Question about Garmin Quest GPS Receiver
Garmin Quest is out of whack
I have a garmin quest 1
the firmware is the latest one
the map source is for north America.
0ff-route calculation is automatic
route preference is faster time ( i tried shorter distance too )
calculation is best route for car
The problem suddenly occurred after reloading the map pack that came with the unit. It worked fine for the first few months and ever since, the unit will:
* take forever to acquire the satellite signal
* will always be off route
* will shut itself down when recalculating
* if I plan a route from point A to B on the unit, it will give me a strange route not even from where i am. and will make me go diagonally????
* the highlighted route will be the one next to my actual location and even when recalculating, it does not change.
I called the tech support at garmin and the guy did not have a clue what could cause that.
Any ideas???
Hello, I currently own a Garmin quest myself, and some time ago I had some strange problems myself, I am a electronics technician, and I do have a work around for you. I will explain the problems and a cure for you to try, none of the work arounds depend on any parts to be removed.
1. NO RECEIVING SATELLITE TELEMETRY. I beleieve this could be due to a number of reasons, but more so at sometime corrupted telemetry was the problem to fix this,
a turn GPS on when booted (initialised)
b. depress menu
select settings
select Time Setup
when in Time Setup depress MENU
Select SET DATE
Depress OK button
Depress OK button again on the numberic keypad that appears on the screen (DONE)
what this seems to do is resets the internal date/time clock and the unit starts to work again.
the Second workaround is this but takes hours to perform.
Simply turn the Guest on and allow the battery to fully discharge, usually this works to TOTALLY flush the Memory again, but on my unit I have to setup all the maps again, this is easy to perform, but just takes time. I hope this helps you.
phil
Posted on Jun 07, 2008
b. depress menu
select settings
select Time Setup
Select SET DATE
Depress OK button
phil
Only shows us routes not canada
I fell foul of that the other way. I have Canada maps and lent it to a friend who was going to California.
You need a map that covers Canada and it is an extra cost. The USA is in two zones, or one map does both zones.
You need to buy the Canada maps and then put it on an SD card. The map costs $84
https://buy.garmin.com/en-CA/CA/maps/on-the-road-maps/city-navigator-nt/city-navigator-north-america-nt-canada-only/prod8750.html
City Navigator North America NT Canada Only Garmin
Feb 20, 2016 | Garmin Nuvi 2360Lmt - Gps Receiver
My Garmin Quest displays...detail maps don't support routing.The position of my vehicle is shown slightly to the left of the roads I am driving on.
May be zoomed in to close, could be that the antenna is not receiving good satellite signals, some windshields have metal to lower sun energy and this can affect reception. Try external antenna.....
Feb 13, 2010 | Garmin Quest GPS Receiver
Need a Map Source CD for a Garmin iQ 3600 GPS
Please visit http://www.ebay.com
Search for the needed item and there you are.
rate this solution afterward.
Sep 04, 2009 | Garmin iQue 3600 GPS Receiver
"Detail maps Don't Support Routing" in Garmin Quest
I too have a Garmin Quest and yesterday felt like throwing it against the wall because of the above problem. I found the solution eventually. When you download the maps from the Garmin Maps page, where you select the maps download, make sure that the checkbox to "Include route calculation data" is ticked before downloading your maps. Also make sure that the total memory required for the number of maps selected does not exceed the available memory on your Quest. If you try to fit more information into your Quest than it can receive then you are bound to have some problems. The Quests seems to have different memory specifications. According to the USA spec the memory is only 128mb, the Garmin site says 115mb and the box that my Quest came in says that it has 243mb.
Jul 10, 2009 | Garmin Quest GPS Receiver
Maps don't show after downloading upgrade.
sounds like you might not have the new map set selected
settings -> map -> map info (make sure the NT 2009 map is checked)
Mar 17, 2009 | Garmin nuvi 350 GPS Receiver
Garmin Quest Coordinates
Menu/ Map Setup/ Layout/ Orientation,  choose 'North up'. To return to normal choose 'Auto'
Aug 19, 2008 | Garmin Quest GPS Receiver
Screen froze up
"If your Quest locks up....on rare occasions, your Quest may freeze or lock up. In this case, reset the Quest by pressing the unit's Power key and the IN key at the same time. This will turn off your Quest. The unit will operate normally when you turn it on again."
Aug 02, 2008 | Garmin Quest GPS Receiver
I need an updated map for my Garmin C340 for North America
already answered the first time
repeated for the last time
https://my.garmin.com/maps/updates.htm
http://www8.garmin.com/support/download_details.jsp?id=209
Jul 16, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin Quest
a turn GPS on
b. depress menu
select settings
select Time Setup
Select SET DATE
Depress OK button
phil email pjb3103@bigpond.com
May 24, 2008 | Garmin Quest GPS Receiver
Can't get maps to unlock
Call Garmin support @ 1-800-800-1020
Feb 09, 2008 | Garmin Quest GPS Receiver
Garmin Quest GPS Receiver Logo
145 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
