Question about NEC MultiSync MT1050 Multimedia Projector
Convergence Problem for NEC MultiSync MT1040
Hello, I just read a post saying you are willing to assist in aligning the LCDs of a projector. I would like your assistance if you are still willing. I have a MT1040 projector I recently purchased off ebay. It has a new bulb. I also want to say I am a certified electronics technician. Any help would be greatly appreciated. Thanks
2 Suggested Answers
SOURCE: NEC MultiSync VT540 not turning on - Temperature error
if the status light is blinking red in 4 sec interval it means that there is something wrong with cooling system. you shold check if there is a thermostat failure or if there are any switches that are not turned on. i suggest you to open the device (using screwdriver) and check if there are any switches broken or damaged.
i had pretty much the same problem (one second interval). i took off the cover and there was a broken switch and i just short-circuit it and now it works
Sorry for my english
Posted on Mar 06, 2009
When connecting projector to my laptop, the picture comes up as right to left so impossible to read anything. I have tried to flip it landscape way but that flips it upside down and still reading right to...
If you push the button one more time to flip the screen it should read properly, otherwise bounce it off of a mirror and adjust the keystone if it is a permanent mount.
Jul 05, 2011 | Sharp XR-10SL DLP Projector
Need the projector bulb where can i get it and how much multisync mt830
Hello I am an electronics technician from Washington,DC. Try they are located in Portland,Oregon I have used them several times. Nate was very helpful. You can find a lamp there for sure.
Nov 19, 2010 | NEC MultiSync MT830 Multimedia Projector
Nec projector vt440 wont turn on
Hello. First check the lamp! From your description, it sounds like the projector is telling you that the lamp needs to be replaced. In "eco mode", when the power is green and the status is steady orange, that is the error message. In "high brightness mode" the status will be steady red. Hope I helped you.
Feb 22, 2009 | NEC MultiSync VT440 Multimedia Projector
NEC Multisync MT1000 Projector - Green Hue
its not the bulb problem . the lcd block need sto be replaced , better to buy new projector
Feb 06, 2009 | NEC MultiSync MT1000 Multimedia Projector
Alignment on the MT1050
You need to take it to a NEC service center or a local professional to get the lcds alinged again.
Jul 18, 2008 | NEC MultiSync MT1050 Multimedia Projector
Vertical line
what cables are uusing for tis 15pin vga in or hdmi ?
Feb 02, 2008 | NEC MultiSync MT1020 Multimedia Projector
Alignment (convergence) of color panels MT1050
I can assist you with that if you want. It is very tedious, but can be done. You need a cross hatch pattern generator or something with vertical and horizontal lines to lineup the LCD Panels again. Tricky little procedure if your not familiar with it. Let me know if i can assist you and hopefully save you agravation at the same time. Thanks Jay
Jan 12, 2008 | NEC MultiSync MT1050 Multimedia Projector
NEC MT800 Projector with Vertical Lines in picture
The ghosting problem is a combination of both the lcds and driver boards in which case neither need to be truely replaced.. They use a specific voltage to transmit data to the lcds.. Each lcd is different and the driver board is programmed by the factory for the EE setting. Unfortunatly with nec, they do not offer a service mode to go in and adjust the ee settings to correct the electrical convergance. So the only way to fix the problem is to replace the lcd with a newer one who wasnt worn out from long term heat.
Sep 22, 2007 | NEC MultiSync MT830 Multimedia Projector
NEC MultiSync MT1050 Multimedia Projector Logo
104 people viewed this question
Top NEC Office Equipment & Supplies Experts
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
