Thin line across screen
I used to be able to tap the TV on the side and the picture would show full again, but now, I think it's dead. Sound and remote works.
    President:
  • 1,779 Answers
Sounds like cold solder joints in the vertical circuit and also check around the yoke plug.
Posted on Apr 04, 2008
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
Hi there My Sansui TV screen started showing thin white horizontal lines across the top of the screen. All of a sudden the screen starts condensing the picture into fine lines across the middle of the...
It is an indication that you have a problem on the vertical section on the main board. The faulty parts is the electrolytic capacitor which affect the linearity of the screen that's why you encountered that kind of problem.
I've advice you to send it to repair shop or look for a qualified technician to isolate the faulty electrolytic capacitor and do re-soldering for some dry joints on the main board.Once replaced the capacitor your unit will back to normal again.
thanks for using fixya...
Jan 07, 2011 | Sansui TVS2750 27"
Picture probs with Orion 14"CRT TV
there is a poor or many poor solder joints in the vertical section of you tv, this is a simple repair for a technician. the set should not be used until this is fixed or this could damage other parts of the television.
Oct 07, 2009 | Televison & Video
No picture Thin line across middle of screen
Most problems indicated by your description involved the Vertical IC. With your post "tap...pop back up" signifies a loose connection or to be more specific a cold solder. I suspect that no part(s) need top be replaced but would however require re-application of heat with the use of a soldering iron.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 19, 2008 | Toshiba 32A50 32" TV
Toshiba 36AF43 36" just has white line in the center
vertical output IC has loose solder joints.if you continue to let it operate this way it will etch a burn line across the face of the tube so discontinue use.
Aug 22, 2007 | Toshiba 36AF43 36" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Televison & Video Logo
165 people viewed this question
Top Televison & Video Experts
