Question about Combi Centre DX - Mango
I have an Ariston Microgenus 27 Combi Boiler
Just recently this boiler has decided not to heat my radiators but still gives me plenty of hot water, the heating pipe coming from the pump is hot for about a foot and the pipe going back into the boiler is cold, can anyone advise me wether or not I should buy a new pump ( I have managed to price one up at about 72 Pounds inc VAT ) or would a better option be to buy a new boiler as I might just end up replacing worn out parts for the next couple of months. Thanks for any help
  • Anonymous Mar 28, 2014
    Have had lots of problems with this boiler.
I hate these boilers!
If the pump is not circulating change it. If the pump is ok you may have a blockage in the diverter valve
Posted on Jul 05, 2008
Ariston microgenus he24 fault is e34 but boiler works when front cover is removed
e34 on a ariston is the fan. Boiler fires up with cover off as its getting the air it needs from atmosphere! fan is not running at full speed
Nov 04, 2011 | Combi Centre DX - Mango
Ariston Microgenus 27 boiler - leaking motorised valve
The leak is coming from a seal around the pin that the motor acts upon, the seal does not come as a replaceable part on its own, so the whole flow group as it is called will need to be replaced, approximate price 170 to 200 pounds inc vat, makers part no 998613. plus 2 or 3 hours labour of a corgi registered engineer. If your boiler is more than 6 years old and you have not had to replace the fan or other parts yet, then think about getting a new high efficiency boiler, it could be a better long term solution.
Feb 15, 2009 | Combi Centre DX - Mango
MicroGenus27 No Hot Water
check HW and CH temperature probes check secondary heat exchanger for blockage check water pressure switch
Jan 03, 2009 | Combi Centre DX - Mango
Boiler flames extinguish and reignite regularly
what about flame rectification probe (flame proving probe)
Nov 30, 2008 | Combi Centre DX - Mango
Ariston Microgenus 27mffi combi boiler
im an engineer and recently had exactly the same thing with this ariston boiler, i found out it was the the 'air pressure switch', this is a switch which is part of the ignition, it works in conjuction with the fan. when the boiler fires up the air pressure switch makes, if its faulty it can break the circuit mid flow and cause the burner to shut down therefore giving intermittent hot water and heating, theres a possibility that the aps tubes may be damaged as well so ensure they'e condition is good. hope this helps you
Aug 29, 2008 | Combi Centre DX - Mango
Ariston combi boiler
sounds like your diverter valve is passing on the boiler, this diverts the heat either to the rads or to the taps, if its passing through the heating chanel it'll heat up the rads- may also be a scaled up secondary heat exchanger, hope this helps you
Aug 21, 2008 | Combi Centre DX - Mango
Pressure of Ariston Microporus 27 MFFI
the boiler reqs to be pressurised to 1 bar in a cold state, in operation the heat expansion with cause the gauge to rise by about half a bar so in full working mode with heating on you'll expext the gauge to register around 1 1/2 bar-
Jun 14, 2008 | Combi Centre DX - Mango
No hot water help
have a ariston euro combi boiler ,the problem to get hot water i have to turn the heating on to get hot water. but now it only run for a few min then run cold please help
Feb 18, 2008 | Washing Machines
Combi Centre DX - Mango Logo
810 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
