Question about Canon Elura 60 Mini DV Digital Camcorder
Disabling the Auto-Off Power Function on Canon Elura Camcorder in Record Mode
I Have a Canon Elura 65 digital video camcorder as a video input device for the Adobe Visual Communicator 3. I'm not recording onto the Mini DV tape...just using the image to record on my computer. I've noticed that the power down option occurs after a few minutes when I do not record to tape. I want to keep teh camera on so that it continues to send an image to the computer program. Is there a way to set the camera power to remain on or to disable the auto-off function?
  • Michael Bargardi Mar 08, 2012
    I am trying to do what you do. I have a JVC digital camcorder and I am using a USB connection, but I can't get the camcorder to "talk to" Adobe Visual Communicator. Can you give me any advice on what to do? Thank you!
Take the tape out. The Camera should stay on.
Posted on Apr 18, 2008
  • KnitRunGirl Mar 05, 2011
    That's genius, LostDesertRt!! I plugged in my AC power adapter instead of using battery power. I took the MiniDV tape out of my older camcorder, a Canon ZR200, and the "auto power off" message did not appear after 5 minutes of inactivity. The older Canon models have no option to disable the auto power off within the camera's menu settings. Thank you so much for this solution!
What a great service. It worked, and nothing else pointed to this simple solution as even an option. Thank you LostDesertRt!
I'm on my way to using it as desired.
Posted on May 14, 2008
Our Canon Elura 65 Camcorder won't focus. The
First off I don't condone or advise hitting an electronic device but, from the advice of another post I did it and it worked. It shouldn't have but it did. I hit the bottom of the camcorder with the palm of my hand and it worked perfectly afterward.
Jun 28, 2010 | Canon Elura 65 Mini DV Digital Camcorder
Canon Elura 65 Camcorder USB input?
I tried to look over the camera for 20 minues and could not find any slot to put the USB cable in. I looked over the camera just one last time before giving up and and i found a little pull tab on the front of the camera. I pulled the tab and it opened showing a circular insert (for hookup to a TV) and a USB slot!
Sep 07, 2009 | Canon Elura 65 Mini DV Digital Camcorder
Blank screen when recording
In some cases when recording on a camer the display is run through the eye piece on some models there are switches or settings in your menu .. you can try that
Mar 24, 2009 | Canon Elura 60 Mini DV Digital Camcorder
Download movie to computer
I have an elura 65 and I believe this model does not let you download your movies onto the computer in full motion. you can only do it through quicktime or some other similar program using less frames. the higher models: elura 70 etc. are supposed to be capable of transferring full motion film. that's what I understood from the owners manual. hope this helps
Jun 09, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Moving photos from pc to Elura 65 camcorder memory card
You can buy both internal and external USB card readers that can read just about any card you can think of in a package about 3" square. They are not expensive either.
Your local PC retailer will (read should) have these in stock.
Hope that helps
Apr 12, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Canon Elura 100 won't eject tape
I have been having the similar problem. Try switching the power to off and then eject the tape in the off position. My finally ejected.
Apr 04, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Camera not detected by XP
Are there any settings in the camera's menu to tell it to switch to PC Mode?
Mar 12, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Canon elura 65
on mine the ribbon cable from the button to the main board was pinched by the door and shorted
Feb 13, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Record button doesn't function
You may want to check the record lockout safety switch located on the tape. This button can get moved by accident and the camera will refuse to record on that tape. Also, be sure the camera is in "video" mode, not "photo" mode. Some of Canons camcorders have a digital still camera mode which stops the camcorder from functioning because the photos are being recorded to a memory card and not your tape, please check this swithc as well. Good luck. Joe Weibel customelectronics.org
Feb 26, 2007 | Canon Elura 65 Mini DV Digital Camcorder
Canon Elura 60 Mini DV Digital Camcorder Logo
360 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
