Question about Asko Dishwashers
Faulty Asko dishwasher
Asko D3350-8 dishwasher all lights on display are on and the pump out pump runs continuiously every time we power up the unit
  • Steve edwards
    Steve edwards Apr 12, 2015
    Same thing happening to my dishwasher. Any ideas?
We were told by an ASKO technician that it has something to do with a balance issue. You could try tilting the machine forward (make sure you've removed side screws into walls first though otherwise you could damage the cupboards).
Posted on Apr 11, 2009
SOURCE:
Pump continually running with F2 displayed.
There is water in the lower pan that you must access by removing the toe kick plate and then the panel behind it. you will see water in the overflow area. Clean that out and all will be well. Asko's are awesome dishwashers that capture any water they may overflow or leak internally instead of it going on your floor, then a float switch triggers the F2 error and runs the drain pump.
May 30, 2012 | Asko D1716 Built-in Dishwasher
All of lights on a panel are blinking when I turn on my dishwasher.
Hello, welcome to FixYa.
Based on your post, "Asko 1996FI Dishwasher. ..All lights on panel blinking", the good news...It is likely nothing very serious, but the "resolve" requires some investigation on your part.
-What this means is the control has indicated a overfill-
**before proceeding turn the dishwasher power off via the home breaker panel, or unplug it from the wall if that is possible...most are hard wired to the home electrical...safety first**
The first thing to do is remove the toe panel/kick plate and inspect the base for water. There will likely be water present.
With the aid of a sponge, towels, or a wet-dry shop vacuum, absorb the water from the base, that should restore normal operation...it should be known that if you leave the unit for a few days, the water in the base will evaporate hence appearing as everything is fine again...if any other problem/leak does exist it will return.
If the unit works fine after resetting the power/breaker and soaking up any water present, it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump...
(it could mean a faulty drain pump so you'll need to pay close attention the next few times you run it)
**The float is primarily the last ditch safety to prevent disaster in the event of a overflow, back-flow, or leak underneath the unit and the illuminated LED's are
letting you know to service or call for service to the unit**
Hope this helps move you forward, or even better resolves the issue altogether. Let me know of course, I will help you move further if necessary. Good luck.
Regards,
Macmarkus :)
Aug 18, 2011 | Asko 1996FI Dishwasher
Asko 1895 shows F2 outlet pump running no water in washer will not shut off have shut off power and restarted stll shows F2 with pump running ?
open the access to the pump and make sure thats its clear and that there are no foreign objects blocking the impellar from spinning. Unit will not start if drain pump is clogged
May 03, 2011 | Asko Dishwashers
My Asko Dishwasher D1976 on the main panel all of the top lights are on and in the display window it flashes F2. The motor is on but nothing else is happening can you help. I have checked that drains are...
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be ther when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now.
Hope it helps...
Daniel
Apr 22, 2011 | Asko D1976CSTM Built-in Dishwasher
My asko dishwasher will not turn off. The pumps runs but nothing happens. The dial has no control over the machine at all. I have turned off the breaker but wonder should I order parts or can it. We...
Hello Steve,
Welcome to FixYa.
As an Asko expert and based on your post, the good news...I can fairly confidently tell you It is likely nothing very serious, but the "resolve" requires some investigation on your part.
What the pump running continuous means is the timer has indicated a overfill.
**The float is primarily the last ditch safety to prevent disaster in the event of a overflow, back-flow, or leak underneath the unit and the continuous pumping is
Good luck.
Regards,
Macmarkus :)
Apr 08, 2011 | Asko D1716 Built-in Dishwasher
Won't drain and unit will not shut off
water will not go into my dishwasher any solutions
Nov 16, 2009 | Asko D1776 Stainless Steel Built-in...
ASKO D3251 flashing error message; drain gurgling, power off
You most likely have a leaking bottom spray arm. The water is in the pan under your unit. It requires dealer service. If you are still in your 3-year warranty, good; otherwise be prepared to put out hundreds of dollars. I'm going though this now for a second time on my $1600 D3251. Asko did grant a one-time extension on my warranty since it expired a month ago. In 6 months when it breaks again, I'll buy a Bosch. I also had this same problem on a previous Asko. I can't get more than 3 years out of these units, so this is my last Asko. When it breaks again, I'll go with Bosch. Good Luck.
Mar 17, 2009 | Asko D3251HDSS Stainless Steel Built-in...
Viking (made by ASKO) Dishwasher Problem
You can find parts, solutions and manuals at link below. Hope this helps, Sea Breeze
Click below
http://www.retrevo.com/s/Asko-D1716-Dishwashers-review-manual/id/21338ci577/t/1-2/
Dec 18, 2008 | Asko D1716 Built-in Dishwasher
Asko dishwasher model 1475
Have the same problem with our asko 1475. In the past, we would disconnect the dishwasher and when we reconnected the power, it ran fine. This time it isn't helping!
Nov 08, 2007 | Dishwashers
Dishwashers Logo
882 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
