Question about Dryers
Dryer wont heat
The dryer is a Kenmore
MOD 11062202101
SER ML5208819
TYPE D433-ELE2406028-FM54
The dryer will work but it wont get hot. About 2 weeks the heating element was replaced. It was working again for a little while, but then it stopped. It still ran but it's just cool air.
  • babygyrl22 Apr 05, 2008
    How can I tell if the heating element or the thrmstate is bad
  • 66 Answers
If you already replace the heating element . it may be loose or it get damage . you can open the dryer from the back . and ck if the 220v is coming in . or the thrmstate is no goog . most likely you heater when dad again. good luck . and let me know if you need to find any parts for it .
Posted on Apr 04, 2008
  • Anonymous Apr 05, 2008
    if you have the contnuty in the heating element. than heater is good. and ths is bad .
SOURCE:
I have a amana dryer that buzzes with u try to turn it on..
Checked the fuses already ? Otherwise try this: http://www.fixya.com/support/t2799423-mod_rex4635ew2
Oct 17, 2014 | Amana Dryers
My Kenmore 500 mod 110.69522800 type DWSR-ELE-2406026-FM54 start button wont turn it on. How do I fix this?
I will help you please contact me [email protected] I have neen repairing appliances for 34 years
Feb 01, 2014 | Dryers
I have a whilpool electric dryer type d433-2406026-fm54 this dryer doesn,t heat anymore but the dryer still runs.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101,,.';'
Aug 02, 2011 | Dryers
I have a whirlpool Dryer type: D433-ELE-2406028-FM54, Model: LER463JQO. It takes atleast 2 cycles to dry the whole load completely, and I'm wondering what I can do to fix this problem?
You may have a clogged vent pipe. I would take it apart and clean it all out.If that doesn't help then you may have other problems.Could be thermostat or one bad element. Hope this helped.
May 05, 2011 | Kenmore 600 6965 Electric Dryer
Dryer runs...timer wont rotate and wont heat up
Good day,
Timer woun't run if there is n heat.
1. Check to see you are getting 230 volts to the machine. The motor uses only 115 so is not a good indication.
2. Remove back cover. You will need an ohm meter to test the components.
A. In the center bottom is a skinny white bakelite device held on with one screw. Remove one wire and check. It should check zero ohms. If not replace.
B. On the bottom right is a canister with the heating element terminals sticking out. They should test at 30 or less ohms. If not replace the heating element.
C. There are about 3 other limit thermostats in the area you're working. They should all check at zero ohms. Replace as needed.
Below is a tutorial on changing a heating element.
http://www.applianceaid.com/wp_element.html
Mar 02, 2010 | Whirlpool Dryers
MOD: REX4635EW2 SER: MJ0922226 Type: D433-ELE-2406028-FM54 Won't turn on just buzzes when hit the start button. Have already checked plug in and braker box?
Remove the back panel from the control panel to access the start switch. If there are 4 wires on the start switch,replace the start switch.
Aug 18, 2009 | Roper Dryers
MY KENMORE DRYER WON'T DRY MY CLOTHES
you need to clean out the dryer vent hole and the wall vent hole,that is your problem it's not letting the wet hot air out-mike
Mar 31, 2009 | Kenmore Elite HE4 Electric Dryer
Wont dry
WHAT BRAND IS ( LG WP KENMOOR OR MAY TAG) I NEED TO KNOW THANKS
Apr 04, 2008 | Dryers
Dryers Logo
275 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
