Question about Singer Vacuums
With my K6 Industrial Singer sewing machine the top thread seems to be too tight. The bottom thread is looping too much on the top of the fabric. The timming is ok. I have checked and rechecked that I have threaded it correctly. It was working great the other day. Please help as we are live out on a property and too far out to get someone out to look at it. Thanks Tania Sorry no category for sewing machines on your list
Hello there, loosen your top thread tension,if it looping on top of the material the tension is way too tight, you will also find changing the thread size to smaller thread, the top tension will also reduce,depending on application a good size thread to use is 25 grade,bobbin tension should have just a slight amount of drag as the top thread and bottom work against each other when sewing.
regards
Tony
Posted on Feb 03, 2009
Can not catching the bobbin tread at the bottom
The bobbin may be in backwards
the needle is not the correct one for the machine
the needle isn't correctly seated in the needle clamp
the machine is a little bit out of time.
Remember to hang on to the needle thread when you're trying to pick up the bobbin thread
Turn the handwheel in the direction that would advance the fabric from the front to the back of the machine
make sure the bobbin-winding spindle has been pushed back to the left for sewing
make sure your needle is inserted correctly as far as it will go with the flat side facing back
and that the upper tension disks of your machine are threaded correctly.
Make sure the presser foot is up when seating the thread through the upper tension.
Turn the hand wheel (TOWARDS YOU ONLY) never turn the hand wheel away from you and hold the needle thread lightly. .
pull the loop up and then pull both threads (top and bobbin) under the foot and toward the back of the machine.
Also could be a timing problem
Mar 18, 2016 | SewShop.com Singer Model 347 Instruction...
I own a singer 14sh654. Bottom stitch really loose,don't know what to set any of the dials at to make it work right. The top stitch is neat tight bottom all over the place
Hi. Loose stitching underneath means you need to increase the upper tension. Try just a little at a time, using scrap fabric of similar weight to what you want to sew.
Aug 19, 2011 | Singer Vacuums
Sewing basic stitch is good on right side of fabric but looks like a wavy line on reverse
Hi. Chances are your upper thread tension may need to be adjusted, increasing it by very small amounts at a time (say one tenth of one whole number), see if the stitching on the bottom improves. Another possibility is that the bottom fabric is moving around. Try pinning top and bottom together with straight pins set at a right angle to the stitch line. A third possibility could be lower thread tension set to tight. If the lower tension screw is all the way in, this is likely your problem.
Aug 19, 2011 | Vacuums
I have a Tacsew T11-115 and I do not have an instruction book. I need to see if I have it treaded correctly and how to adjust the bobbin tension. The top thread is laying on the fabric and the bobbin...
For all sewing machines, if the bobbin thread is showing on the top surface, then the top tension is probably too tight. Turn the tension indicator to the left by half a number to a lower value. (So that if 5 was lined up with the dot initially, then go to 4.5 lined up with the dot).
See this article for some clear pictures of thread tension adjustments: http://www.ca.uky.edu/HES/fcs/FACTSHTS/CT-MMB-213.pdf . If you can find it the Singer Sewing Book is a good reference http://www.amazon.com/Singer-Sewing-Book-Gladys-Cunningham/dp/0307098702 .
This site, http://www.allbrands.com/products/abc0762.html , may be able to find and send you a manual to the TacSew T11-115. They have the T11-155 for sale.
I hope this helps.
Jun 12, 2011 | Vacuums
I amhaving trouble with the thread brahing and I don;t know if it is the tension. Which way should the pobbing turn right or left and how do you set the tension For my Singer sewing machine
Check the upper threading and make sure it is threaded correctly. When you pull on the thread before it goes through the needle does it give a bit or does it break? If it is breaking when you pull then the tension is way too tight or it is threaded incorrectly. Make sure it isn't looped around some guide along the line too.
For the bobbin thread... when it is in the bobbin case outside of the machine dangle it by the thread. It should hang there until you flick your wrist a bit, which should cause some thread to release and drop the bobbin down towards the floor a bit. (If it just pulls out right to the floor it is too loose). Most bobbin tension is tightened by a small screw on the bobbin case near where the thread comes though. Breaking thread would not be from the bobbin thread being too loose. Too loose would cause looping on top side of the stitch not breakage.
Make sure the bobbin is in correctly. You should feel and hear a slight "click" when the bobbin goes in correctly.
Apr 26, 2011 | Singer Vacuums
I have a Janome 8048. Here's my problem: As I sew I notice that the stitches on the top of the fabric look the way they should on the bottom side and when I take the material off the machine and flip it...
I haven't sewn in years. A sewing machine has a tension control on top and on the bobbin. If the intersection of the top and bottom threads is not in the middle of the sewn material, you have to adjust your tension.
In your case, what I think you are saying is that the stitch on top is just a straight line and on the back it disappears into the fabric.
To correct this, lower the top tension by loosening the tension adjuster on the thread where the thread loops around the small pulley.
Also, you could tighten the tension on the bobbin by slightly tightening the small screw on the side of the bobbin.
Gary
Feb 21, 2011 | Vacuums
Singer simaco 95-1 timing belt
I can't seem to get this thing posted. I have the same problem and have started contacting leather craftsmen to see if someone can fabricate the belt. We can't find the join and wonder if each end was shaved down and then overlayed and glued somehow to keep it all the same thickness. Let me know if you come up with anything.  Terry tergould@gmail.com
Mar 17, 2008 | Vacuums
Vacuums Logo
256 people viewed this question
Top Singer Vacuums Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Vernon Taylor
Are you a Singer Vacuum Expert? Answer questions, earn points and help others
