Question about EZQuest Cobra Plus (B66600) 80 GB Hard Drive
Front light jumper cable
Can you advise where the front light jumper cable plugs into on the circuit board. There are three jumper points on my board. JP1 ,JP2 JP3
  • shadai Apr 04, 2008
    Thanks
    Scholar:
  • 91 Answers
If it has the black and red wires, it connects into JP2.  The other wires, which are black and green connect directly to the power supply into connector CN4. Bob
Posted on Apr 05, 2008
SOURCE:
Plugigng of wire in board
Hello there,
Below is an image of *********** Board with number indication and wiring explanation. From your manual page 1-6 you can see the image below and 1-7 for the connector, jumpers, slots. as indicated in your problem I will only answer problems related to the wirings.
  • For the Front Panel
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
  • For the USB connectors
1. If your casing has a USB header on the front bezel you can put it on any connector. You can also purchase a USB module cable or an internal card reader and plug the headers to any of those connectors.
Note: Observe Polarity, do this Vcc, -Data, +Data, Gnd ,(NC) ground is always near to NC.
Plug it at your own risk, reference image are already shown.
  • Front Panel Audio connectors
1. Look for FP_Audio header from your casing and plug it to the connector.
*Asus recommend you connect a high definition front panel audio module to this connector to avail of the motherboard's high-definition audio capability.
Hopefully this information helps.
Thank you for using FixYa.
Aug 19, 2011 | ASUS P5KPL-AM SE Motherboard
Tip
How to Test the Relay Board on Stairmaster SM916 Stepmill
How to Test the Relay Board on a Stairmaster SM916 Stepmill Disconnect power from the machine.
Disconnect the main cable from the relay board J1 terminal. Main cable should remain disconnected for the duration of the relay board tests.
With the Power ON, place a jumper wire across the GND/BLK and RLY/RED test points. (Ensure jumper wire only makes contact with the designated test points.)
  • Verify that the Relay LED is lit. Remove jumper wire.
With the Power ON, place jumper wire across the +/WHT and FLD/BRN test points. (Ensure jumper wire only makes contact with the designated test points.)
  • Verify that the Field LED is lit. Remove jumper wire.
With the Power ON, place jumper wire across the +/WHT and with the other end touch the ALT/C, FLD/NC, and RES/NO.
  • Verify that the Field LED lights.
If any of these jumps fail, replace the relay board and or power supply.
Stairmaster SM916 Stepmill Relay Board Testing
on Feb 25, 2015 | Stairmaster SM 916 StepMill
I Need the jumper settings for the fic k8mc51g motherboard from a emachines desktop computer. Putting the motherboard in a custom case.
There is a 4-Pin Speaker connector that is not used by Gateway on the motherboard (right beside) the CMOS jumper settings (Pins).
The clear CMOS settings jumper block is right beside the speaker pins. You can use this jumper block to clear the CMOS RAM, which is powered by the onboard real-time clock button cell battery.
Pin 3 is indicated by the markings on the board.
Settings: Pins 1 and 2 covered = Normal Operation Pins 2 and 3 covered = Clear CMOS enabled.crazyeyes746.jpg
Jun 26, 2011 | Computers & Internet
Wash load almost complete, buzzer went off, door locked & won't open. Lights all blinking. Unplugged washer, plugged back in, lights still blink, door still locked.
To open the door first unplug the machine then take off the front panel under the door (three screws at the bottom) reach in by the door lock and there will be a plastic tab hanging down, that is the manual release for the door. Pull it down and the door should open right up. I'm judging that the machine is flashing a code when it shuts down, often times its F11 or FdL in either case the problem is most often a bad CCU circuit board (whirlpool had quality control problems with this circuit board) There's what's called cold solder joints on the board at the points where the spade connectors and relays (5 of them) are supposed to be firmly soldered to the board. These bad connections cause the Duet washer to have all kinds of issues. To repair it you need to take out the CCU circuit board It's in a plastic case at the inside, top, back of the machine. Remove the case as a whole, it's easier that way. Then remove the circuit board and touch-up those points I mentioned. If you not good with solder techniques you can remove the board (keep it in the case) and take it, and this response, to a good appliance repair shop and they should be able to help you out. Good luck.
