Question about Jwin JD-VD743 Tape Decks
The dvd player won't turn on
Recieved this as a gift. the power light on the front never comes on but it looks like the battery is charging. I cannot get the unit to power up. thanks in advance
    Sergeant:
    Champion:
  • 319 Answers
Some units will not operate when charging. Remove battery and see if unit will operate then
Posted on Apr 25, 2008
SOURCE:
I have a sony DVP-FX74 portable dvd player that won't turn on. I have charged the battery. Any ideas?
the power system has been interfered with,i won't use a complicated language but i need you to try and use an adapter,if it doesn't work it means the transformer has a problem or it has failed completely and it needs replacement
Oct 25, 2012 | Sony Dvp-Fx740dtb Portable Dvd Player Sony
My daughter spilled water on Sony portable DVD player, now it won't turn on
No! when water enters it will rapidly corrode the ic pins and other critical parts, best to replace the player.
Apr 02, 2012 | Sony DVP-FX930 Portable DVD Player
I have a Sylvannia SDVD9000 portable DVD player. My parents bought it for my son for Christmas and we've never figured out how to charge the battery. My son has watched many movies with it plugged in,...
In order to charge the battery you must plug in the power supply AND then turn the off/on switch to OFF. You should see the blue light in front change to red. and you are now charging... Tadah
Feb 26, 2011 | Sylvania SDVD9000 Portable DVD Player
Need help charging my mintek dvd player battery
The way the battery is usually charged is by plugging it into the player and plugging the player into the a/c outlet. Do not use the player, Just allow the player to charge the battery. The way you tell if the charging is working is the light on the front will usually be a red color and it will be steady color or blinking while charging. When the battery is fully charged, the light will turn green or turn off . This lets you know that the battery has fully charged.To test this try using the dvd player on the battery only. Play a dvd or cd and see if the battery is working properly. I hope this information helps you with your problem.
Apr 01, 2009 | Mintek MDP-1770 Portable DVD Player
GPX DVD Player
Most items, first time your have to charge it for continious 8 to 11 hours. On that time it fully charge the battery and internal battery. I would say charge it for 11 hours.(It wont over chage on anything.)
But, if you already charged it for some time, discharge it fully. (Leave it playing till it wont even turn on when you puch the power button) Then charge it backfor11 hours.
Cheers!!
Mar 13, 2009 | GPX Audio Players & Recorders
My prortable dvd player
Make sure the battery is installed in the correct direction, turn off the player, plug in the AC pack and look for the red charge light to illuminate on the front lip of the player. Give it a few hours to charge.
Apr 05, 2008 | Insignia IS-PDVD10 Portable DVD Player
Not working
I had the same problem.  iRiver suggested getting a new battery.
Jan 31, 2008 | Audio Players & Recorders
Charge light does not come on???
I had the same problem after buying a new dvd from bestbuy.
although this may sound wierd, but check if you have a battery in there, since its coming without it inside.
maybe you bought it without a battery.
Sep 28, 2007 | Zenith ZPA-314 Portable DVD Player
My DVD player does not charge!
I think you mean the "charge/power" light doesn't come on? One thing I've noticed on the PD-758LP I have, is that the power connector on the back of the player is none too good, my DVD player quits if the cable isn't set just...right... Try moving the power cable around on the back and see if it lights-up briefly. I suspect problems with that connector first.
Jan 14, 2007 | Protron PD-758LP
Jwin JD-VD743 Tape Decks Logo
50 people viewed this question
Top Jwin Audio Players & Recorders Experts
 Grubhead
Grubhead
Dapid Candra
Dapid Candra
Pavel Pranovich
Pavel Pranovich
Are you a Jwin Audio Player and Recorder Expert? Answer questions, earn points and help others
