Question about HP Compaq Presario V2000 Notebook
No sound from speakers
Audio is coming when i use my headphones but no sound comes from the speakers...Any solution Folks
  • amlu Apr 05, 2008
    Hey,, idid check the sound settings, reinstalled the audio drivers, restarted the comp...still no go...
  • Anonymous Apr 06, 2008
    yeah, My laptop has thesame case. sometime i reinstall drive for sound , but still like that. pls . some thing wrong on hardware!?
    Problem Solver:
  • 8 Answers
Hm.. Not entirely sure. Maybe try going to the control panel and hardware and sound (might be under something different if you have XP or earlier, I am looking at my laptop but I have vista, but wherever your sound settings are) and look at the settings and make sure everything is working and all. If you haven't restarted since the problem started, definitely try that. Otherwise, all I can think of is maybe reinstalling the audio driver. On my computer that is called SoundMAX. On yours it is probably different. So that's all I can think of. I'm not sure that any of that will work but those are some of the basic things I would start off with doing if I were having the same problem. If you do reinstall the audio driver, be careful doing it. It's not like it's something that's really likely to mess up your computer or anything but you don't want to like uninstall and not know where to go to reinstall because then you really won't have it. So, yeah. That's all I've got. Hope it helps.
Posted on Apr 05, 2008
No sound comes out of the system/speakers on my FW-C255/37
There is a problem with the headphone jack or there is a audio output problem, get some electronic contact cleaner attach straw and spray inside the jack, push the headphone jack in and out quickly and spray again and repeat, this should clean the contact points, if no sound, audio output should be suspect.
May 10, 2012 | Philips FWC255 CD Shelf System
Why does the audio cut out on acer z5700 speakers when you connect to a source at the audio output in the back.(expect this only when you connect headphones to headphone input)
When you connect headphones to your computer the computer will only send sound through the headphones and not allow sound to come out of the speakers. this is the way almost all audio drivers are setup, it detects the speakers and the headphones as 2 different devices and will only play sound through one (headphones first and if there are no headphones then speakers).
The only way I know to resolve this (and I hate this suggestion) is to purchase a headphone splitter. Connect the speakers and the headphones through the splitter, the quality of the splitter will determine the quality of the sound.
You could try going to the audio driver options (if there is any program installed by the audio driver) to see if you can get it to play through both but with both my Acer laptops I have been unsuccessful.
Hope this helps.
Mar 23, 2011 | Acer Aspire Z5700 PC Desktop
I have a 32" LG
Hello Undernet01,
Yes, it's very simple. Connect the computer speakers to the headphone socket on the TV, then run a separate audio cable from the PC to the TV. A PC monitor cable wont carry an audio signal so you need to connect an RCA type cable or similar - depending on whether you have corresponding audio OUT sockets on the PC and audio IN sockets on the TV.
You will then have sound from both the PS3, the PC, and the TV on the computer speakers. The TV speakers will automatically switch off when something is plugged into the headphone socket.
Simples as pies.
BElectric
Dec 26, 2010 | Computers & Internet
No sound
Hello
First you check the speaker of your Daewoo Tv. To check the whether the speaker is good or damaged, place your year very close to the speaker side of your TV, and switch the TV by its front panel power switch, not by the remote control. If you can hear a "Thumb" sound from the speaker, as the TV is switched on, the speaker is good and you have to to further. If not speaker has got damaged and have to be replaced.
If your TV is provided with an earphone or headphone socket at its fron panel, insert a earphone or headphone pin into it and listen whether there is sound coming from it or not. If ther comes the sound, it doesnot comes to the speaker, means that the headphone or earphone socket is faulty. Replacing it will solve the problem.
If there is AV OUT from your TV, connect it to an amplifier or so to get the sound. If there is sound and no output from speaker, means the Audio Output IC inside your TV is faulty.
Just locate the audio output Ic, and replace it with same type and number. Audio Output IC can be easly located ans speaker wire goes to that section, and follow the speaker wire. locate it. If you need any more assistance, feel free to contact me through Fixya. OK.
Dec 07, 2010 | Daewoo DTQ-20U9SC TV
How to connect headphones to this tv.
The only way to accomplish this will require an external amplifier.
Connect the program out to the input of the external amp and use the headphones from there. Disconnect the speakers or turn them off in the audio menu.
Hope this helps,
Dan
Jul 11, 2010 | Panasonic TH-42PX60U Television
Audio/sound problems
sounds (pun intended) like you have your headphones plugged into the microphone input. See if you can change the spot they are plugged in...
good luck
May 23, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Audio input/output problem
Dear user,,
Pl go to control panel and select sound/audio device and click and see you see install sound device.
pl double click on speaker symbol at taskbar.
see volume controler and selecting hedphone device and see it is mute or not
Regards,
Ravindra Shah
Marshall mg15cd practice amp sound ok through headphones but does not come from main speaker when h/phone lead is removed
Hi davyboy5
Sounds like the speaker has blown or maybe a wire has come off. Sometimes the headphone socket can go faulty also. Do you have nyway of testing the speaker?
regards
robotek
Jun 13, 2008 | Audio Players & Recorders
Audio problem...
i have compaq presario c700. when i attach headphones, the laptop speakers dont get off. both headphone and speaker are on. the sound should only come from headphones..
i have windows professional installed
ishric_ishaan@yahoo.com
kindly post the feedbakc on my email
May 26, 2008 | Intel Computers & Internet
HP Compaq Presario V2000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
