Question about Lexmark X83 All-In-One InkJet Printer
Lexmark X 83 will photocopy but not print
Darndest thing... The X83 is a combo printer/scanner/photocopier but not fax alas. Anyway I can make both color and black and white photocopies but when I try to print, the document will queue up, and the printer acts as if it is printing, but all I get are blank sheets of paper.
Lexmark is no help whatsoever.
Should also mention that I am using an Apple iBook, OS X 10.4.11
Thank you for your help.
  • 7 more comments
  • gloriamarie Apr 05, 2008
    I don't really understand your question.
    I can make photocopies as I said above. What it won't do is print.
    Thank you Basti, I really appreciate your help.
    Yes, I am using an USB cable.
    I am convinced the laptop is communication with the printer because as I said above, when i give the command to print, the printer makes all the noises that is printing, only blank sheets of paper come out.
    No, I did not trash the driver when I upgraded tp 10.4.11.
    As to which Mac... as I said above it is an iBook. I have no idea if there is ppc or intel 2 core duo. I use a computer, but have very little understanding of how they work. For instance all of a sudden I am typing in Italic and I have no idea what I did to cause that.
    I looked in "About this Mac", selected more info and I copy it below. Maybe in here is the info you are looking for?
    Hardware Overview:
    Machine Name: iBook
    Machine Model: PowerBook4,3
    CPU Type: PowerPC 750 (1.12)
    Number Of CPUs: 1
    CPU Speed: 700 MHz
    L2 Cache (per CPU): 512 KB
    Memory: 640 MB
    Bus Speed: 100 MHz
    Boot ROM Version: 4.3.6f3
    Serial Number: UV2290HSLQ5
    No, I never had an installation disk. Merely an instruction book referring me to the Lexmark website.
    Did all this but it only prints the odd character, not the whole document
  • gloriamarie Apr 06, 2008
    I have no idea what you mean by this.
  • tomcat1083 Apr 18, 2008
    I have the same problem with my Lexmark X83. It will not print from any program, it will scan and show up on the monitor but when it tries to print it goes through the motion but puts out a blank page. Also will not print test page or clean cartridges, even using the onboard controls. I have replaced both cartridges, USB cable and downloaded the current drivers from Lexmark but to no avail. I am running Windows XP Pro on a Toshiba Satellite M55-S3314 laptop, and have also tried it on my desktop also running XP Pro. Is it time to toss it in the garbage or is there any hope for it. Any help would be appreciated.
  • gloriamarie Apr 25, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona May 11, 2010
    verify connection/if printer is communicating with computer, how do you connect it? are you using usb cable?
    when you upgraded to 10.4.11 did you trash and reinstall the driver?
    which mac are you using? ppc or intel core 2 duo?
    Using printer as a standalone printer, can you do copies?
  • 1,447 Answers
Ok thanks for the info:
Do you still have the the Installation disk for your printer?
Posted on Apr 05, 2008
  • 2 more comments
    Edgar Allan Pagayona Apr 05, 2008
    Uninstall the printer driver and download the driver from this link and reinstall:
    ok download the driver and reinstall it then keep me posted. ok?
    1 thing that we can actually try is to install the resident drivers included your mac os disk.
    Edgar Allan Pagayona Apr 07, 2008
    Some printers have a preinstalled driver to your mac, esp older model of printers. do you have a gmail acct or yahoo so that we can actually chat regarding this matter. Just want to help.
When hp photosmart does not photocopy what is that thing that can cause it not to copy
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now take a test print and CALIBRATE the scanner with the test print.
Now the printer must be set to copy if not there are errors on the scanner section.
Nov 15, 2011 | Office Equipment & Supplies
Can a lexmark work without computer
apparently a lexmark cannot work without a pc except when making photocopies.For printing and scanning,the lexmark needs a pc that is why the lexmark comes with a software.
May 29, 2010 | Lexmark X7350 All-In-One InkJet Printer
I just bought a new lexmark copier, scanner, fax,
This should give you a good explanation of what ocr is.,6959,204816596_1268319518_0_en,00.html
Jul 07, 2009 | Lexmark X3550 All-In-One Printer
Lines rule across my print out paper at photocopying mode
Make sure you don't have a scratch on the glass of the scanner. If you have a mark, or scratch that matches the line ruled on your print, then there is your problem.
It;s also possible the scanner is jerking as it goes across the bed, which is causing the line. Is the line solid, dashed, bold, thin or just kinda there?
Mar 14, 2009 | HP DeskJet F380 All-In-One Printer
Lexmark x215 MFP All in one - prints fine but photocopy and faxes
you should clean the optics situed in the upper place of the machine, retirate the originals glass en clean all the mirrors are inside...
good luck...
Feb 11, 2009 | Lexmark X215 MFP All-In-One Laser Printer
Panasonic DP 180 - will not print faxes
you need to do an all job clear in fax mode. leave me a msg and i will try to help
Oct 04, 2008 | Panasonic Workio DP-190 Multifunction...
Inability to print
I chunked it and hooked up another spare printer we had in the house. Life is too short for tinking around with frustrating things like this. Thanks anyway.
Mar 17, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark Fax/Photocopier/Scanner Model X5470
most likely it's just sending them to a file. Check the settings for this. You have the user manual?
check your computers warranty here 4 FREE
Mar 08, 2008 | Lexmark X5470 All-In-One InkJet Printer
Sorry the printer hardware is not supportting MAC leopard as printer is old and lexmark dont have driver for mac leopard:that why the printer is not working...
Dec 23, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
349 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
