Question about Toshiba 32A61 32" TV
Remote problem i have a toshiba 32a61 tv and the other day the remote stopped working. tried different remotes the same problem,,,,,,, i unplugged the tv over night and the next morning the remotes worked for like 5 minutes but now they wont work at all. any ideas
  • Lngwayhome Apr 04, 2008
    the tv works fine using the button on the tv, i can change channels and set all the setting from there, when i unplugged it the remotes started working so im thiking its the rf on tv
    President:
  • Toshiba Master
  • 1,779 Answers
With the set on, I would like you to use all of the manual control buttons on the set to see if they all work the way they should. If any one of them does not or if all don't, then I would say your have a corrupted E-Prom which will have to be replaced by a service center. This is not an expensive repair, probably around 75-100 $, depending on who does it. It's a no brainer for a tech.
Posted on Apr 04, 2008
SOURCE:
Toshiba 32a33. I'll be watching tv and the volume bar shows goes down to 0 (no sound) when it is in this mode the remote control will not work on the volume, you can get up and manually up the volume...
1st check to see if your remote volume down button is stuck. 2nd do you have wireless internet (router) or any other wireless devices phones,ceiling fans, another Toshiba remote, if so try unplugging them (or remove the batteries if it's a remote) while it's changing the volume one at a time. If a different device makes it stop try changing the channel on it. Also make sure the t.v doesn't have a mind of its own and remove the batteries out of the t.v remote, let it ride for a couple days if it happens without the remote being in play then you know your t.v is acting strange, if it stops then starts back up when you start using the remote again then you know your dealing with a remote issue. Sometimes Freq.'s merge causing remotes/wireless devices to conflict with each other.
May 18, 2011 | Toshiba 32A33 32" TV
I have an old remote that works for a VCR and I did have it working for the TV but one day someone was playing with buttons and it stopped working. I was wondering how to program my Toshiba vc 260 remote...
Try the following procedure:
1. Make sure there are working batteries in the Toshiba remote control.
2. Turn on your television set, DVD player or other device that you want to control with the Toshiba remote.
3. Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
4. Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed.
Feb 28, 2011 | Toshiba Vc-260 Remote Control
My universal remote stopped working, I bought another one and it doesn't work either, I mean it doesn't work with my set, it seems I programmed it correctly but when I try to change the channel it doesn't...
It was the TV set! I googled remote control problems and went on one of the websites......The answer was quite simple, unplug the TV for a few minutes and let it reset itself. I did and it did! I guess it's no different than a cell phone or computer sometimes!
Sep 16, 2009 | Toshiba 27A30 27" TV
Toshiba 32A61 will not respond to the original remote or the cable remote (volume, channel or power). TV works fine if buttons on the set are used.
Check the obvious.One easy way to know if your remote is working is by watching the diode in the front of the remote through a digital camera (from a cell phone or any other). If you see a light beam emitted, then the remote is working and the problem is most likely in the TV.
Aug 25, 2009 | Toshiba 36A40 36" TV
Toshiba TV Remote Control not working
REPLACE IR SENSOR INSIDE THE SET COMMON PROBLEM
Apr 11, 2009 | Toshiba 36AF42 36" TV
Password for tv function
try unplugging it for about 3 days.
Mar 02, 2008 | Toshiba 19A26 19" TV
SHARP T.V. not responding to remote, but remote isn't broken
Here are the Toshiba codes for universal remote- 000,048,049,072,073,105,109,118,160,162,190,&241 try these codes and see if this works.ThankYou for using FixYa and Have a Nice day.
Feb 05, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba 36AF43 will not operate via remote control (Yes, the batteries are fresh!)
try unplugging the tv and allow the tv to remain unplugged for a least 5 minutes. This will force a reset on the tv which should resolve your remote issues.
Dec 17, 2007 | Toshiba 36AF43 36" TV
i have bought universal remote controls and they do not work. what can i do? i have bought rca universal philips universal remote,
Nov 17, 2007 | Toshiba 36HFX71 36" TV
I have been seeing a lot of Toshiba remote "eyes" (the infra-red receiver inside the TV) fail recently. If several known good remotes cannot control the TV then the IR receiver will have to be replaced. If you have no experience soldering and unsoldering PC boards then have a qualified tech handle it for you.
Jun 27, 2006 | Toshiba 32A30 32" TV
Toshiba 32A61 32" TV Logo
88 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
