately shuts off. I
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Make sure that you are installing a fresh/ full charge battery
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jul 13, 2009 | Kodak EasyShare Z885 Digital Camera
Won't turn on
How "fresh" are the batteries. Quite often they are weak, right out of the package. We revive a lot of "dead" cameras with Energizer Lithium AA batteries. Many cameras that people are ready to write-off, are resurrected with the Energizer Lithiums. I also think that battery manufacturers are not putting as much "juice" in them as they used to.
May 19, 2009 | Kodak EasyShare C433 Digital Camera
My camera turns on then quickly turns off.
This is usually a low/bad battery problem. Remove the batteries from your camera and make sure the battery and camera contacts are clean. If using alkaline batteries, try a fresh set. If using rechargeable batteries, recharge them for several hours. If a recharge doesn't work, you may need a new battery set. eBay is a good source for reasonably priced replacement batteries.
Bill B.
San Antonio
May 16, 2009 | Kodak EasyShare DX6490 Digital Camera
KODAK CAMERA
I found that most digital cameras are fussy. They need the right type of battery. Try using energiser rechargables. They last longer and are the cheapest that work. Don't bother with cheap batteries they don't work.
Jan 23, 2009 | Kodak EasyShare Z710 Digital Camera
When i open my camera it says system error and shuts of can you help
I hope it may be a ' lens error'.if it means
u can try this at once..
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Jun 24, 2008 | Cell Phones
Battery problem
did you use comapny authorised battery if not go for it
Apr 24, 2007 | Canon PowerShot S1 IS Digital Camera
Canon PowerShot A400 Digital Camera Logo
56 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
