Question about Ovens
How to remove broiler element from a Bosch oven (model #HBL445AUC). Do I just pull hard? Must the oven be pulled out? There are screws (ends, not heads) sticking into the bracket of the element into the oven from the back side (the heads of the screws are on the back side (not accessible).
  • Anonymous Aug 14, 2008
    Element does not come on
  • 1,234 Answers
Remove 4 screws from back panel and remove back panel. Remove 3 screws and 3 wires from heater element POWER OFF to unit! and remove element. Reversed procedure with new element and seal. You will need the seal! maybe! Old one's usually crumble apart less than 10 minutes to replace
if you need a gasket/seal and are in a pinch go to a local auto parts store and ask for a sheet of hi/temp gasket material and make one.........
or order from repairclinic.com
hope this helps
Posted on Jan 06, 2018
  • vince Jan 06, 2018
    you have to get the unit out. that may cause a problem if it's built in with trim. But tis the only way to repair. whether it's you or a tech. Please be sure the power/breaker is OFF while doing anything with the repair.
    your dealing with 240 volts... breaker a double breaker in the breaker box.
4 Suggested Answers
SOURCE:
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    aborcass
    • 2651 Answers
    SOURCE: Frigidaire double oven has one element not working in each oven
    sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
    ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
    Posted on Dec 21, 2008
    barkencoa
    • 3463 Answers
    SOURCE: unable to remove the fan blade on the neff u1721 oven (too tight)
    The nut is a left hand thread, so unscrew it clockwise to release it, hold fan blade as you are doing this. Tighten anti- clockwise.
    Plz rate my solution.
    Thanks.
    Posted on Jan 11, 2009
    I have a Fridgidaire Model # PLEB30S8CCC wall oven. The broiler works fine. The oven is very slow to heat up, 20 minutes to reach 250. I checked the lower element with a omp meter it read 20. Is that...
    Hello there and than you for choosing Fixya
    If your oven does not heat, does not heat enough or does not broil, a common cause is a burned out heating element. There are two elements, the baking element on the floor of the oven and the broiling element on the ceiling of the oven. They are about the diameter of a pencil and typically supported by metal stand-offs.
    This easiest test you can do is to turn on the oven and observe the heating element. If it glows red, the element is working. When baking, the broiling element may come on to assist with preheating or to maintain the oven temperature. When set to bake, if the broiler comes on, but the baking element does not, the likely cause is a burned out baking element.
    When set to broil, the broil element should glow red, but the bake element typically is not used. If the broiler does not glow, it is likely a burned out heating element.
    There are other possible causes of these symptoms, refer to our diagnostic page for some other possibilities.
    To test the heating element using a multimeter, follow the steps provided below.
    1. Unplug the oven or turn off the power at the breaker or fuse box.
    2. Follow the heating element back to where it goes through the wall of the oven. Remove the bracket that secures the element in place.
    3. Unscrew or unfasten any stand-off supports that secure the element to the oven.
    4. Pull the element part way out to expose the oven's wiring connected the element.
    5. Label the wires and secure them in place so they do not fall back into the cavity.
    6. Disconnect the wires from the element.
    7. Using a multimeter set to x1, touch one probe to each of the element contacts. Expect resistance in the range of 20 to 40 ohms. Infinite or kilo-ohm resistance usually indicates a bad element and it should be replaced.
    8. If the element tests okay, reconnect the wires, slip them back into the cavity and resecure the element.
    Jan 26, 2011 | Frigidaire Ovens
    Oven won't heat past 200 degrees
    Unplug the range.
    Remove the oven racks.
    Remove the screws on the bake element.
    Carefully pull the bake element out.
    Remove the wires from the element.
    Use a volt meter set for ohms/continuity and touch one meter lead to one element terminal and the other lead to the other element terminal.
    No reading is a bad element/
    If you get a reading your oven control is bad.
    Jul 24, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
    Broiler element out. Need instructions on replacement.
    Varies a little by brand, but basically you:
    1. Turn off the power. Either at the breaker, or pull out the range/oven and unplug it.
    2. open the oven door, remove the racks.
    3. where the element enters the back of the range, there should be a screw or two one each side. Remove the screws
    4. pull out the element
    5. put the new element in and reverse the steps above.
    be sure and take your oven model # to the appliane store when you order your new element.
    Peace
    Mar 02, 2010 | Ovens
    Bake at low temp. Heating element vs control board
    you need a meter that checks voltage (220) and continuity. turn off breaker remove screws that hold element in carefully pull it out just enuff to remove wires.remove wires check for continuity on element if there element is good. tape the leads to the wires turn on breaker, turn on oven if no 220 volts bad board or broken wire.
    Feb 17, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
    Broiler works fine, oven will not come on ?
    Check all fuses. Make sure the bottome element is seated properly. If the top and bottom element are the same you could always remove the top one and place it in the bottom (they usually just push-in and pull-out similar to the elements on the top of the stove) to see if it is just the element. A replacment element may be all you need.
    Hope this helps
    Jer
    Jan 16, 2010 | Maytag CWG3100A Gas Single Oven
    Replace broiler heating element Whirlpool builtin oven
    do you want to know how to replace it? turn the power off first. open the door to the oven usually there are 2 screws that go to the broiler. unscrew them pull the heating element out remove the wires, make sure you pull them out far enough or you will loose them in the back of the oven. plug the new one in screw in the screws and you are good to go. let me know if this helps
    Jul 18, 2009 | Ovens
    Kenmore electrical oven
    Trying to better define the problem....
    Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
    To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
    Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    Bosch convection double oven,ovens won't heat,only broilers work
    If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
    Plz rate my\solution.
    Thanks.
    Dec 17, 2008 | Bosch Ovens
    Frigidaire Double oven PLEB30T8AC
    The best way for you to check is to swap with other element since they use the same one. FRIST turn the breaker off! Then take out the 2 screws on the element. The wires unplug, make sure they don't go back in the holes or the oven may have to come out to find them. You can pull the element out and take it to a parts house to see if they can check it with a ohm meter for you if you don't want to pull both of them out.
    Apr 15, 2008 | Frigidaire PLEB30T8A Electric Double Oven
    GE Oven Model JK1901BC
    check power cord if oven light not working or burners then you have a power problem no there is no reset if you have power at the outlet then pull the range out take off the back cover where the power cord is and check there let me know we will go from there
    Dec 30, 2007 | Ovens
    Ovens Logo
    148 people viewed this question
    Top Ovens Experts
    Marvin
    Marvin
    Are you an Oven Expert? Answer questions, earn points and help others
