Question about Tascam 2488 Portastudio Multitrack Recorder System
Tascam 488 ?
When i turn on the tascam 488, the vu meters go up about half , all 8 tracks. and just stay there. any help?
jim
2 Suggested Answers
SOURCE:
  • 189 Answers
SOURCE: TRANSFERING OLD TRACKS TO THE NEW TASCAM 2488-NEO
You'll need your PC as the intermediary. You'll have to do a USB export of the tracks you want from the DP01 to your PC and then connect the 2488's USB to the PC and do a USB import of those tracks into new tracks on the 2488.
Page 40 of the DP01FX manual will explain using the USB connection and page 43 details the steps for performing a USB export.
In the 2488 NEO manual refer to pages 80 and 81 for using the USB connection and importing the tracks.
Hope this helps. Best of luck.
bd.
Posted on Oct 19, 2009
I have a tascam 488 mk II when its turned on the play record and pause lights all are blinking and dont know why?
check to see if any of the buttons on the play/record panel are pushed down or stuck if not go to the tascam website and submit a trouble iinquiry
Oct 08, 2014 | Tascam 488 MKII Portastudio
Just got a Tascam DP-01 and plug my keyboard into input A and assigned it. I clicked the record button for track one . I can hear the output in the headphones and the meter is showing on the Tascam, but...
If the track can be armed for recording, it won't show anything until you arm that track. Otherwise, check to see if you can hear anything on the main output. If so, then it's just the lights, which will not affect functionality.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Feb 12, 2011 | Tascam DP01 All-In-One Recording Package...
I installed my tascam mk2.under Cubase LE4. Midi tracks work good.In "set-up devices" I see the Tascam inputs and outputs.Monitor VU-meter is not moving in this audio track and consequently there is no...
Have you clicked the little "monitor" icon (looks like a speaker) on the armed audio track so that it goes orange? Once on, you should see a signal on the VU meter (assuming the line in has a good signal etc). Once recorded, turn the monitor off again to listen to the track with all the others.
Jan 26, 2010 | Tascam US-144 Sound Card
bd.
Oct 14, 2009 | Tascam 2488 Portastudio Multitrack...
TASCAM 80-8 DECK NO VU LIGHTS NO REEL MOTORS CAPSTAIN MOTOR RUNS VU METERS THUMP WHEN SWITCH /MAIN POWER IS DEPRESSED
the machine vu lights were dim the reel motors ran then the lights got dimmer and the reel motors stopped its quite old now but never let me down . best regards kirk
Dec 07, 2008 | Tascam Audio Players & Recorders
DP-01FX
I shut down the system, waited 30 seconds, turned it back on, and the recording went fine. Must've been a glitch.
Jun 18, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam 488 mk II recording problems
Have you taken a look at the edge of the tape? tracks 1 and 2 on a cassette are usually next to the edge and you may have a bad batch of tapes that have the edge damaged. Another possible but not a likley problem might be the tape is out of spec. for the width, and your heads MAY have a little wear from use, and are trying to act like tape guides. If the tape is slightly wider than the grove worn in the head, the tape would be lifted at the edge and not make contact to the head. It is not electronic as you have diagnosed this with other tapes. Give it a try and see!
Aug 05, 2007 | Maxell 109069 Audio Cassette (Type 1)...
Tascam 2488 Portastudio Multitrack Recorder System Logo
37 people viewed this question
Top Tascam Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Ekse
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