Jan 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Electrics The power to tiller broke down,I have had the control box checked profesionally & it was deemed to be ok. I changed the contector from tiller harness to controller replacing some of the...
It sounds like you have tracked down your problems to the front to rear wiring harnesses since you have replaced some of the pins. In my experience, it is not cost effective to do this since there are usually hidden problems in the harness due to flexing, other corroded contacts or contacts pushed in the connector not making contact. The front to rear harness costs about $60 retail and is easily replaced.
You might also consider replacing the two intermediate harnesses from the tiller to all the components in the front console and the rear controller harness. I have had the rear controller harness melt and make poor contact at the controller board connector on the Curtis and Penny and Giles controllers. I have also had the tiller harness get pinched and flexed so much that the internal wiring made intermittent contact.
Continuity checks are only good if you go from the farthest point at the controller board pin outs to the console board pin outs. Sometimes, you can have a good continuity check on an unplugged, isolated component only to have it fail when you plug it in and the contacts are poor. Usually the intermediate molex contacts or wiring can be bad. These two additional harnesses can run an additional $200 retail. Labor should be about 2 hours if you do it yourself and if you have a hot glue gun to secure the front to rear harness under the shroud (if not use cable ties). You might still need to replace the front console circuit board and throttle potentiometer but your description indicates otherwise. Also make sure the that the front connector to the console circuit board (from the intermediate front to rear harness has not come unplugged due to gravity. You might still need to contact your professional for additional diagnosis and parts, then do the work yourself. The parts are OEM parts only, but they might be available online at a discount. Hope this helps.
Nov 13, 2010 | Pride New Mobility Legend 4 Wheel Scooter
Hi I have a Mitsubishi ws-65615 65'' tv. I gat the green flashing light. I chainged the 4 capacitors, disconnect the front panel but still not want to work, still have the green light. ???????????????...
On the DM module where you replaced the capacitors there are three small white pico fuses. They are on the opposite site of the board. I would jumper all three by crimping a small piece of copper around them. Put the module back in place without its metal box around it. Plug the tv in and wait about two minutes. If the flashing light is off, turn it on. If this works, remove one of the jumpers. Continue until you have found the faulty fuse. Either replace or jumper the fuse permanently. When you put the DM module back in permanently, if the tv once again gives you the flashing light for more than two minutes, then the DM module is simply not setting properly into all of the pin locations.
Jan 05, 2010 | Televison & Video
Power light on front flashes continuously and TV won't turn on
unplug TV for 5+ minutes then plug back in ... might work but this usually is caused by some other internal problem that may require service.
Sep 28, 2009 | Toshiba 57H81 57" Rear Projection...
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
Speakers no longer work when front panel audio cable connected.
Thats the point of the jumpers. They need to be connected to make the connection so the rear is disabled when you plug things in. Here is where your jumpers should be placed:
Basicly every other bank needs a jumper.
May 01, 2009 | ASUS K8V-MX Motherboard
T2893 Motherboard Layout - Where do the power jumpers go?
go to this link for the information you need http://www.intel.com/design/motherbd/sr/sr_con.htm#IC
May 05, 2007 | E-Machines T2893 PC Desktop
Open Questions:
zcmslkcs'./ Amazon Prime rEfUnD pHoNe O*^%{+1++85O++8I2++4OO9*^ how to get refund from amazon prime Amazon Prime Refund Phone Number +1-85O-8I2-4OO9. While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 20, 2019 | Amazon Computers & Internet
~~AmaZon PrImE ReFunD PhOnE NuMbER {+1-85O-812-4OO9} USA Customer service phone number for amazon 1 800 for Cancel amazon prime membership by phone. How to get a refund from amazon prime? AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon.
See all EZQuest Cobra Plus (B66600) 80 GB Hard Drive Questions
EZQuest Cobra Plus (B66600) 80 GB Hard Drive Logo
99 people viewed this question
Top EZQuest Computers & Internet Experts
Ekse
Alun Cox
Are you an EZQuest Computer and Internet Expert? Answer questions, earn points and help others
